    MMM-CalendarExt2
    486 Posts 83 Posters 1.0m Views 83 Watching
      [[global:former-user]] @EdO
      @EdO
      try to set “firstDrawingDelay” to 1000 or 2000 something, or shorten ‘updateInterval’ or ‘rotateInterval’.
      The reason would be; all your events are not loaded or parsed yet on its first drawing cycle, so only some of them will be displayed at that time. Remains will be parsed and displayed on next cycle when prepared.
      • E Offline
        EdO @Guest
        @Sean
        Thanks for getting back to me so fast.
        Ok firstDrawingDelay and rotateInterval are both at default values while updateInterval is set to 300000.
        I’ll first try setting rotateInterval to 1000 to match firstDrawingDelay to see if that fixes the problem. If that doesn’t work, I’ll experiment until I find something that does.
          @EdO
          if you are using only one scene or you don’t mind change of event applied instantly,
          you don’t need to keep interval so shortly. I think 1 -2 sec for firstDrawDelay would be enough.
          • BKeyportB Offline
            BKeyport Module Developer
            @Sean - been thinking about changing up my calendar a bit, and was wanting to see if this is possible. I want the majority of my screen to be a monthly calendar (the entire month), but not show individual events on a particular agenda/calendar (“Appointments”), rather show the number of events each day. For other agendas/calendars, I want items to show. Example using a downloaded monthly calendar template (18th, 19th, and 20th is typed in like I want)
            Example
            Then, I’d like a separate view, using only today’s events. I currently use the “daily” view, but I’d like to restrict it to “Today”.
            Is this possible?
              [[global:former-user]] @BKeyport
              @BKeyport
              you just want to show only event.of today? use “daily” with “slotCount:1”.
              • T Offline
                Thekk @Guest
                @Sean said in MMM-CalendarExt2:
                @Thekk
                Thanks. I haven’t thought about that method. Now I updated that part in the module.
                Excellent! Thanks for integrating the recurring filter.
                • T Offline
                  Turtle
                  Hello @Sean,
                  I just came upon your MMM-CalendarExt2 in the last few days. I think it will do what I need it to do for me. Awesome job! But before I dive in, I like to get myself familiar with it. After reading all the posts in this thread, you keep mentioning about adding “style codes” into the css/custom.css file. By any chance, this been renamed to “main.css”? This is the only css file I have in the “MagicMirror/css/” folder.
                    cskenney @Turtle
                    @Turtle In the CSS folder you should also have a custom.css file (in addition to the main.css file) that was created when you installed MagicMirror.
                    • T Offline
                      Turtle @cskenney
                      @cskenney said in MMM-CalendarExt2:
                      @cskenney - I do not have a custom.css file. Only have the main.css file. Why I’m so confused right now.
                        [[global:former-user]] @Turtle
                        @Turtle
                        I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css. Just create empty text file and name it as custom.css then save it to your css directory.
                        T S 2 Replies Last reply Reply Quote 0
                        • T Offline
                          Turtle @Guest
                          @Turtle
                          @Sean - I thought I could do that but wanted to make sure but before I did that though I was able to find another css file called “MMM-CalendarExt2” in another folder and made some changes to that file which seems to be working. Of course, I made a backup of it just in case but for some reason, that file is acting like custom.css.
                          C ? 2 Replies Last reply Reply Quote 0
                            cskenney @Turtle
                            @Turtle said in MMM-CalendarExt2:
                            @Turtle
                            Custom.css is the only file that doesn’t get over written when you update MM or Calendar-Ext2. That is why it exists. If you modify main.css then a MM update will wipe out the changes. Same thing is true of CalendarExt2.css.
                              @Turtle
                              To agree @cskenney
                              When I update MMM-CalendarExt2.css on next version, your change will be lost. Use css/custom.css.
                                sdetweil @Guest
                                because we removed it from the git repo, to avoid over-writing it on updates… can’t have it both ways…
                                  [[global:former-user]] @sdetweil
                                  In that case, .gitIgnore couldn’t help?
                                    sdetweil @Guest
                                    @Sean they decided to remove it…
                                    • BKeyportB Offline
                                      @sdetweil so custom.css.sample like the config?
                                        sdetweil @BKeyport
                                        @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
                                        • BKeyportB Offline
                                          true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
                                          • T Offline
                                            Turtle
                                            all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 24
                                            • 25
                                            • 14 / 25
