    Update troubles. Again.
    10 Posts 5 Posters 2.5k Views 4 Watching
    • U Offline
      uatuba
      Every time I update, it seems to break something. This is getting frustrating, because I can’t diagnose the problem. This time, it shows MM is running in PM2, but all I see is my Pi desktop. I don’t even know where to begin to fix the issue, because it seems like everything should be working.
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich @uatuba
        What exact steps did you take to update?
        • U Offline
          uatuba
          Ssh to the device
          git pull (as mentioned in the readme)
          reboot
          • U Offline
            uatuba
            Was the update intended to work with Raspbian updates, too? Could the MagicMirror update have a breaking change if Raspbian hasn’t been updated?
              bdream
              @uatuba I had trouble also.
              As mentiones by Stedweil I used script from first threat in link text
              Make sure to stop MM before running update
              cheers, bdream
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                uatuba @bdream
                @bdream said in Update troubles. Again.:
                link text
                This seems like a great feature that would prevent a lot of issues. I don’t think it will help me in my current predicament, though, since I already updated according to the readme.
                • evroomE Offline
                  evroom @uatuba
                  @uatuba
                  The v2.20.0 announcement said
                  https://forum.magicmirror.builders/topic/11899/v2-10-0
                  Please update using the following command: git pull && npm install.
                  Note that one has to be in the MagicMirror directory before issuing these commands (cd ~/MagicMirror).
                  The README.md shows 2 commands, see:
                  https://github.com/MichMich/MagicMirror/blob/master/README.md#updating
                  Not a sign of just an single git pull anywhere.
                  Anyway, I would suggest you to try the commands from the first post in this topic:
                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                  The only note would be that it is advised to stop MM (e.g. using pm2 stop mm).
                  Success.
                  MagicMirror version: 2.33.0
                  Test environment:
                  MagicMirror version: v2.33.0
                  • U Offline
                    uatuba @evroom
                    @evroom my apologies…I DID use both. After rebooting again, I now get “line 66: electron not found.”
                    S evroomE 2 Replies Last reply Reply Quote 0
                      sdetweil @uatuba
                      @uatuba the update posting says
                      git pull & npm install
                      did you do the npm install part? in the MagicMirror folder?
                      the new distribution needs dependencies (libraries) newer than previously installed.
                      so you have to redo npm install to update them
                      if u ran the script from the new updater topic, please post the contents of
                      MagicMirror/installers/upgrade.log
                      • evroomE Offline
                        evroom @uatuba
                        @uatuba
                        No need to apologize, but you were asked to supply the exact steps taken.
                        A git pull followed by npm install in the MM homedir will most likely solve your electron error message.
                        If not, the upgrade script from Sam will solve it or at least will provide with some info to check for.
                        Test environment:
