    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @tbs86
      @tbs86
      You’re welcome, mate. :thumbsup:
        rvanuden
        it all seems to be working but googlemaps can not be loaded, i used a new key though
        any ideas?
        R 1 Reply Last reply
          rvanuden @rvanuden
          @rvanuden anyone?
          M 1 Reply Last reply
            mcneilp @rvanuden
            @rvanuden I have the same problem. Did you find a solution?
              there is a problem with the original module… I have a fixed version
              here https://github.com/sdetweil/MMM-GoogleMapsTraffic
              Do this
              cd ~/MagicMirror/modules
              mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
              git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
              cd MMM-GoogleMapsTraffic
              npm install
              then restart the mirror app
              ChrisC 1 Reply Last reply
              Reply Quote 3
              • ChrisC
                Chris @sdetweil
                @sdetweil said in MMM-GoogleMapsTraffic:
                Do this
                npm install
                Thank you so much,
                Regards,
                  mcneilp
                  I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
                    sdetweil @mcneilp
                    @mcneilp thanks for the feedback… sad how many of the apis want to charge…
                    • E
                      Egnos
                      Hello to all.
                      Many thanks to the developer for the brilliant idea!
                      I describe my environment:
                      I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                      For now all modules work perfectly except MMM-GoogleMapsTraffic.
                      Description of the problem:
                      I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
                      The configuration of the .JSON seems ok, and the API has been entered correctly.
                      Can you help me…?
                      Thank you all!
                        sdetweil @Egnos
                        @Egnos see back a couple posts to get my updated version.
                        E 1 Reply Last reply
                        • E
                          Egnos @sdetweil
                          I installed the module this afternoon, I believe it is already the updated version.
                          I have used this
                          guide
                            sdetweil @Egnos
                            @Egnos from here, right?
                            E 3 Replies Last reply
                            • E
                              Egnos @sdetweil
                              Yes, of course.
                              • E
                                Egnos @sdetweil
                                sorry @sdetweil, I have seen now that there are two modules with the same name!
                                *vicmora module not updated
                                • sdetweil module updated
                                Correct?
                                Thanks.
                                  sdetweil @Egnos
                                  @Egnos correct
                                  • E
                                    Egnos @sdetweil
                                    Hi @sdetweil ,
                                    using the second link the module starts but I see this message:
                                    “This page didn’t load Google Maps correctly”
                                    The screen shot
                                    https://ibb.co/bm6BqJ6
                                    Can you help me?
                                    Thanks.
                                      sdetweil @Egnos
                                      @Egnos are u doing this over vnc? I don’t see that problem using the display connected to the pi
                                      • E
                                        Egnos @sdetweil
                                        Virtualize Raspbian with Virtualbox…
                                          sdetweil @Egnos
                                          @Egnos running on Intel?
                                          I use VMware Workstation mostly.
                                          But virtual box for a couple systems
                                          • E
                                            Egnos @sdetweil
                                            @sdetweil are there problems with Magic Mirror if using VirtualBox?
                                            • 4 / 5
