    Rpi 4 and two monitors
    60 Posts 6 Posters 42.4k Views 6 Watching
      sdetweil @NathTheDude
      @NathTheDude said in Rpi 4 and two monitors:
      When I update ‘Display’ to 1 I still get an error
      Yes, we just need to find out what the other Display number is.
      tvservice is wrong cause it reports display 2 for HDMI 0, and we know it’s really Display 0
      • N
        NathTheDude
        @sdetweil , so using ‘0’ or ‘0.0’ give the same result and start MM on the first monitor.
        So far I have tried 1,2,3,4,5,6,7,8,9 and 0.1, 0.2, 0.3, 0.4, 0.5
        How far do I go? :)
        • O
          OldSunGuy @NathTheDude
          @NathTheDude The 2nd monitor should be display 0, screen 1. Use this:
          DISPLAY=:0.1
          • N
            NathTheDude
            Hey @OldSunGuy , thanks. ‘0’ and ‘0.0’ seem to be the first monitor however I get an error when I try anything else. So far I have tried using each of the following: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9
            Each time I try to start npm (npm start) apart from when I use 0 or 0.0 I get the following (with the value reflecting the number I changed in ‘run-start.sh’):
            (electron:2238): Gtk-WARNING **: 06:14:02.236: cannot open display: :0.1
            @sdetweil - not sure if this is relevant but it does not seem to matter what value I set in ‘run-start.sh’, when I reboot the pi it will always start MM on the first screen. Should it not fail if it is using ‘run-start.sh’?
            Also with an incorrect value being added to ‘run-start.sh’, when I run ‘mm.sh’ this always works and displays MM on the first screen.
            okay, I think I understand it now. When I reboot it is using ‘mm.sh’, within mm.sh is the following:
            DISPLAY=:0 npm start
            Which I assume means that the ‘run-start.sh’ is not used during boot up?
            When I change this value to anything other than 0, this will also fail with the same error seen when trying to run npm previously.
            • O
              @NathTheDude If you start a terminal on one desktop and run:
              echo $DISPLAY
              Then start a terminal on the other desktop and run:
              echo $DISPLAY
              do you get the same results?
              • N
                NathTheDude
                @OldSunGuy - I get :0.0
                I wonder if both screens are being seen as 0.0, if that is the case I guess I would expect the MM screen to cover both screens and not just the first :-/
                • N
                  NathTheDude
                  @OldSunGuy , sorry mis read your comment. Not sure how I would start a terminal on one screen and a different terminal on another.
                    @NathTheDude if they are two independent desktops, then you should have a menu on the second desktop, just like the first…
                    also, you can move the mouse to the second desktop and do ctrl-alt-t to open a terminal there
                    I have an micro hdmi adapter coming later today so I can put up a second physical display on my pi4…
                    • N
                      NathTheDude
                      @sdetweil , I opened up a terminal session on each screen and both indicated the same display was being used (:0).
                      From the ‘Appearance Settings’ window (‘Prefences’ > ‘Apprearance Settings’, there is a ‘Taskbar’ tab and in this tab you select which hdmi output you want the taskbar to be on. You can choose both.
                      S N 2 Replies Last reply Reply Quote 0
                        @NathTheDude so, it looks like one big desktop…
                        u should be using Buster OS, right? so you can see the temples across the big image, some on the right display, some on the left…
                        NOT the same on both?
                        • N
                          NathTheDude @sdetweil
                          @sdetweil , yeah buster.
                          I can see temples on both screens, the image does not flow between screens. When looking at the 'Appearance Settings’, the is a tab for each HMDI with different settings but these are purely for what image is seen on the desktop. You can use the same image on both desktops however this is purely related to the desktop image or so is what I understand of it.
                          • N
                            NathTheDude @NathTheDude
                            Sorry, with my previous comment - I meant to say you ‘CANT’ choose both (taskbar can only be on one screen/output).
