    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 84.7k Views 19 Watching
      Mr.Gysy
      thats the screen above :)
        sdetweil @Mr.Gysy
        @Mr-Gysy no screen above shows 2 times the command
        ipconfig
        I need you to use
        ifconfig
        Windows system uses ipconfig
        Linux does not
          Mr.Gysy @Mr.Gysy
          @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
          ifconfig worked
          alt text
          that is “ifconfig”
            sdetweil @Mr.Gysy
            @Mr-Gysy ok. U have two interfaces.
            What is address: in config.js?
              Mr.Gysy
              you mean this? 0.0.0.0 or?
              alt text
              O 1 Reply Last reply
              • O
                OldSunGuy @Mr.Gysy
                @Mr-Gysy
                config.js has a typo
                adresss: “0.0.0.0”,
                should be.
                address: “0.0.0.0”,
                  Mr.Gysy
                  @OldSunGuy said in [MMM-Remote-Control] Can not access remote control module:
                  address: “0.0.0.0”,
                  what a shit failure.
                  THANKS VERY MUCH!!!
                    sdetweil @Mr.Gysy
                    @Mr-Gysy hm … the default according to the API used is 0.0.0.0 if not specified.
                    The typo would make it not specified…
                    • O
                      OldSunGuy
                      Isn’t the default localhost?
                      General property option
                      On my rpi I get the ::1 IPv6 address
                      pi@raspberrypi ~ % getent hosts localhost
                      ::1             localhost ip6-localhost ip6-loopback
                      pi@raspberrypi ~ %
                      Both IPv4 and IPv6 addresses are in my local /etc/hosts file:
                      pi@raspberrypi ~ % grep localhost /etc/hosts
                      127.0.0.1       localhost
                      pi@raspberrypi ~ %
                      • W
                        Welle05 @Mykle1
                        @Mykle1 said in [MMM-Remote-Control] Can not access remote control module:
                        Thank you so much, also from my side! I spent hours to look for the mistake and it was again the wrong written “address”
                        • 4 / 4
