    Rpi 4 and two monitors
    60 Posts 6 Posters 42.9k Views 6 Watching
    • N
      NathTheDude
      thanks @sdetweil , right you are - I was not running npm from within the MagicMirror directory.
      When I update ‘Display’ to 1 I still get an error when trying to manually run NPM, however when ‘Display’ is set to 0 and then I run NPM there are no errors with it. The error is:
      pi@MagicMirrors:~/MagicMirror $ npm start
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      (electron:11918): Gtk-WARNING **: 22:18:00.088: cannot open display: :1
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.10.1 start script.
      npm ERR!     /home/pi/.npm/_logs/2020-02-04T22_18_00_154Z-debug.log
      @bhepler thanks for the link, it is a bit beyond my understanding at the moment. I will have to read up on it a bit more. I tried to run xrandr to see what kind of status it gives on the monitors but it currently comes back with ‘Can’t open display’, I assume it is because another service/application is utilising them?
      Anyway, thanks for your help.
        sdetweil @NathTheDude
        @NathTheDude said in Rpi 4 and two monitors:
        Yes, we just need to find out what the other Display number is.
        tvservice is wrong cause it reports display 2 for HDMI 0, and we know it’s really Display 0
        • N
          NathTheDude
          @sdetweil , so using ‘0’ or ‘0.0’ give the same result and start MM on the first monitor.
          So far I have tried 1,2,3,4,5,6,7,8,9 and 0.1, 0.2, 0.3, 0.4, 0.5
          How far do I go? :)
          • O
            OldSunGuy @NathTheDude
            @NathTheDude The 2nd monitor should be display 0, screen 1. Use this:
            DISPLAY=:0.1
            • N
              NathTheDude
              Hey @OldSunGuy , thanks. ‘0’ and ‘0.0’ seem to be the first monitor however I get an error when I try anything else. So far I have tried using each of the following: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9
              Each time I try to start npm (npm start) apart from when I use 0 or 0.0 I get the following (with the value reflecting the number I changed in ‘run-start.sh’):
              (electron:2238): Gtk-WARNING **: 06:14:02.236: cannot open display: :0.1
              @sdetweil - not sure if this is relevant but it does not seem to matter what value I set in ‘run-start.sh’, when I reboot the pi it will always start MM on the first screen. Should it not fail if it is using ‘run-start.sh’?
              Also with an incorrect value being added to ‘run-start.sh’, when I run ‘mm.sh’ this always works and displays MM on the first screen.
              okay, I think I understand it now. When I reboot it is using ‘mm.sh’, within mm.sh is the following:
              DISPLAY=:0 npm start
              Which I assume means that the ‘run-start.sh’ is not used during boot up?
              When I change this value to anything other than 0, this will also fail with the same error seen when trying to run npm previously.
              • O
                @NathTheDude If you start a terminal on one desktop and run:
                echo $DISPLAY
                Then start a terminal on the other desktop and run:
                echo $DISPLAY
                do you get the same results?
                • N
                  NathTheDude
                  @OldSunGuy - I get :0.0
                  I wonder if both screens are being seen as 0.0, if that is the case I guess I would expect the MM screen to cover both screens and not just the first :-/
                  • N
                    NathTheDude
                    @OldSunGuy , sorry mis read your comment. Not sure how I would start a terminal on one screen and a different terminal on another.
                      @NathTheDude if they are two independent desktops, then you should have a menu on the second desktop, just like the first…
                      also, you can move the mouse to the second desktop and do ctrl-alt-t to open a terminal there
                      I have an micro hdmi adapter coming later today so I can put up a second physical display on my pi4…
                      • N
                        NathTheDude
                        @sdetweil , I opened up a terminal session on each screen and both indicated the same display was being used (:0).
                        From the ‘Appearance Settings’ window (‘Prefences’ > ‘Apprearance Settings’, there is a ‘Taskbar’ tab and in this tab you select which hdmi output you want the taskbar to be on. You can choose both.
