    Rpi 4 and two monitors
    60 Posts 6 Posters 43.6k Views 6 Watching
      sdetweil @NathTheDude
      @NathTheDude MagicMirror startup in the run-start.sh file sets DISPLAY=:0 for the primary display
      I would guess that the second display is :1
      so, do
      export DISPLAY=:1
      then npm start
      see if it comes up on the second display
      • N
        NathTheDude
        @sdetweil na, no joy. I did try this yesterday also but was not sure I was looking in the right place. For the sake of it I tried using numbers 0 to 9, all with the same result. This for example:
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2020-02-04T21_33_32_894Z-debug.log
        However if I reboot the RPI with run-start having the different value it will still display the MM on the first screen, this made me think that this script was not being used at the startup as I would expect it to fail and not display the MM - perhaps I am wrong.
        S 2 Replies Last reply
        • bheplerB
          bhepler Module Developer
          I wonder if we’re looking in the wrong place? Perhaps it’s how the MM process is calling Electron that determines where on the desktop the app appears.
            @NathTheDude said in Rpi 4 and two monitors:
            npm ERR! errno -2
            you are doing npm start in the root, not in the MagicMirror folder…
              sdetweil @bhepler
              @bhepler that is run-start.sh
              ~/MagicMirror/package.json
                "name": "magicmirror",
                "version": "2.10.1",
                "description": "The open source modular smart mirror platform.",
                "main": "js/electron.js",
                "scripts": {
                  "start": "./run-start.sh",     // < ------   when u do npm start this happens
                @NathTheDude run-start.sh is in the MagicMirror folder
                actually the pm2 only on the 1st screen is understandable
                as the script used by pm2 is installers/mm.sh
                which does
                DISPLAY=:0 npm start
                and run-start does
                # if DISPLAY is not set then set it
                if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                	export DISPLAY=:0 # Set by default display
                fi
                so I would just set export DISPLAY=:0
                and the execute run-start.sh
                • bheplerB
                  I have to head home, so I can’t investigate any more for some time. But I did find this link on StackOverflow that seems to address the issue. Aren’t we using an X11 based desktop manager?
                  Anyway, this may help.
                    sdetweil @bhepler
                    @bhepler correct, that is DISPLAY
                    • N
                      NathTheDude
                      thanks @sdetweil , right you are - I was not running npm from within the MagicMirror directory.
                      When I update ‘Display’ to 1 I still get an error when trying to manually run NPM, however when ‘Display’ is set to 0 and then I run NPM there are no errors with it. The error is:
                      pi@MagicMirrors:~/MagicMirror $ npm start
                      > magicmirror@2.10.1 start /home/pi/MagicMirror
                      > ./run-start.sh
                      (electron:11918): Gtk-WARNING **: 22:18:00.088: cannot open display: :1
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.10.1 start script.
                      npm ERR!     /home/pi/.npm/_logs/2020-02-04T22_18_00_154Z-debug.log
                      @bhepler thanks for the link, it is a bit beyond my understanding at the moment. I will have to read up on it a bit more. I tried to run xrandr to see what kind of status it gives on the monitors but it currently comes back with ‘Can’t open display’, I assume it is because another service/application is utilising them?
                      Anyway, thanks for your help.
                        Yes, we just need to find out what the other Display number is.
                        tvservice is wrong cause it reports display 2 for HDMI 0, and we know it’s really Display 0
                        • N
                          NathTheDude
                          @sdetweil , so using ‘0’ or ‘0.0’ give the same result and start MM on the first monitor.
                          So far I have tried 1,2,3,4,5,6,7,8,9 and 0.1, 0.2, 0.3, 0.4, 0.5
                          How far do I go? :)
                          O 1 Reply Last reply
                          • O
                            OldSunGuy @NathTheDude
                            @NathTheDude The 2nd monitor should be display 0, screen 1. Use this:
                            DISPLAY=:0.1
                            • N
                              NathTheDude
                              Hey @OldSunGuy , thanks. ‘0’ and ‘0.0’ seem to be the first monitor however I get an error when I try anything else. So far I have tried using each of the following: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9
                              Each time I try to start npm (npm start) apart from when I use 0 or 0.0 I get the following (with the value reflecting the number I changed in ‘run-start.sh’):
                              (electron:2238): Gtk-WARNING **: 06:14:02.236: cannot open display: :0.1
                              @sdetweil - not sure if this is relevant but it does not seem to matter what value I set in ‘run-start.sh’, when I reboot the pi it will always start MM on the first screen. Should it not fail if it is using ‘run-start.sh’?
                              Also with an incorrect value being added to ‘run-start.sh’, when I run ‘mm.sh’ this always works and displays MM on the first screen.
                              okay, I think I understand it now. When I reboot it is using ‘mm.sh’, within mm.sh is the following:
                              Which I assume means that the ‘run-start.sh’ is not used during boot up?
                              When I change this value to anything other than 0, this will also fail with the same error seen when trying to run npm previously.
                              • O
                                @NathTheDude If you start a terminal on one desktop and run:
                                echo $DISPLAY
                                Then start a terminal on the other desktop and run:
                                echo $DISPLAY
                                do you get the same results?
                                • N
                                  NathTheDude
                                  @OldSunGuy - I get :0.0
                                  I wonder if both screens are being seen as 0.0, if that is the case I guess I would expect the MM screen to cover both screens and not just the first :-/
                                  • N
                                    NathTheDude
                                    @OldSunGuy , sorry mis read your comment. Not sure how I would start a terminal on one screen and a different terminal on another.
                                      @NathTheDude if they are two independent desktops, then you should have a menu on the second desktop, just like the first…
                                      also, you can move the mouse to the second desktop and do ctrl-alt-t to open a terminal there
                                      I have an micro hdmi adapter coming later today so I can put up a second physical display on my pi4…
                                      • N
                                        NathTheDude
                                        @sdetweil , I opened up a terminal session on each screen and both indicated the same display was being used (:0).
                                        From the ‘Appearance Settings’ window (‘Prefences’ > ‘Apprearance Settings’, there is a ‘Taskbar’ tab and in this tab you select which hdmi output you want the taskbar to be on. You can choose both.
                                        S N 2 Replies Last reply
                                          @NathTheDude so, it looks like one big desktop…
                                          u should be using Buster OS, right? so you can see the temples across the big image, some on the right display, some on the left…
                                          NOT the same on both?
                                          N 1 Reply Last reply
                                          • N
                                            NathTheDude @sdetweil
                                            @sdetweil , yeah buster.
                                            I can see temples on both screens, the image does not flow between screens. When looking at the 'Appearance Settings’, the is a tab for each HMDI with different settings but these are purely for what image is seen on the desktop. You can use the same image on both desktops however this is purely related to the desktop image or so is what I understand of it.
                                            • 2 / 3
