    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      A Former User @EdO
      @EdO
      if you are using only one scene or you don’t mind change of event applied instantly,
      you don’t need to keep interval so shortly. I think 1 -2 sec for firstDrawDelay would be enough.
      • BKeyportB
        BKeyport Module Developer
        @Sean - been thinking about changing up my calendar a bit, and was wanting to see if this is possible. I want the majority of my screen to be a monthly calendar (the entire month), but not show individual events on a particular agenda/calendar (“Appointments”), rather show the number of events each day. For other agendas/calendars, I want items to show. Example using a downloaded monthly calendar template (18th, 19th, and 20th is typed in like I want)
        Example
        Then, I’d like a separate view, using only today’s events. I currently use the “daily” view, but I’d like to restrict it to “Today”.
        Is this possible?
        ? 1 Reply Last reply
          A Former User @BKeyport
          @BKeyport
          you just want to show only event.of today? use “daily” with “slotCount:1”.
          • T
            Thekk @Guest
            @Sean said in MMM-CalendarExt2:
            @Thekk
            Thanks. I haven’t thought about that method. Now I updated that part in the module.
            Excellent! Thanks for integrating the recurring filter.
            • T
              Turtle
              Hello @Sean,
              I just came upon your MMM-CalendarExt2 in the last few days. I think it will do what I need it to do for me. Awesome job! But before I dive in, I like to get myself familiar with it. After reading all the posts in this thread, you keep mentioning about adding “style codes” into the css/custom.css file. By any chance, this been renamed to “main.css”? This is the only css file I have in the “MagicMirror/css/” folder.
              C 1 Reply Last reply
                cskenney @Turtle
                @Turtle In the CSS folder you should also have a custom.css file (in addition to the main.css file) that was created when you installed MagicMirror.
                T 1 Reply Last reply
                • T
                  Turtle @cskenney
                  @cskenney said in MMM-CalendarExt2:
                  @cskenney - I do not have a custom.css file. Only have the main.css file. Why I’m so confused right now.
                    A Former User @Turtle
                    @Turtle
                    I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css. Just create empty text file and name it as custom.css then save it to your css directory.
                    T S 2 Replies Last reply
                    • T
                      Turtle @Guest
                      @Turtle
                      @Sean - I thought I could do that but wanted to make sure but before I did that though I was able to find another css file called “MMM-CalendarExt2” in another folder and made some changes to that file which seems to be working. Of course, I made a backup of it just in case but for some reason, that file is acting like custom.css.
                      C ? 2 Replies Last reply
                        cskenney @Turtle
                        @Turtle said in MMM-CalendarExt2:
                        @Turtle
                        Custom.css is the only file that doesn’t get over written when you update MM or Calendar-Ext2. That is why it exists. If you modify main.css then a MM update will wipe out the changes. Same thing is true of CalendarExt2.css.
                          @Turtle
                          To agree @cskenney
                          When I update MMM-CalendarExt2.css on next version, your change will be lost. Use css/custom.css.
                            sdetweil @Guest
                            because we removed it from the git repo, to avoid over-writing it on updates… can’t have it both ways…
                              A Former User @sdetweil
                              In that case, .gitIgnore couldn’t help?
                                sdetweil @Guest
                                @Sean they decided to remove it…
                                BKeyportB 1 Reply Last reply
                                • BKeyportB
                                  @sdetweil so custom.css.sample like the config?
                                    sdetweil @BKeyport
                                    @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
                                    • BKeyportB
                                      true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
                                      • T
                                        Turtle
                                        all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
                                        • T
                                          Turtle
                                          So, all day yesterday, I had everything working with just one calendar and the MM working find. Today, I tried adding three other calendar to the code and now I’m getting a screen that’s telling me the “Must create a config file”. I must have done some syntax wrong that I’m just not seeing. Anyone show me what I’m doing wrong? I removed my url links. Here is my whole config file code…
                                          c/* Magic Mirror Config Sample
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "en",
                                          	timeFormat: 12,
                                          	units: "metrics",
                                          			     // false, default for all  NON-armv6l devices
                                          			module: "alert",
                                          			module: "updatenotification",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			position: "top_right"
                                            			module: 'MMM-CalendarExt2',
                                              				calendars : [
                                          					name: "Turtle's Calendar"
                                          					url: "",
                                          					name: "Work Calendar"
                                          					url: "",
                                          					name: "Bill Calendar"
                                          					url: "",
                                          					name: "Payday Calendar"
                                          					url: "",
                                              				views: [
                                                  					mode: "weekly",
                                              				scenes: [
                                            sdetweil @Turtle
                                            @Turtle after each name: line needs to end with a comma ,
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
