    What is the procedure for reviving a dead module?
    13 Posts 6 Posters 3.9k Views 6 Watching
    • V Offline
      Vizulize Module Developer
      MMM-fitbit has been inactive for over 3 years.
      I am interested in picking this project up myself, but I am not sure what the procedure is for doing this.
      Should I create a new module name for it, or should I “replace” this module as its active development equivalent?
      Thanks!
        sdetweil @Vizulize
        @Vizulize fork the module (upper right button on github page)
        now you have a copy of the module, and u can do whatever you want…
        if you care, or the author cares, u can submit your changes back (submit a Pull Request to the author)
        if not, then don’t…
        V 1 Reply Last reply Reply Quote 1
          A Former User
          Of course, you can also release new module with new name like MMM-fitbit2.
          S 1 Reply Last reply Reply Quote 3
            sdetweil @Guest
            @Sean true…
            • V Offline
              Vizulize Module Developer @sdetweil
              @sdetweil Obviously this would be an option if it weren’t dead. My question was what to do given the fact that a PR is unlikely to be responded to.
              @Sean I think that this is probably the way to go, so I’ll do that.
              Thanks!
              • F Offline
                Fr8Trayne
                Yes please do this. I was just looking to add this today, but looks like I’ll wait. If you’re able do you mind adding the water stat as well?
                • V Offline
                  @Fr8Trayne I’ve got the following currently supported data:
                  • Steps Walked (compared to goal)
                  • Calories Burned (compared to goal)
                  • Total Distance Walked (compared to goal)
                  • # of Active Minutes (compared to goal)
                  • # of Floors Climbed (compared to goal)
                  • Resting Heart Rate (average for the day)
                  • Today’s Remaining Water Intake (amount consumed subtracted from goal)
                  • Today’s Remaining Calories To Consume (amount consumed subtracted from goal)
                  • Sleep Time (compared to goal)
                  • Current Weight (last weigh-in, if within the last 30 days)
                  I need icons for water, food and weight, and some assistance with formatting before I will post it publicly. Perhaps I will create a new forum post for this.
                  • F Offline
                    Fr8Trayne
                    This is awesome! Did you add it as a new module?
                    • V Offline
                      I want to get icons and formatting sorted before I add it publicly. However, you can try it here: https://github.com/m-roberts/MMM-Fitbit2
                      Also, I need to handle credentials from the config, as currently they are hard-coded into files that are used by the Python Fitbit library. This needs to be handled from the config directly, to support multiple Fitbit accounts on one setup.
                      F 1 Reply Last reply Reply Quote 2
                      • F Offline
                        Fr8Trayne @Vizulize
                        @Vizulize keep up the great work! If I had the coding knowledge to help I would definitely lend a hand. This will be an awesome addition to many Magic Mirrors.
