    organization of the text next to the icon.
    48 Posts 3 Posters 28.1k Views 5 Watching
      doubleT Module Developer
      Yeeeeah … what about the one above that? The 2nd part. ;)
      I 1 Reply Last reply
        sdetweil @iorifly
        @iorifly take the .module prefix off, not needed
        • I
          iorifly @sdetweil
          @sdetweil ok
          • I
            iorifly @doubleT
            @doubleT
            excuse. LOL
              I did not understand.
              The content of the custom.css should be:
              .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
                  test-align: left;
              .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
              .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
                  border-bottom: 1px solid white;
              .module.MMM-homeassistant-sensors table {
                  border-spacing: 0;
              All of it. Not just the last part.
              • I
                iorifly
                @doubleT said in organization of the text next to the icon.:
                test-align: left;
                border-spacing: 0;
                    test-align: left;
                    border-spacing: 0;
                  @sdetweil I don’t have any modules with uper case letters (MMM- …) at the moment. Can you confirm the module class name is with uper case letters or is it changed to lower case?
                  In this situation, with a unique module name, it’s ok to identfy the module without the .module but in general I’d say it’s best practice that if you want to address a specific module, you describe it as precise as possible.
                  E.g. there might be a module “image_frame” that you want to address but there’s also a module that somewhere within its structure has one div with the class “image_frame” that you don’t want to address. Then it’s absolutely necessary to address the target with .module.image_frame
                  • I
                    iorifly
                    added “.modulo” before .MMM
                      And that worked? :thinking_face:
                      • I
                        iorifly
                        @doubleT
                        I noticed that the font color is erased. Why that ? the other modules have the strongest colors!
                          Because the creator of that module gave the wrapper the class name “dimmed” in line 38 …
                          • I
                            iorifly
                            @doubleT Unfortunately not.
                            • I
                              iorifly @doubleT
                              esmaecido
                              what I put in place to make it clearer (alive)
                                Can you show me what your custom.css file looks like now?
                                • I
                                  iorifly
                                  @doubleT
                                      test-align: left;
                                      border-spacing: 0;
                                  note: I’m slow to answer because I have to wait 120s to post.
                                    Oh, I noticed a typo – even though that’s not the reason it’s not working. Change te_s_t-align to text-align, please. ;)
                                    What’s the name of the module in your config file?
                                    • I
                                      iorifly @doubleT
                                      x t-align
                                      hitting the text did not appear the line either.
                                        In that case the css should work. And the css file is named custom.css? Exactly like that? And you restarted the mirror?
                                        Since we’re already working directly in the code: In the module js there’s a line
                                        var tableElement = document.createElement("table");
                                        You can write a line directly after that:
                                        tableElement.className = "homeassistant-table";
                                        Then you should be able to address the table in the cusom.css like this:
                                        .homeassistant-table tr td:nth-of-type(2) {
                                            text-align: left;
                                        .homeassistant-table tr:nth-of-type(3) td,
                                        .homeassistant-table tr:nth-of-type(6) td {
                                        .homeassistant-table {
                                            border-spacing: 0;
                                        Is the text brighter now?
                                        EDIT: tableElement, not table.Element
                                        • I
                                          iorifly
                                          text-align: left;
                                          border-spacing: 0;
                                          do I delete the text from what was in the custom? or leave and put this?
                                            Delete the previous code in custom.css if you added that className line in the module’s js.
                                            • 2 / 3
