    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
      there is a problem with the original module… I have a fixed version
      here https://github.com/sdetweil/MMM-GoogleMapsTraffic
      Do this
      cd ~/MagicMirror/modules
      mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
      git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
      cd MMM-GoogleMapsTraffic
      npm install
      then restart the mirror app
      ChrisC 1 Reply Last reply Reply Quote 3
      • ChrisC
        Chris @sdetweil
        @sdetweil said in MMM-GoogleMapsTraffic:
        Do this
        npm install
        Thank you so much,
        Regards,
          mcneilp
          I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
            sdetweil @mcneilp
            @mcneilp thanks for the feedback… sad how many of the apis want to charge…
            • E
              Egnos
              Hello to all.
              Many thanks to the developer for the brilliant idea!
              I describe my environment:
              I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
              For now all modules work perfectly except MMM-GoogleMapsTraffic.
              Description of the problem:
              I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
              The configuration of the .JSON seems ok, and the API has been entered correctly.
              Can you help me…?
              Thank you all!
                sdetweil @Egnos
                @Egnos see back a couple posts to get my updated version.
                • E
                  Egnos @sdetweil
                  I installed the module this afternoon, I believe it is already the updated version.
                  I have used this
                  guide
                    sdetweil @Egnos
                    @Egnos from here, right?
                    E 3 Replies Last reply Reply Quote 0
                    • E
                      Egnos @sdetweil
                      Yes, of course.
                      • E
                        Egnos @sdetweil
                        sorry @sdetweil, I have seen now that there are two modules with the same name!
                        *vicmora module not updated
                        • sdetweil module updated
                        Correct?
                        Thanks.
                          sdetweil @Egnos
                          @Egnos correct
                          • E
                            Egnos @sdetweil
                            Hi @sdetweil ,
                            using the second link the module starts but I see this message:
                            “This page didn’t load Google Maps correctly”
                            The screen shot
                            https://ibb.co/bm6BqJ6
                            Can you help me?
                            Thanks.
                              sdetweil @Egnos
                              @Egnos are u doing this over vnc? I don’t see that problem using the display connected to the pi
                              • E
                                Egnos @sdetweil
                                Virtualize Raspbian with Virtualbox…
                                  sdetweil @Egnos
                                  @Egnos running on Intel?
                                  I use VMware Workstation mostly.
                                  But virtual box for a couple systems
                                  • E
                                    Egnos @sdetweil
                                    @sdetweil are there problems with Magic Mirror if using VirtualBox?
                                      sdetweil @Egnos
                                      @Egnos I don’t know. Haven’t tried that
                                      • E
                                        Egnos @sdetweil
                                        What does it mean when this message appears:
                                          sdetweil @Egnos
                                          @Egnos I do not know
                                            sdetweil @Egnos
                                            @Egnos sounds like u didn’t setup the API key
                                            https://www.google.com/amp/s/www.liontreegroup.com/tips-and-tricks/fixing-the-this-page-cant-load-google-maps-correctly-error/amp/
                                            • 4 / 5
