    PIR sensor behind glass?
    65 Posts 16 Posters 115.7k Views 19 Watching
    • cowboysdudeC Offline
      That’s another great way to do it! :) Where did you get them from?
      • Y Offline
        yo-less Module Developer @dmcinnes
        @dmcinnes It’s great to hear that they’re working on an external 5v power supply, this means it should be possible to use them on the Pi. It would be really nice if you could try hooking them up to the Pi to see if they’re acting up once attached to the Pi’s pins. I’ll probably try to get one as well if you can confirm they’re working on the Pi as well.
        • Y Offline
          @cowboysdude: You’re welcome :)
          Also, have a look at this post:
          dmcinnes said in PIR sensor behind glass?:
          Another possibility: I ordered a couple of these $2 microwave radar motion detectors to see if they will work behind my glass. Still waiting to receive them though:
          http://m.ebay.com/itm/1pc-5-8GHZ-Microwave-Radar-Sensor-6-9M-Smart-Switch-for-Home-Control-/131864712562?txnId=1245760396003
          More details:
          http://www.cnx-software.com/2016/04/04/tiny-microwave-radar-module-detects-movements-up-to-9-meters-away-for-2/amp/
            dmcinnes Module Developer
            Finally got around to testing on the PI’s 5v power (I’ve busy being sick) and seems to work fine!
            Next I’m going to hook up to the GPIO and see if I can get the whole thing running together.
              Now that I have time I’ve finally set up the microwave sensor on my mirror. Works like a charm!
              The sensor’s data line goes high to 3.3v when it detects motion and stays high for about 30 seconds. It’s set up on one of the 5v outputs. I’ve put some foil around it to help it be a bit more directional since the sensor is so sensitive; I sit under and to the right of my mirror all week and I don’t want it it trigger all the time. It helps somewhat.
                amcolash
                I used some cardboard and then made a little housing for my PIR under the bottom of the mirror. It is a little ugly, but hey this whole project for me was to make something cool (not necessarily beautiful)!
                I did a few layers of cardboard between the sensor and the front to limit the viewing angles and for my needs it is perfect :)
                  Cato Module Developer @dmcinnes
                  @dmcinnes Would you mind share some code? :)
                  D cowboysdudeC 2 Replies Last reply Reply Quote 0
                    dmcinnes Module Developer @Cato
                    @Cato just the regular PIR sensor mirror code works fine! The data pin triggers in the same way as a PIR sensor.
                      cowboysdude Module Developer @Cato
                      @Cato said in PIR sensor behind glass?:
                      https://github.com/cowboysdude/Pir-Sensor
                      N 1 Reply Last reply Reply Quote 1
                        A Former User
                        hmm… some questions if you would not mind.
                        Ive just ordered 2 sensors .
                        I need to know what plugs in to what to feed in to the chips (im guessing the sensors i need? please explain what i am missing… and what connects in to the Raspberry PI.
                        Also note the second i want to have outside the home and set up to a facial recog module, and comand it to open the door via face and voice confirm if possibl.
                        And how this connects to the a
                          amcolash
                          If you want a very simple solution (independent of MM completely), check out this script. This is what I am using, it is a very simple python script that reads the value of a PIR and then selectively turns on / off the monitor. You will need to change things up a bit as I wrote it for a C.H.I.P. but the GPIO library is the same.
                            dmcinnes Module Developer @Guest
                            @wjdw87 cool! The connection is basicly the same as a PIR sensor. It has three wires, ground, vcc, and data which goes high when it senses motion. I plugged it into the PI’s 3.3v, ground and I believe gpio 22 (whichever is the default for the module).
                            Since the wire comes out as a three pin JST I split it into individual header connectors because all the pins are not next to one another on the PI.
                            Hope that helps!
                              rvdgeer
                              Can anyone of you please share a picture of how you’ve connected the microwave sensor to the Pi pins?
                              I know this sounds dumb, but I can’t seem to find out what pin connects to what, as I don’t know what pin is ground and what pins is (data) out…
                              Thanks!
                                cowboysdude Module Developer @amcolash
                                @amcolash said in PIR sensor behind glass?:
                                VERY good choice! Mine also works independent… but I really like your idea!
                                • N Offline
                                  Nususu @cowboysdude
                                  @cowboysdude I recently picked up these microwave sensor modules to use in conjunction with the code you posted for PIR Sensor. I’m pretty new to all this, and I can’t get any function out of the sensor. Do you have some advice on how to troubleshoot this? It could be an error on my part in implementing the code, wiring it incorrectly, or something else, but I’m just not sure how to figure out what the issue is.
                                    cowboysdude Module Developer @Nususu
                                    @Nususu I would go online and lookup ‘wiring pir sensor raspberry pi’ there are TONS of things out there. Your issue could be one of any or a combination of things… I did that using a PIR sensor so I have no idea how it would act with microwave sensors… good I’m hoping because I want to get some… BUT let me know if you need anymore help, not that I helped you now but I will do what I can!
                                      cowboysdude Module Developer @rvdgeer
                                      @rvdgeer and @Nususu
                                      Try here!
                                      https://www.pubnub.com/blog/2015-06-16-building-a-raspberry-pi-motion-sensor-with-realtime-alerts/
                                      • N Offline
                                        Nususu @cowboysdude
                                        @cowboysdude thanks, I’ll check that out and let you know how it goes!
                                        • N Offline
                                          Nususu @cowboysdude
                                          @cowboysdude I got it working using this code:
                                          https://github.com/paviro/MMM-PIR-Sensor
                                          With this code, I’ve got a problem where the screen only stays on for about 1 second after motion detection. Now I need to modify the code somehow to allow me to tell the mirror to stay on for a set amount of time after detecting motion, i.e. only go dark once no motion has been detected for x seconds. Problem is I don’t know where to start with that. Will let you know if I figure anything out. Any ideas?
                                            @Nususu try adding the powerSaving to your config…
                                                    module: 'MMM-PIR-Sensor',
                                                        powerSaving: false
                                            See what that does :) PLUS there’s also an adjustment on your PIR sensor itself… which one and I don’t know … do a google search for adjustments :)
                                            • 3 / 4
