    MMM-CalendarExt2
    486 Posts 83 Posters 1.0m Views 83 Watching
    • T Offline
      Turtle @cskenney
      @cskenney said in MMM-CalendarExt2:
      @Turtle In the CSS folder you should also have a custom.css file (in addition to the main.css file) that was created when you installed MagicMirror.
      @cskenney - I do not have a custom.css file. Only have the main.css file. Why I’m so confused right now.
        A Former User @Turtle
        @Turtle
        I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css. Just create empty text file and name it as custom.css then save it to your css directory.
        T S 2 Replies Last reply Reply Quote 0
        • T Offline
          Turtle @Guest
          @Sean said in MMM-CalendarExt2:
          @Turtle
          @Sean - I thought I could do that but wanted to make sure but before I did that though I was able to find another css file called “MMM-CalendarExt2” in another folder and made some changes to that file which seems to be working. Of course, I made a backup of it just in case but for some reason, that file is acting like custom.css.
          C ? 2 Replies Last reply Reply Quote 0
            cskenney @Turtle
            @Turtle said in MMM-CalendarExt2:
            @Turtle
            Custom.css is the only file that doesn’t get over written when you update MM or Calendar-Ext2. That is why it exists. If you modify main.css then a MM update will wipe out the changes. Same thing is true of CalendarExt2.css.
              @Turtle
              To agree @cskenney
              When I update MMM-CalendarExt2.css on next version, your change will be lost. Use css/custom.css.
                sdetweil @Guest
                because we removed it from the git repo, to avoid over-writing it on updates… can’t have it both ways…
                  A Former User @sdetweil
                  In that case, .gitIgnore couldn’t help?
                    sdetweil @Guest
                    @Sean they decided to remove it…
                    • BKeyportB Offline
                      @sdetweil so custom.css.sample like the config?
                        sdetweil @BKeyport
                        @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
                        • BKeyportB Offline
                          true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
                          • T Offline
                            Turtle
                            all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
                            • T Offline
                              Turtle
                              So, all day yesterday, I had everything working with just one calendar and the MM working find. Today, I tried adding three other calendar to the code and now I’m getting a screen that’s telling me the “Must create a config file”. I must have done some syntax wrong that I’m just not seeing. Anyone show me what I’m doing wrong? I removed my url links. Here is my whole config file code…
                              c/* Magic Mirror Config Sample
                               * MIT Licensed.
                              var config = {
                              	port: 8080,
                              	language: "en",
                              	timeFormat: 12,
                              	units: "metrics",
                              			     // false, default for all  NON-armv6l devices
                              			module: "alert",
                              			module: "updatenotification",
                              			position: "top_bar"
                              			module: "clock",
                              			position: "top_right"
                                			module: 'MMM-CalendarExt2',
                                  				calendars : [
                              					name: "Turtle's Calendar"
                              					url: "",
                              					name: "Work Calendar"
                              					url: "",
                              					name: "Bill Calendar"
                              					url: "",
                              					name: "Payday Calendar"
                              					url: "",
                                  				views: [
                                      					mode: "weekly",
                                  				scenes: [
                                sdetweil @Turtle
                                @Turtle after each name: line needs to end with a comma ,
                                • T Offline
                                  Turtle @sdetweil
                                  @sdetweil said in MMM-CalendarExt2:
                                  @sdetweil - after putting the post up there, I saw that and added them. Also, added quotes around module name “MMM-CalendarExt2”.
                                  But I’m still getting the same message.
                                  • T Offline
                                    Turtle
                                    @sdetweil - wait a minute…do you mean after the name as in “Turtle’s Calendar”? I have them after each of the URL.
                                    • T Offline
                                      Turtle
                                      @sdetweil - thank you again…I got it up and working. Just got to do some tweaking!
                                        sdetweil @Turtle
                                        @Turtle yes.
                                        One thing to think about, as u encounter errors, is … What did I do last?
                                        • BKeyportB Offline
                                          @sdetweil and “config check is cool” 😏
                                            sdetweil @BKeyport
                                            @BKeyport once u know how to read it!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
