    MMM-awesome-alexa
    241 Posts 43 Posters 452.9k Views 47 Watching
    • QuberchQ
      Quberch
      First I’ve to say awesome work @dolanmiu ! I’ve installed as described in your documentation. For auto start I’m still using PM2 with the mm.sh script and can’t get the wake word to trigger. ALSA ist configured and recording. Any ideas what could be the problem? Do I have to get rid completely of PM2? Many thanks in advance for your help!
        Cordetx
        Can you please add the wake word “Mirror Mirror On The Wall”?
        B 1 Reply Last reply
          berne @Cordetx
          what mic are people using, i have this: USB MIC
          but cant get it to work so looking for a new one
            menanr @Canterrain
            @Canterrain said in MMM-awesome-alexa:
            @Cr4z33
            Well dang. I’m doing something wrong here. Whether I use the helper config or the tool above, I get a broken error page.
            And I know an error page is expected, but it’s not a long url with a code in it.
            It’s like… amazon.com/wpa
            and that’s it.
            Was the right choice “device with alexa built in” and “no companion app” ? I figure I must have done something wrong on the Amazon developer page, since that’s the part with no guide and it’s working for other people.
            Hey
            did you get it working. I am stuck at the same spot.
            P 1 Reply Last reply
              prpun311 @berne
              @berne No, its just telling you what the amazon site is doing, you only need the top portion.
                prpun311 @menanr
                @menanr try this out,
                https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                • Blackhawk50000B
                  Blackhawk50000
                  I would LOVE to get this work… i have done everything that is written in the guide:
                  2nd hand guide
                  and of course in your normal regular guide…
                  i have testet my microphone and my speaker… everything is okay. but when i set up the config and a try tu say something… NOTHING works.
                  even with wireshark i dont see, that everything is trying to do something.
                  • Blackhawk50000B
                    Blackhawk50000
                    Okay, little Update, why i think the module dont work.
                    I saw that the part:
                    rm -rf node_modules
                    npm install nan --save
                    npm install node-pre-gyp@0.12.0 --save
                    npm install
                    npm run prepublish
                    throws some erros:
                    Found 2 errors.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 2
                    npm ERR! snowboy@1.3.1 prepublish: `tsc --listFiles`
                    npm ERR! Exit status 2
                    npm ERR!
                    npm ERR! Failed at the snowboy@1.3.1 prepublish script.
                    npm ERR!     /home/pi/.npm/_logs/2019-09-11T20_53_08_308Z-debug.log
                    after a bit googeling i found this: https://www.gitmemory.com/issue/eouia/MMM-Hotword/65/507582634
                    so i editet the package.json and set up the typescript version ti 3.5.2 and gor this errors by npm run prepublish:
                    > snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
                    > tsc --listFiles
                    node_modules/@types/node/index.d.ts:43:11 - error TS2300: Duplicate identifier 'IteratorResult'.
                    43 interface IteratorResult<T> { }
                      node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6
                        41 type IteratorResult<T, TReturn = any> = IteratorYieldResult<T> | IteratorReturnResult<TReturn>;
                        'IteratorResult' was also declared here.
                    node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6 - error TS2300: Duplicate identifier 'IteratorResult'.
                    i think this is a current problem, that snowboy is not correct installed… can anyone confiorm this?
                    • H
                      HabibA
                      • H
                        HabibA
                        I solved my problems with that now.
                        https://github.com/dolanmiu/MMM-awesome-alexa/issues/184#issuecomment-584215826
                        • V
                          vlatko_jordanov
                          Hi @dolanmiu awesome job with the Alexa I must say!!
                          I have set it up however I think it’s behaving weird or I am missing some bits and pieces to make it work! I’ve added MMM-NowPlayingOnSpotify and google calendar however when I try to ask Alexa to add event on the calendar or to play Spotify it has no idea, what am I missing here, please let me know what logs I can provide to troubleshoot!
                          Cheers,
                          Vlatko
                            sdetweil @vlatko_jordanov
                            @vlatko_jordanov said in MMM-awesome-alexa:
                            this module shows what is playing somewhere else.
                            I don’t think alexa can start playing anywhere, i stand corrected
                            https://www.spotify.com/us/amazonalexa/
                            now to make spotify play ON the PI
                            https://www.raspberrypi.org/forums/viewtopic.php?t=215857
                            how to integrate those, I don’t know.
