    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 84.7k Views 19 Watching
      sdetweil @Mr.Gysy
      @Mr-Gysy please read and copy/paste
      sudo ifconfig
      U are typing iPconfig
      Not p
        Mr.Gysy
        thats the screen above :)
          sdetweil @Mr.Gysy
          @Mr-Gysy no screen above shows 2 times the command
          ipconfig
          I need you to use
          ifconfig
          Windows system uses ipconfig
          Linux does not
            Mr.Gysy @Mr.Gysy
            @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
            ifconfig worked
            alt text
            that is “ifconfig”
              sdetweil @Mr.Gysy
              @Mr-Gysy ok. U have two interfaces.
              What is address: in config.js?
                Mr.Gysy
                you mean this? 0.0.0.0 or?
                alt text
                O 1 Reply Last reply
                • O
                  OldSunGuy @Mr.Gysy
                  @Mr-Gysy
                  config.js has a typo
                  adresss: “0.0.0.0”,
                  should be.
                  address: “0.0.0.0”,
                    Mr.Gysy
                    @OldSunGuy said in [MMM-Remote-Control] Can not access remote control module:
                    address: “0.0.0.0”,
                    what a shit failure.
                    THANKS VERY MUCH!!!
                      sdetweil @Mr.Gysy
                      @Mr-Gysy hm … the default according to the API used is 0.0.0.0 if not specified.
                      The typo would make it not specified…
                      • O
                        OldSunGuy
                        Isn’t the default localhost?
                        General property option
                        On my rpi I get the ::1 IPv6 address
                        pi@raspberrypi ~ % getent hosts localhost
                        ::1             localhost ip6-localhost ip6-loopback
                        pi@raspberrypi ~ %
                        Both IPv4 and IPv6 addresses are in my local /etc/hosts file:
                        pi@raspberrypi ~ % grep localhost /etc/hosts
                        127.0.0.1       localhost
                        pi@raspberrypi ~ %
                        • W
                          Welle05 @Mykle1
                          @Mykle1 said in [MMM-Remote-Control] Can not access remote control module:
                          Thank you so much, also from my side! I spent hours to look for the mistake and it was again the wrong written “address”
                          • 4 / 4
