    What is the procedure for reviving a dead module?
    13 Posts 6 Posters 4.0k Views 6 Watching
      A Former User
      Of course, you can also release new module with new name like MMM-fitbit2.
      S 1 Reply Last reply Reply Quote 3
        sdetweil @Guest
        @Sean true…
        • V Offline
          Vizulize Module Developer @sdetweil
          @sdetweil Obviously this would be an option if it weren’t dead. My question was what to do given the fact that a PR is unlikely to be responded to.
          @Sean I think that this is probably the way to go, so I’ll do that.
          Thanks!
          • F Offline
            Fr8Trayne
            Yes please do this. I was just looking to add this today, but looks like I’ll wait. If you’re able do you mind adding the water stat as well?
            • V Offline
              @Fr8Trayne I’ve got the following currently supported data:
              • Steps Walked (compared to goal)
              • Calories Burned (compared to goal)
              • Total Distance Walked (compared to goal)
              • # of Active Minutes (compared to goal)
              • # of Floors Climbed (compared to goal)
              • Resting Heart Rate (average for the day)
              • Today’s Remaining Water Intake (amount consumed subtracted from goal)
              • Today’s Remaining Calories To Consume (amount consumed subtracted from goal)
              • Sleep Time (compared to goal)
              • Current Weight (last weigh-in, if within the last 30 days)
              I need icons for water, food and weight, and some assistance with formatting before I will post it publicly. Perhaps I will create a new forum post for this.
              • F Offline
                Fr8Trayne
                This is awesome! Did you add it as a new module?
                • V Offline
                  I want to get icons and formatting sorted before I add it publicly. However, you can try it here: https://github.com/m-roberts/MMM-Fitbit2
                  Also, I need to handle credentials from the config, as currently they are hard-coded into files that are used by the Python Fitbit library. This needs to be handled from the config directly, to support multiple Fitbit accounts on one setup.
                  F 1 Reply Last reply Reply Quote 2
                  • F Offline
                    Fr8Trayne @Vizulize
                    @Vizulize keep up the great work! If I had the coding knowledge to help I would definitely lend a hand. This will be an awesome addition to many Magic Mirrors.
                    • V Offline
                      I have posted the module here. I am looking for testers!
                      lavolp3L bheplerB 2 Replies Last reply Reply Quote 1
                      • lavolp3L Offline
                        lavolp3 Module Developer @Vizulize
                        Oh, am I jealous of you fitbit guys. Garmin has a very costly API only intended for professionals.
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
