    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • T
      Turtle @Guest
      @Sean said in MMM-CalendarExt2:
      @Turtle
      I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css. Just create empty text file and name it as custom.css then save it to your css directory.
      @Sean - I thought I could do that but wanted to make sure but before I did that though I was able to find another css file called “MMM-CalendarExt2” in another folder and made some changes to that file which seems to be working. Of course, I made a backup of it just in case but for some reason, that file is acting like custom.css.
      C ? 2 Replies Last reply Reply Quote 0
        cskenney @Turtle
        @Turtle said in MMM-CalendarExt2:
        @Turtle
        Custom.css is the only file that doesn’t get over written when you update MM or Calendar-Ext2. That is why it exists. If you modify main.css then a MM update will wipe out the changes. Same thing is true of CalendarExt2.css.
          A Former User @Turtle
          @Turtle
          To agree @cskenney
          When I update MMM-CalendarExt2.css on next version, your change will be lost. Use css/custom.css.
            sdetweil @Guest
            because we removed it from the git repo, to avoid over-writing it on updates… can’t have it both ways…
              A Former User @sdetweil
              In that case, .gitIgnore couldn’t help?
                sdetweil @Guest
                @Sean they decided to remove it…
                • BKeyportB
                  @sdetweil so custom.css.sample like the config?
                    sdetweil @BKeyport
                    @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
                    • BKeyportB
                      true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
                      • T
                        Turtle
                        all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
                        • T
                          Turtle
                          So, all day yesterday, I had everything working with just one calendar and the MM working find. Today, I tried adding three other calendar to the code and now I’m getting a screen that’s telling me the “Must create a config file”. I must have done some syntax wrong that I’m just not seeing. Anyone show me what I’m doing wrong? I removed my url links. Here is my whole config file code…
                          c/* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 12,
                          	units: "metrics",
                          			     // false, default for all  NON-armv6l devices
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_right"
                            			module: 'MMM-CalendarExt2',
                              				calendars : [
                          					name: "Turtle's Calendar"
                          					url: "",
                          					name: "Work Calendar"
                          					url: "",
                          					name: "Bill Calendar"
                          					url: "",
                          					name: "Payday Calendar"
                          					url: "",
                              				views: [
                                  					mode: "weekly",
                              				scenes: [
                            sdetweil @Turtle
                            @Turtle after each name: line needs to end with a comma ,
                            • T
                              Turtle @sdetweil
                              @sdetweil said in MMM-CalendarExt2:
                              @sdetweil - after putting the post up there, I saw that and added them. Also, added quotes around module name “MMM-CalendarExt2”.
                              But I’m still getting the same message.
                              • T
                                Turtle
                                @sdetweil - wait a minute…do you mean after the name as in “Turtle’s Calendar”? I have them after each of the URL.
                                • T
                                  Turtle
                                  @sdetweil - thank you again…I got it up and working. Just got to do some tweaking!
                                    sdetweil @Turtle
                                    @Turtle yes.
                                    One thing to think about, as u encounter errors, is … What did I do last?
                                    • BKeyportB
                                      @sdetweil and “config check is cool” 😏
                                        sdetweil @BKeyport
                                        @BKeyport once u know how to read it!
                                        • T
                                          Turtle
                                          I’m confusing myself with all these examples I’m looking out from the main documentation to other people’s examples. When MM starts, I get the monthly calendar the entire screen but with none of my information from any of the four calendars that I have. Also, I do get the “Upcoming” view in the top_left hand corner with only my information from “Turtle’s Calendar” but not the other calendar. Here is my code…
                                              				calendars : [
                                          					name: "Turtle's Calendar",
                                          					url: "",
                                          					name: "Work Calendar",
                                          					url: "",
                                          					name: "Bill Calendar",
                                          					url: "",
                                          					name: "Payday Calendar",
                                          					url: "",
                                              				views: [
                                          						mode: "month",
                                          						position: "bottom_bar",
                                          						calendars: ["Turtle's Calendar", "Work Calendar", "Bill Calendar", "Payday Calendar"],
                                          						mode: "upcoming",
                                          						Title: "Upcoming Events",
                                          						slotCount: 10,
                                          						hideOverflow: false,
                                          						filterPassedEvent: true,
                                              				scenes: [
                                          						views: ["MONTHVIEW", "DAILYVIEW"],
                                            @Turtle
                                            I suspect maxItems of each view, but not confirm the reason without real ical data. send me your ical’s URL to inspect what happens. (eouia0819@gmail.com)
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
