    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      A Former User @JRB1988
      @JRB1988
      I cannot represent your symptom, Mine works well. So I should get your config and real ical url to diagnose.
        cskenney
        @JRB1988 I can confirm that 7 calendars works fine. I wonder if you have a syntax issue on the last one in your list. You should be able to look at the log window and see each of the calendars being read and the number of entries that are selected.
          mscrawford5 @JRB1988
          @JRB1988
          Did you happen to figure out why MMM-Todoist was causing the green underline on calendars ? I’m having the same problem and can’t seem to find a solution.
          Thank you in advance
          ? 1 Reply Last reply
            A Former User @mscrawford5
            @mscrawford5
            add this into your css/custom.css
            .today {
              text-decoration: inherit;
            .tomorrow {
            .MMM-Todoist .today {
              text-decoration: underline #03a05c;
            .MMM-Todoist .tomorrow {
              text-decoration: underline #166cec;
            Not tested, but you can catch the idea.
            M 1 Reply Last reply
            • E
              EdO @Thekk
              @Thekk Thanks for this, just implemented it and it work like a charm. Took me a while to find node_helper.js until I did a find on it and found it in the MMM-CalendarExt2 folder (as well as everywhere else). I’m still a noob with the RPI so not all things are obvious.
              It took me no time at all to find the place to make the change and then I added the filter to the upcoming view while leaving the monthly view alone; exactly what I wanted! Thanks again.
              Now just need to make sure that this gets incorporated into the next module.
                mscrawford5 @Guest
                @Sean
                That worked.Thank you for your help!
                  A Former User @Thekk
                  @Thekk
                  Thanks. I haven’t thought about that method. Now I updated that part in the module.
                  T 1 Reply Last reply
                  • E
                    EdO
                    Experiencing a new problem. I have MMM-CalendarExt2 configured with two calendars and two views. I have one view that shows upcoming events, top_left, looking out in the next 90 days (we don’t have a lot of events at the moment) and a second view that is monthly fullscreen. Both calendars are listed in both views and have css entries to color code which calendar the event comes from.
                    When MM first starts up, only the first calendar appears in each view; however, when MMM-CalendarExt2 refreshes, both calendar events appear and are properly color coded. This doesn’t change unless I restart MM and then the process repeats.
                    Both calendars are defined exactly the same way.
                    Since the events in the second calendar eventually appear, I’ve ruled out potential errors in the config file.
                      A Former User @EdO
                      @EdO
                      try to set “firstDrawingDelay” to 1000 or 2000 something, or shorten ‘updateInterval’ or ‘rotateInterval’.
                      The reason would be; all your events are not loaded or parsed yet on its first drawing cycle, so only some of them will be displayed at that time. Remains will be parsed and displayed on next cycle when prepared.
                      E 1 Reply Last reply
                      • E
                        EdO @Guest
                        @Sean
                        Thanks for getting back to me so fast.
                        Ok firstDrawingDelay and rotateInterval are both at default values while updateInterval is set to 300000.
                        I’ll first try setting rotateInterval to 1000 to match firstDrawingDelay to see if that fixes the problem. If that doesn’t work, I’ll experiment until I find something that does.
                          A Former User @EdO
                          @EdO
                          if you are using only one scene or you don’t mind change of event applied instantly,
                          you don’t need to keep interval so shortly. I think 1 -2 sec for firstDrawDelay would be enough.
                          • BKeyportB
                            BKeyport Module Developer
                            @Sean - been thinking about changing up my calendar a bit, and was wanting to see if this is possible. I want the majority of my screen to be a monthly calendar (the entire month), but not show individual events on a particular agenda/calendar (“Appointments”), rather show the number of events each day. For other agendas/calendars, I want items to show. Example using a downloaded monthly calendar template (18th, 19th, and 20th is typed in like I want)
                            Example
                            Then, I’d like a separate view, using only today’s events. I currently use the “daily” view, but I’d like to restrict it to “Today”.
                            Is this possible?
                              A Former User @BKeyport
                              @BKeyport
                              you just want to show only event.of today? use “daily” with “slotCount:1”.
                              • T
                                Thekk @Guest
                                @Sean said in MMM-CalendarExt2:
                                @Thekk
                                Excellent! Thanks for integrating the recurring filter.
                                • T
                                  Turtle
                                  Hello @Sean,
                                  I just came upon your MMM-CalendarExt2 in the last few days. I think it will do what I need it to do for me. Awesome job! But before I dive in, I like to get myself familiar with it. After reading all the posts in this thread, you keep mentioning about adding “style codes” into the css/custom.css file. By any chance, this been renamed to “main.css”? This is the only css file I have in the “MagicMirror/css/” folder.
                                  C 1 Reply Last reply
                                    cskenney @Turtle
                                    @Turtle In the CSS folder you should also have a custom.css file (in addition to the main.css file) that was created when you installed MagicMirror.
                                    • T
                                      Turtle @cskenney
                                      @cskenney said in MMM-CalendarExt2:
                                      @cskenney - I do not have a custom.css file. Only have the main.css file. Why I’m so confused right now.
                                        A Former User @Turtle
                                        @Turtle
                                        I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css. Just create empty text file and name it as custom.css then save it to your css directory.
                                        T S 2 Replies Last reply
                                        • T
                                          Turtle @Guest
                                          @Turtle
                                          @Sean - I thought I could do that but wanted to make sure but before I did that though I was able to find another css file called “MMM-CalendarExt2” in another folder and made some changes to that file which seems to be working. Of course, I made a backup of it just in case but for some reason, that file is acting like custom.css.
                                          C ? 2 Replies Last reply
                                            cskenney @Turtle
                                            @Turtle said in MMM-CalendarExt2:
                                            @Turtle
                                            Custom.css is the only file that doesn’t get over written when you update MM or Calendar-Ext2. That is why it exists. If you modify main.css then a MM update will wipe out the changes. Same thing is true of CalendarExt2.css.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 24
                                            • 25
                                            • 14 / 25
