    PIR sensor behind glass?
    65 Posts 16 Posters 111.7k Views 19 Watching
      amcolash
      If you want a very simple solution (independent of MM completely), check out this script. This is what I am using, it is a very simple python script that reads the value of a PIR and then selectively turns on / off the monitor. You will need to change things up a bit as I wrote it for a C.H.I.P. but the GPIO library is the same.
        dmcinnes Module Developer @Guest
        @wjdw87 cool! The connection is basicly the same as a PIR sensor. It has three wires, ground, vcc, and data which goes high when it senses motion. I plugged it into the PI’s 3.3v, ground and I believe gpio 22 (whichever is the default for the module).
        Since the wire comes out as a three pin JST I split it into individual header connectors because all the pins are not next to one another on the PI.
        Hope that helps!
          rvdgeer
          Can anyone of you please share a picture of how you’ve connected the microwave sensor to the Pi pins?
          I know this sounds dumb, but I can’t seem to find out what pin connects to what, as I don’t know what pin is ground and what pins is (data) out…
          Thanks!
          • cowboysdudeC Offline
            cowboysdude Module Developer @amcolash
            @amcolash said in PIR sensor behind glass?:
            VERY good choice! Mine also works independent… but I really like your idea!
            • N Offline
              Nususu @cowboysdude
              @cowboysdude I recently picked up these microwave sensor modules to use in conjunction with the code you posted for PIR Sensor. I’m pretty new to all this, and I can’t get any function out of the sensor. Do you have some advice on how to troubleshoot this? It could be an error on my part in implementing the code, wiring it incorrectly, or something else, but I’m just not sure how to figure out what the issue is.
                cowboysdude Module Developer @Nususu
                @Nususu I would go online and lookup ‘wiring pir sensor raspberry pi’ there are TONS of things out there. Your issue could be one of any or a combination of things… I did that using a PIR sensor so I have no idea how it would act with microwave sensors… good I’m hoping because I want to get some… BUT let me know if you need anymore help, not that I helped you now but I will do what I can!
                  cowboysdude Module Developer @rvdgeer
                  @rvdgeer and @Nususu
                  Try here!
                  https://www.pubnub.com/blog/2015-06-16-building-a-raspberry-pi-motion-sensor-with-realtime-alerts/
                  • N Offline
                    Nususu @cowboysdude
                    @cowboysdude thanks, I’ll check that out and let you know how it goes!
                    • N Offline
                      Nususu @cowboysdude
                      @cowboysdude I got it working using this code:
                      https://github.com/paviro/MMM-PIR-Sensor
                      With this code, I’ve got a problem where the screen only stays on for about 1 second after motion detection. Now I need to modify the code somehow to allow me to tell the mirror to stay on for a set amount of time after detecting motion, i.e. only go dark once no motion has been detected for x seconds. Problem is I don’t know where to start with that. Will let you know if I figure anything out. Any ideas?
                        @Nususu try adding the powerSaving to your config…
                                module: 'MMM-PIR-Sensor',
                                    powerSaving: false
                        See what that does :) PLUS there’s also an adjustment on your PIR sensor itself… which one and I don’t know … do a google search for adjustments :)
                          Aly
                          @Nususu - same here
                          Perhaps, with a resistor?
                          • N Offline
                            Nususu @Aly
                            @Aly I found documentation for the sensor that a resistor would indeed solve the issue here. I can set the delay up to 200 seconds with a 250k resistor, so I ordered one and will report back how it went.
                              Aly
                              @Nususu - great !!
                              Can you post the doc. ?
                              • N Offline
                                Nususu @Aly
                                @Aly I misspoke, shouldn’t have called it documentation. Rather, it was this picture:alt text
                                Which appears to be a translation from the Chinese original picture.
                                A 1 Reply Last reply Reply Quote 1
                                  Aly @Nususu
                                  @Nususu
                                  so if we remove the R6 resistor the delay would be 30s ?
                                  • N Offline
                                    Nususu @Aly
                                    @Aly yes, it would appear so. I just bought a soldering iron and resistors which arrive tomorrow so I’ll perform a couple tests: 1. Remove r6 and verify that it’s 30s. 2. Add 250k resistor and test duration.
                                      Aly @Nususu
                                      @Nususu
                                      Ok - thanks for your help! :)
                                      I can/will test it on coming monday.
                                      • N Offline
                                        Nususu @Aly
                                        @Aly I tested this today - I put a 250k resistor on R6 and it increased the timer to approximately 25 seconds. I forgot to test without a resistor. Let me know if you end up testing that.
                                          PaulB
                                          @Comunnity
                                          If it comes to the thickness of the mirror: Would you either recommend webcams, etc, behind the mirror or as I thought create a CAD-print plan for a 3 D-printer to hide the camera behind a… actually I have no clue how to call it … a “string” of maybe a lamp?
                                          Do you guys have recommendations or Best Practices?
                                          I saw some awesome bathroom project in this forum but no one 3D printed his lamp or LED. My roommate has a 3D printer so I am thinking about to integrated a camera in one part of an LED lamp which is on top of the mirror.
                                          Maybe someone tried this idea before me. Hope there are some Best Practices on how to do it.
                                          As always I would like to thank you for your awesome feedback guys.
                                          Kind regard from Hamburg, Germany,
                                          Paul
                                          • yawnsY Offline
                                            yawns Moderator @PaulB
                                            @paulb
                                            I really like the way this guy mounted the camera on top of the mirror: https://forum.magicmirror.builders/topic/6952/my-mirror-so-great
                                            • 3 / 4
