    reinstall walkthrough
    5 Posts 4 Posters 3.2k Views 4 Watching
      mrdenmark
      i have a problem where i can’t get my pi to connect to the internet ,after trying for a while i’ve decided to reinstall raspbian.
      i will want to reinstall magicmirror after this-whats the easiest/fastest way of doing this?
      obviously i’ll need to backup my config.js
      can i copy the entire magicmirror folder and transfer it after the install?
      any tips or walkthroughs on this will be greatlt appreciated
      Mykle1M FoziF 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @mrdenmark
        @mrdenmark said in reinstall walkthrough:
        @sdetweil’s install script is by far the easiest/fastest/best way of installing MM. https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        You can.
        M 1 Reply Last reply
          mrdenmark @Mykle1
          @Mykle1 i already have a working magicmirror,its just the pi its on won’t connect to the internet(os problem)
          so i’ll reinstall raspbian,reinstall mm but which files should i keep to transfer,i’ll keep the config because i don’t want to do that again-which other files should i keep from the existing setup?all the module folders?
          • FoziF
            Fozi Project Sponsor @mrdenmark
            @mrdenmark This is what I do:
            Make regularly a backup of the SD-card image and store it away to a safe place. Depending on your environment (Windows, mac, Linux, …) there exist lots of great tools for backing up and restoring SD cards. On my Mac I use ApplePi Baker. Here is a description on how to backup the SD card under Linux
              sdetweil @mrdenmark
              @mrdenmark copy the whole MagicMirror folder to another name
              run the install script to get the rest of the system updated
              then move the new MagicMirror folder out of the way, and move the copied one back
