    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 93.2k Views 28 Watching
      rvanuden
      it all seems to be working but googlemaps can not be loaded, i used a new key though
      any ideas?
        rvanuden @rvanuden
        @rvanuden anyone?
          mcneilp @rvanuden
          @rvanuden I have the same problem. Did you find a solution?
            there is a problem with the original module… I have a fixed version
            here https://github.com/sdetweil/MMM-GoogleMapsTraffic
            Do this
            cd ~/MagicMirror/modules
            mv  MMM-GoogleMapsTraffic  MMM-GoogleMapsTraffic.original
            git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
            cd MMM-GoogleMapsTraffic
            npm install
            then restart the mirror app
            ChrisC 1 Reply Last reply Reply Quote 3
            • ChrisC Offline
              Chris @sdetweil
              @sdetweil said in MMM-GoogleMapsTraffic:
              Do this
              npm install
              Thank you so much,
              Regards,
                mcneilp
                I got it working. I did the above…plus I was using the wrong bit of text for my API key…and had to “setup billing” on my api account apparently to allow it to work.
                  sdetweil @mcneilp
                  @mcneilp thanks for the feedback… sad how many of the apis want to charge…
                  • E Offline
                    Egnos
                    Hello to all.
                    Many thanks to the developer for the brilliant idea!
                    I describe my environment:
                    I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
                    For now all modules work perfectly except MMM-GoogleMapsTraffic.
                    Description of the problem:
                    I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
                    The configuration of the .JSON seems ok, and the API has been entered correctly.
                    Can you help me…?
                    Thank you all!
                      sdetweil @Egnos
                      @Egnos see back a couple posts to get my updated version.
                      • E Offline
                        Egnos @sdetweil
                        I installed the module this afternoon, I believe it is already the updated version.
                        I have used this
                        guide
                          sdetweil @Egnos
                          @Egnos from here, right?
                          E 3 Replies Last reply Reply Quote 0
                          • E Offline
                            Egnos @sdetweil
                            Yes, of course.
                            • E Offline
                              Egnos @sdetweil
                              sorry @sdetweil, I have seen now that there are two modules with the same name!
                              *vicmora module not updated
                              • sdetweil module updated
                              Correct?
                              Thanks.
                                sdetweil @Egnos
                                @Egnos correct
                                • E Offline
                                  Egnos @sdetweil
                                  Hi @sdetweil ,
                                  using the second link the module starts but I see this message:
                                  “This page didn’t load Google Maps correctly”
                                  The screen shot
                                  https://ibb.co/bm6BqJ6
                                  Can you help me?
                                  Thanks.
                                    sdetweil @Egnos
                                    @Egnos are u doing this over vnc? I don’t see that problem using the display connected to the pi
                                    • E Offline
                                      Egnos @sdetweil
                                      Virtualize Raspbian with Virtualbox…
                                        sdetweil @Egnos
                                        @Egnos running on Intel?
                                        I use VMware Workstation mostly.
                                        But virtual box for a couple systems
                                        • E Offline
                                          Egnos @sdetweil
                                          @sdetweil are there problems with Magic Mirror if using VirtualBox?
                                            sdetweil @Egnos
                                            @Egnos I don’t know. Haven’t tried that
                                            • 4 / 5
