    no result from mvgmunich modul
    12 Posts 4 Posters 5.7k Views 4 Watching
      sdetweil @Babene1
      @Babene1 open the developers window, using the keyboard, ctrl-shift-i, select the tab labeled ‘console’ and then scroll up… to find any errors (usually red text)
      you can also filter to messages from a single module, by putting some part of its unique name into the file labeled ‘filter’, like mvgm
      let us know what u find
      if you use pm2 to manage the mirror runtime, you might also look at the logs, by doing
      pm2 logs
        Babene1 Project Sponsor
        i install MM on an Windows PC to debug,
        i start magic in node servonly
        start browser + debug console
        here is the result off debug
          sdetweil @Babene1
          @Babene1 it says it can’t find the fonts needed…
          “After the last update, the module no longer displays a result.”
          what update? MagicMirror?
          did u also add MMM-GoogleMapsTraffic? it has a bug, you can get an updated version from my repo
          https://github.com/sdetweil/MMM-GoogleMapsTraffic
          • thedoorsfanaticT Offline
            thedoorsfanatic @Babene1
            @Babene1
            Bei mir kommt die Meldung: “Der Name der Haltestelle ist nicht korrekt, bitte überprüfen sie auf MVG”.
            Vielleicht sollten wir ein Issue erstellen. Der Autor des Moduls hat bei mir schon mal darauf reagiert.
            My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
              andyyy
              Did anyone find a solution? I have the same problem. When I remove the MMM-GoogleMapsTraffic from the config.js the issue presists. First it is displaying “undefind” and then nothing at all.
              P.S.: I reverted to the previous version of mvgmunich (sd card backup) which works again, but it has some dupicate stations entries. But this issues was from the beginning.
              thedoorsfanaticT 1 Reply Last reply Reply Quote 1
                thedoorsfanatic @andyyy
                @andyyy
                I switched back to the old version and that works for me, too
                  andyyy @thedoorsfanatic
                  @thedoorsfanatic
                  That is a workaround for now. I wondering if this is a sole module issue or a config issue/problem with the MM or OS itself. Sooner or later we need update mvgmunich module though.
                    @andyyy
                    Ok, I got it working again. Since I am a beginner this might be a little bit unusual but that’s what I did:
                    1.) in my modules folder I renamed the existing folder to “mvgmunich_alt”
                    2.) then I did a new install as described here in step 1 and step 2: https://github.com/mrVragec/MMM-mvgmunich
                    3.) I skipped step 3 but I copied the whole configuration block from step 4 to my config.js
                    4.) Then I put in my information like haltestelle, etc. and it worked again
                    5.) I discovered that the ignoreStations part did not work but after putting in the name exactly like stated in https://www.mvg.de/dienste/abfahrtszeiten.html, for example “Moosach Bf. U S” everything was like before.
                    Hope that helps!
                      andyyy
                      @thedoorsfanatic
                      This approach doesn’t work for me. Now I have both versions installed. Running the old version from the config.js it works as aspected but if I change the directory to the latest version of the module doesn’t load the table/stations. I have no clue what to do next.
                        I found the solution, it’s not a bug, it’s a new feature :-)
                        It is undocumented feature, some missing parts in configuration.
                        Now you able to filter some line unfortunately the filter is by default active. switch off the filter now it works.
                        lineFiltering: {
                        					"active": false,
                        					"filterType": "whitelist",
                        					"lineNumbers": ["U1, U3, X50"]
                        With this config it should be worked :
                        			module: 'mvgmunich',
                        			position: 'top_right',
                        			header: 'MVG',
                        				haltestelle: 'Vaterstetten',
                        				maxEntries: 4,
                        				updateInterval: 60000,
                        				showIcons: true,
                        				transportTypesToShow: {
                        					"ubahn": false,
                        					"sbahn": true,
                        					"bus": false,
                        					"regional_bus": false,
                        					"tram": false
                        				lineFiltering: {
                        					"active": false,
                        				ignoreStations: [],
                        				timeToWalk: 0,
                        				showWalkingTime: false,
                        				showTrainDepartureTime: true,
                        				trainDepartureTimeFormat: "relative",
                        				walkingTimeFormat: "relative",
                        				showInterruptions: true,
                            			showInterruptionsDetails: true,
                            			countInterruptionsAsItemShown: true,
                          andyyy
                          Good catch and thank you very much. That solved my issue too (at the moment at least). I knew that feature were introduced with the last update, but it is a bit strange to have this enabled by default.
