    organization of the text next to the icon.
    48 Posts 3 Posters 27.6k Views 5 Watching
    • I Offline
      iorifly
      @doubleT said in organization of the text next to the icon.:
      newCell = newrow.insertCell(1);
      newCell.className = “align-left”;
      newText = document.createTextNode(name);
      newCell.appendChild(newText);
      alignment resolved. Can I now create lines to separate groups? Or is it impossible?
        doubleT Module Developer
        Ok, please keep in mind that this is not the best solution (working directly in the code).
        If you want to make the changes via custom.css file, try this:
        (Now, since the module is called “MMM-homeassistant-sensors” I’m going to assume the element is identifiable with _“.module.MMM-homeassistant-sensors” …)
        Tell each 2nd cell to align its content left:
        .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
            text-align: left;
        Tell the cells of the 3rd and 6th line to have a bottom border line:
        .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
        .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
            border-bottom: 1px solid white;
        If the line is separated, try:
        .module.MMM-homeassistant-sensors table {
            border-spacing: 0;
        EDIT: There was an error, it’s text-align, of course. Not test-align.
        • I Offline
          iorifly
          Let me see if I got it. I need to change the custom.css file. Where is it located?
          in the css folder. I only have the main.css file
            Create a file named “custom.css” and put the code from above inside it.
            • I Offline
              iorifly
              border-spacing: 0;
              nothing happened. This is the same way. He did not create the lines.
                Yeeeeah … what about the one above that? The 2nd part. ;)
                  sdetweil @iorifly
                  @iorifly take the .module prefix off, not needed
                  • I Offline
                    iorifly @sdetweil
                    @sdetweil ok
                    • I Offline
                      iorifly @doubleT
                      @doubleT
                      excuse. LOL
                        I did not understand.
                        The content of the custom.css should be:
                            test-align: left;
                            border-spacing: 0;
                        All of it. Not just the last part.
                        • I Offline
                          iorifly
                          test-align: left;
                          border-spacing: 0;
                              test-align: left;
                              border-spacing: 0;
                            @sdetweil I don’t have any modules with uper case letters (MMM- …) at the moment. Can you confirm the module class name is with uper case letters or is it changed to lower case?
                            In this situation, with a unique module name, it’s ok to identfy the module without the .module but in general I’d say it’s best practice that if you want to address a specific module, you describe it as precise as possible.
                            E.g. there might be a module “image_frame” that you want to address but there’s also a module that somewhere within its structure has one div with the class “image_frame” that you don’t want to address. Then it’s absolutely necessary to address the target with .module.image_frame
                            • I Offline
                              iorifly
                              added “.modulo” before .MMM
                                And that worked? :thinking_face:
                                • I Offline
                                  iorifly
                                  @doubleT
                                  I noticed that the font color is erased. Why that ? the other modules have the strongest colors!
                                    Because the creator of that module gave the wrapper the class name “dimmed” in line 38 …
                                    • I Offline
                                      iorifly
                                      @doubleT Unfortunately not.
                                      • I Offline
                                        iorifly @doubleT
                                        esmaecido
                                        what I put in place to make it clearer (alive)
                                          Can you show me what your custom.css file looks like now?
                                          • I Offline
                                            iorifly
                                            @doubleT
                                                test-align: left;
                                                border-spacing: 0;
                                            note: I’m slow to answer because I have to wait 120s to post.
                                            • 2 / 3