                        S N 2 Replies Last reply Reply Quote 0
                          @NathTheDude so, it looks like one big desktop…
                          u should be using Buster OS, right? so you can see the temples across the big image, some on the right display, some on the left…
                          NOT the same on both?
                          • N
                            NathTheDude @sdetweil
                            @sdetweil , yeah buster.
                            I can see temples on both screens, the image does not flow between screens. When looking at the 'Appearance Settings’, the is a tab for each HMDI with different settings but these are purely for what image is seen on the desktop. You can use the same image on both desktops however this is purely related to the desktop image or so is what I understand of it.
                            • N
                              NathTheDude @NathTheDude
                              Sorry, with my previous comment - I meant to say you ‘CANT’ choose both (taskbar can only be on one screen/output).
                                @NathTheDude there is a firmware update on the pi4… execute
                                sudo rpi-update
                                • N
                                  NathTheDude
                                  @sdetweil , so I did the firmware update and rebooted.
                                  Slightly different now but still can not quite get this to work. When I now run a terminal on screen 1 the output of ‘echo $DISPLAY’ is ‘:0.0’ and when I run the terminal on the 2nd window the output is ‘:0’. However the same is seen when I try to either user ‘0’ or ‘0.0’ in run.sh (mm gets display on the 1st monitor.
                                  I have again tried to use different numbers (1,2,3 and 0.1, 0.2, 0.3) but again, these are not valid entries.
                                    @NathTheDude how about the output of xrandr -q
                                    • N
                                      @sdetweil . I get the following when trying to run different xrandr commands:
                                      Can't open display
                                      • N
                                        NathTheDude
                                        @sdetweil - ahhh. I need to do this from the desktop:
                                        pi@MagicMirrors:~ $ xrandr -q
                                        Screen 0: minimum 320 x 200, current 2160 x 1920, maximum 7680 x 7680
                                        HDMI-1 connected primary 1080x1920+0+0 left (normal left inverted right x axis y axis) 477mm x 268mm
                                           1920x1080     60.00*+  60.00    50.00    59.94
                                           1680x1050     59.88
                                           1280x1024     75.02    60.02
                                           1440x900      59.90
                                           1280x960      60.00
                                           1280x720      60.00    60.00    50.00    59.94
                                           1024x768      75.03    70.07    60.00
                                           832x624       74.55
                                           800x600       72.19    75.00    60.32    56.25
                                           720x576       50.00    50.00    50.00
                                           720x480       60.00    60.00    59.94    59.94    59.94
                                           640x480       75.00    72.81    66.67    60.00    59.94    59.94
                                           720x400       70.08
                                        HDMI-2 connected 1080x1920+1080+0 right (normal left inverted right x axis y axis) 477mm x 268mm
                                           1680x1050     59.88
                                           1440x900      59.90
                                           1280x960      60.00
                                           832x624       74.55
                                           720x400       70.08
                                        pi@MagicMirrors:~ $
                                          @NathTheDude ok, I can see the same results now that I have my adapter…
                                          may have to wait til tomorrow to work on it…
                                          • N
                                            NathTheDude
                                            Hey @sdetweil , no problem at all - no rush indeed. Thank you for your help thus far.
                                            So thanks to this page I have been able to run up two chromiums, one on each page but I have started up chromium directly via terminal from the desktop. Not quite figured out how to implement this as two MM’s and if running up two at once would kill the CPU.
                                            raspberrypi.org forum post
                                            1st terminal session
                                            DISPLAY=:0 /usr/bin/chromium-browser \
                                            --noerrdialogs \
                                            --kiosk \
                                            --window-position=0,0 \
                                            --start-fullscreen \
                                            --user-data-dir=Default
                                            2nd terminal session
                                            --noerrdialogs \
                                            --kiosk \
                                            --window-position=1920,0 \
                                            --user-data-dir=‘Test2’
                                            • 2 / 3