                              @NathTheDude there is a firmware update on the pi4… execute
                              sudo rpi-update
                              • N
                                NathTheDude
                                @sdetweil , so I did the firmware update and rebooted.
                                Slightly different now but still can not quite get this to work. When I now run a terminal on screen 1 the output of ‘echo $DISPLAY’ is ‘:0.0’ and when I run the terminal on the 2nd window the output is ‘:0’. However the same is seen when I try to either user ‘0’ or ‘0.0’ in run.sh (mm gets display on the 1st monitor.
                                I have again tried to use different numbers (1,2,3 and 0.1, 0.2, 0.3) but again, these are not valid entries.
                                  @NathTheDude how about the output of xrandr -q
                                  • N
                                    @sdetweil . I get the following when trying to run different xrandr commands:
                                    Can't open display
                                    • N
                                      NathTheDude
                                      @sdetweil - ahhh. I need to do this from the desktop:
                                      pi@MagicMirrors:~ $ xrandr -q
                                      Screen 0: minimum 320 x 200, current 2160 x 1920, maximum 7680 x 7680
                                      HDMI-1 connected primary 1080x1920+0+0 left (normal left inverted right x axis y axis) 477mm x 268mm
                                         1920x1080     60.00*+  60.00    50.00    59.94
                                         1680x1050     59.88
                                         1280x1024     75.02    60.02
                                         1440x900      59.90
                                         1280x960      60.00
                                         1280x720      60.00    60.00    50.00    59.94
                                         1024x768      75.03    70.07    60.00
                                         832x624       74.55
                                         800x600       72.19    75.00    60.32    56.25
                                         720x576       50.00    50.00    50.00
                                         720x480       60.00    60.00    59.94    59.94    59.94
                                         640x480       75.00    72.81    66.67    60.00    59.94    59.94
                                         720x400       70.08
                                      HDMI-2 connected 1080x1920+1080+0 right (normal left inverted right x axis y axis) 477mm x 268mm
                                         1680x1050     59.88
                                         1440x900      59.90
                                         1280x960      60.00
                                         832x624       74.55
                                         720x400       70.08
                                      pi@MagicMirrors:~ $
                                        @NathTheDude ok, I can see the same results now that I have my adapter…
                                        may have to wait til tomorrow to work on it…
                                        • N
                                          NathTheDude
                                          Hey @sdetweil , no problem at all - no rush indeed. Thank you for your help thus far.
                                          So thanks to this page I have been able to run up two chromiums, one on each page but I have started up chromium directly via terminal from the desktop. Not quite figured out how to implement this as two MM’s and if running up two at once would kill the CPU.
                                          raspberrypi.org forum post
                                          1st terminal session
                                          DISPLAY=:0 /usr/bin/chromium-browser \
                                          --noerrdialogs \
                                          --kiosk \
                                          --window-position=0,0 \
                                          --start-fullscreen \
                                          --user-data-dir=Default
                                          2nd terminal session
                                          --noerrdialogs \
                                          --kiosk \
                                          --window-position=1920,0 \
                                          --user-data-dir=‘Test2’
                                            @NathTheDude copy one MM folder tree to MagicMirror1
                                            then change the config on MM1 to use a different port (8081 maybe)
                                            then start both MM in serverOnly mode (u can set that in config.js too, serverOnly: true,
                                            then launch your two browsers, with the url pointing to separate MM’s…
                                            –app=http://localhost:MM_port,
                                            –app=http://localhost:MM1_port
                                            you can edit the run-start.sh on MM1 to add the
                                            parms to the ones already provided
                                            then change both MM configs to serverOnly: “local”,
                                            and it will launch the chrome browser for you
                                            (this is what we call split mode, using a separate browser)
                                            then u can have pm2 start both of those when the system boots…
                                            have to change the mm.sh in MM1/installers, and maybe the json file title to MagicMirror1, and point to the local mm.sh
                                            • 2 / 3
