    organization of the text next to the icon.
    48 Posts 3 Posters 23.2k Views 5 Watching
      doubleT Module Developer
      Ok, please keep in mind that this is not the best solution (working directly in the code).
      If you want to make the changes via custom.css file, try this:
      (Now, since the module is called “MMM-homeassistant-sensors” I’m going to assume the element is identifiable with _“.module.MMM-homeassistant-sensors” …)
      Tell each 2nd cell to align its content left:
      .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
          text-align: left;
      Tell the cells of the 3rd and 6th line to have a bottom border line:
      .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
      .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
          border-bottom: 1px solid white;
      If the line is separated, try:
      .module.MMM-homeassistant-sensors table {
          border-spacing: 0;
      EDIT: There was an error, it’s text-align, of course. Not test-align.
      • I Offline
        iorifly
        Let me see if I got it. I need to change the custom.css file. Where is it located?
        in the css folder. I only have the main.css file
          Create a file named “custom.css” and put the code from above inside it.
          • I Offline
            iorifly
            @doubleT said in organization of the text next to the icon.:
            border-spacing: 0;
            nothing happened. This is the same way. He did not create the lines.
              Yeeeeah … what about the one above that? The 2nd part. ;)
                sdetweil @iorifly
                @iorifly take the .module prefix off, not needed
                • I Offline
                  iorifly @sdetweil
                  @sdetweil ok
                  • I Offline
                    iorifly @doubleT
                    @doubleT
                    excuse. LOL
                    I did not understand.
                      The content of the custom.css should be:
                          test-align: left;
                          border-spacing: 0;
                      All of it. Not just the last part.
                      • I Offline
                        iorifly
                        test-align: left;
                        border-spacing: 0;
                            test-align: left;
                            border-spacing: 0;
                        • 3 / 5