                            calendar
                            can alexa add to your google calendar? it doesn’t know anything about what is on the mirror,
                            and the cal on the mirror is a download from some other location(google, apple…) . (ie , its read only)
                            https://www.techradar.com/how-to/how-to-connect-your-google-calendar-to-amazon-echo
                            V 1 Reply Last reply
                            • V
                              vlatko_jordanov @sdetweil
                              Hey Sam!
                              Thanks for coming coming back on this! Well I must say I was thinking the same that it could be due to something like that and the name of the Spotify module says it all doesn’t it :)
                              I was tricked by this video on youtube: https://www.youtube.com/watch?v=q7wqm8h3PnA
                              He didn’t mentioned anywhere how he controls Spotify, so I assumed Alexa somehow knew how to reach spotify and the module just to display the now playing.
                              So I need client is what you say right?
                              And about the calendar I already gave alexa rights through the Alexa app on my android phone but the funny thing is that when I go to devices it says that it’s offline?
                              Cheers,
                              Vlatko
                                here is how to control potify with alexa, https://www.spotify.com/us/amazonalexa/, unrelated to mirror
                                So I need client is what you say right? if u want to PLAY on mirror system yes,
                                rights to what? again, the local ‘calendar’ is a read only copy of a cal somewhere else…
                                maybe on google?
                                offline? that is between alexa account(cloud) and google (cloud)
                                has nothing to do with mirror app
                                I rechecked and resynched my google calendar with my alexa account…
                                and then using my echo asked alexa to add an event to my calendar and it worked and shows on the mirror calendar display…
                                  @vlatko_jordanov I am trying to set this up but my brain cannot figure out what I am supposed to put in as the return url in the AVS setup…
                                  my device is not known outside my home.
                                  i can use my public url redirect to make it known
                                  localhost doesn’t work
                                  my public return url DOES get a callback into my browser, but there is no ‘web page’ served at that url… so it ‘times out’…
                                  the setup app doesn’t use request to MAKE a web server there… (I have had to do this on other oauth apps…)
                                  edit: DOAH… read the instructions!!! lol… it is EPEXCTED to FAIL to connect… read the text from the failing url
                                  got that… BUT then next step fails for me…
                                   Enter your Authorization code (from previous step): ANMJShcLPpSKjJkKLbzj
                                    ◡ Getting response from Amazon...(node:2772) UnhandledPromiseRejectionWarning: StatusCodeError: 400 - {"error_description":"The request has an invalid grant parameter : code","error":"invalid_grant"}
                                  V B 2 Replies Last reply
                                  • V
                                    Hi Sam,
                                    Alright that’s cool I think I’ve put my question wrong, is it possible to have the mmm-awesome-alexa (standalone app) linked with alexa(cloud) without owning any amazon echo dot in my household i.e. the rapsi to be my first and only device with the awesome-alexa module? :)
                                    I did heard that from a friend that his echo dot couldn’t be seen from the WAN side but he could still drop in and announce messages to it which I believe is using different callback settings/ports than the actual device communication, haven’t gone into details as yourself but that’s good to know :)
                                    Thanks,
                                    Vlatko
                                      @vlatko_jordanov sorry. I do not know if u can have mirror BE a full function Alexa node. It seems that should be possible, as I have an automobile Alexa.
                                      Now, can this module do all that?
                                      Don’t know
                                      • V
                                        Cheers Sam,
                                        I hope someone else could provide me that answer here as I am really confused to how this guy has full control over his calendar, spotify etc. via the alexa module on the mirror! Feeling helpless here as my mirror won’t even appear in my alexa app(cloud) as a device (well I did tried something but it says offline as described previously) :)
                                        Reference: https://www.youtube.com/channel/UC1HROb1JCteiftaWwq7Hhhg/videos
                                        Thanks,
                                        Vlatko
                                          @vlatko_jordanov yeh, I went thru his videos, and I don’t see the actual alexa setup ON the mirror…
                                          I have sent him a message…
                                            I can’t get the alexa module to do much… (on pi4)
                                            I have to say ‘Alexa’ then the black circle appears… but no voice reco
                                            I have to say ‘Alexa’ again, then the black circle goes to white, and SOME things are recognized.
                                            it looks like the module does not support conversational mode (add an event, sure, what date and time, xxx yyy, what do you want to call it, some test, ok adding some test at xxx on yyy)
                                            the main guts of the module haven’t been updated in 2 years… and they are minified, which makes debugging them almost impossible…
                                            • 12
                                            • 13
                                            • 5 / 13
