    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      sdetweil @Guest
      @Sean said in MMM-CalendarExt2:
      I don’t know why, but some nowadays version of MagicMirror has been missing css/custom.css.
      because we removed it from the git repo, to avoid over-writing it on updates… can’t have it both ways…
        A Former User @sdetweil
        In that case, .gitIgnore couldn’t help?
          sdetweil @Guest
          @Sean they decided to remove it…
          • BKeyportB
            @sdetweil so custom.css.sample like the config?
              sdetweil @BKeyport
              @BKeyport its an empty file… I can add it with the installer… if not present then touch to create the file…
              • BKeyportB
                true, forgot it started out empty. Back to MMM-CalendarExt2 here, I guess.
                • T
                  Turtle
                  all I know is that I’m glad to hear I’m not going crazy for not seeing the custom.css. lol
                  • T
                    Turtle
                    So, all day yesterday, I had everything working with just one calendar and the MM working find. Today, I tried adding three other calendar to the code and now I’m getting a screen that’s telling me the “Must create a config file”. I must have done some syntax wrong that I’m just not seeing. Anyone show me what I’m doing wrong? I removed my url links. Here is my whole config file code…
                    c/* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 12,
                    	units: "metrics",
                    			     // false, default for all  NON-armv6l devices
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_right"
                      			module: 'MMM-CalendarExt2',
                        				calendars : [
                    					name: "Turtle's Calendar"
                    					url: "",
                    					name: "Work Calendar"
                    					url: "",
                    					name: "Bill Calendar"
                    					url: "",
                    					name: "Payday Calendar"
                    					url: "",
                        				views: [
                            					mode: "weekly",
                        				scenes: [
                      sdetweil @Turtle
                      @Turtle after each name: line needs to end with a comma ,
                      • T
                        Turtle @sdetweil
                        @sdetweil said in MMM-CalendarExt2:
                        @sdetweil - after putting the post up there, I saw that and added them. Also, added quotes around module name “MMM-CalendarExt2”.
                        But I’m still getting the same message.
                        • T
                          Turtle
                          @sdetweil - wait a minute…do you mean after the name as in “Turtle’s Calendar”? I have them after each of the URL.
                          • T
                            Turtle
                            @sdetweil - thank you again…I got it up and working. Just got to do some tweaking!
                              sdetweil @Turtle
                              @Turtle yes.
                              One thing to think about, as u encounter errors, is … What did I do last?
                              • BKeyportB
                                @sdetweil and “config check is cool” 😏
                                  sdetweil @BKeyport
                                  @BKeyport once u know how to read it!
                                  • T
                                    Turtle
                                    I’m confusing myself with all these examples I’m looking out from the main documentation to other people’s examples. When MM starts, I get the monthly calendar the entire screen but with none of my information from any of the four calendars that I have. Also, I do get the “Upcoming” view in the top_left hand corner with only my information from “Turtle’s Calendar” but not the other calendar. Here is my code…
                                        				calendars : [
                                    					name: "Turtle's Calendar",
                                    					url: "",
                                    					name: "Work Calendar",
                                    					url: "",
                                    					name: "Bill Calendar",
                                    					url: "",
                                    					name: "Payday Calendar",
                                    					url: "",
                                        				views: [
                                    						mode: "month",
                                    						position: "bottom_bar",
                                    						calendars: ["Turtle's Calendar", "Work Calendar", "Bill Calendar", "Payday Calendar"],
                                    						mode: "upcoming",
                                    						Title: "Upcoming Events",
                                    						slotCount: 10,
                                    						hideOverflow: false,
                                    						filterPassedEvent: true,
                                        				scenes: [
                                    						views: ["MONTHVIEW", "DAILYVIEW"],
                                      A Former User @Turtle
                                      @Turtle
                                      I suspect maxItems of each view, but not confirm the reason without real ical data. send me your ical’s URL to inspect what happens. (eouia0819@gmail.com)
                                      • T
                                        Turtle @Guest
                                        @Turtle
                                        @Sean - it was sent. Thank you!
                                          @Turtle
                                          Result of Inspection.
                                          It seems
                                          • Turtle’s Calendar - Personal Public calendars
                                          • Other 3 Calendars - Has only access allowed to Your G Suite Group.
                                          In this case; the other 3 Calendars’ ical addresses will not be accessible from externs.
                                          For example; Open the browser and put the URL of your “Work calendar” in the address form. It will show 404 error
                                          In your Google Calendar settings, you can see warns.
                                          Warning: The address won’t work unless this calendar is public.
                                          • T
                                            Turtle
                                            This weekend I’m going to be working some more on the MM especially the CSS to get the calendars the way I want. So, I’m going to be making the “custom.css” file. Which of the current “.css” file am I going to us to fill the “custom.css” file? Also, on the next updating of MM am I going to lose the “custom.css” file?
                                            Turtle
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 24
                                            • 25
                                            • 15 / 25
