    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      sdetweil @BKeyport
      @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
      • BKeyportB
        BKeyport Module Developer
        true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
        • T
          Turtle
          all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
          • T
            Turtle
            So, all day yesterday, I had everything working with just one calendar and the MM working find. Today, I tried adding three other calendar to the code and now I’m getting a screen that’s telling me the “Must create a config file”. I must have done some syntax wrong that I’m just not seeing. Anyone show me what I’m doing wrong? I removed my url links. Here is my whole config file code…
            c/* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 12,
            	units: "metrics",
            			     // false, default for all  NON-armv6l devices
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_right"
              			module: 'MMM-CalendarExt2',
                				calendars : [
            					name: "Turtle's Calendar"
            					url: "",
            					name: "Work Calendar"
            					url: "",
            					name: "Bill Calendar"
            					url: "",
            					name: "Payday Calendar"
            					url: "",
                				views: [
                    					mode: "weekly",
                				scenes: [
              sdetweil @Turtle
              @Turtle after each name: line needs to end with a comma ,
              • T
                Turtle @sdetweil
                @sdetweil said in MMM-CalendarExt2:
                @sdetweil - after putting the post up there, I saw that and added them. Also, added quotes around module name “MMM-CalendarExt2”.
                But I’m still getting the same message.
                • T
                  Turtle
                  @sdetweil - wait a minute…do you mean after the name as in “Turtle’s Calendar”? I have them after each of the URL.
                  • T
                    Turtle
                    @sdetweil - thank you again…I got it up and working. Just got to do some tweaking!
                      sdetweil @Turtle
                      @Turtle yes.
                      One thing to think about, as u encounter errors, is … What did I do last?
                      • BKeyportB
                        @sdetweil and “config check is cool” 😏
                          sdetweil @BKeyport
                          @BKeyport once u know how to read it!
                          • T
                            Turtle
                            I’m confusing myself with all these examples I’m looking out from the main documentation to other people’s examples. When MM starts, I get the monthly calendar the entire screen but with none of my information from any of the four calendars that I have. Also, I do get the “Upcoming” view in the top_left hand corner with only my information from “Turtle’s Calendar” but not the other calendar. Here is my code…
                                				calendars : [
                            					name: "Turtle's Calendar",
                            					url: "",
                            					name: "Work Calendar",
                            					url: "",
                            					name: "Bill Calendar",
                            					url: "",
                            					name: "Payday Calendar",
                            					url: "",
                                				views: [
                            						mode: "month",
                            						position: "bottom_bar",
                            						calendars: ["Turtle's Calendar", "Work Calendar", "Bill Calendar", "Payday Calendar"],
                            						mode: "upcoming",
                            						Title: "Upcoming Events",
                            						slotCount: 10,
                            						hideOverflow: false,
                            						filterPassedEvent: true,
                                				scenes: [
                            						views: ["MONTHVIEW", "DAILYVIEW"],
                              A Former User @Turtle
                              @Turtle
                              I suspect maxItems of each view, but not confirm the reason without real ical data. send me your ical’s URL to inspect what happens. (eouia0819@gmail.com)
                              • T
                                Turtle @Guest
                                @Sean said in MMM-CalendarExt2:
                                @Turtle
                                @Sean - it was sent. Thank you!
                                  @Turtle
                                  Result of Inspection.
                                  It seems
                                  • Turtle’s Calendar - Personal Public calendars
                                  • Other 3 Calendars - Has only access allowed to Your G Suite Group.
                                  In this case; the other 3 Calendars’ ical addresses will not be accessible from externs.
                                  For example; Open the browser and put the URL of your “Work calendar” in the address form. It will show 404 error
                                  In your Google Calendar settings, you can see warns.
                                  Warning: The address won’t work unless this calendar is public.
                                  • T
                                    Turtle
                                    This weekend I’m going to be working some more on the MM especially the CSS to get the calendars the way I want. So, I’m going to be making the “custom.css” file. Which of the current “.css” file am I going to us to fill the “custom.css” file? Also, on the next updating of MM am I going to lose the “custom.css” file?
                                    Turtle
                                      sdetweil @Turtle
                                      @Turtle no. Custom.css is no longer tracked, so u won’t lose it. The updater script also saves it.
                                      Custom.css starts out empty, so u add whatever u need.
                                      • BKeyportB
                                        BKeyport Module Developer @Turtle
                                        @Turtle find what you want to modify in the existing css files, then copy them over to custom.css - example:
                                        /* Bottom Bar Adjustments */
                                        .region.bottom.bar {
                                        	background-color:rgba(0,0,0,.90);
                                        /* Left adjustments */
                                        .region.left {
                                        	text-align: center;
                                        • T
                                          Turtle
                                          Thank you @sdetweil and @BKeyport for the information.
                                          • BKeyportB
                                            @Sean Is there a way to center the title for “daily” view? Normally, I’d just use .css for the region, but that doesn’t work with your module.
                                            Thanks!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
