    MMM-DWD-Pollen
    Scheduled Pinned Locked Moved Health
    healthweather
    32 Posts 10 Posters 16.0k Views 10 Watching
      CarstenD
      Description
      Since the existing module to display Pollen information from Germany seems to be broken, I wrote a new module but used the US version as a template (MMM-Pollen).
      The data is sourced from DWD.
      Screenshot
      alt text
      Link:
      MMM-DWD-Pollen
      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
        CarstenD
        https://github.com/carstendirks/MMM-DWD-Pollen/blob/master/screenshot.png
        • thedoorsfanaticT Offline
          thedoorsfanatic @CarstenD
          @CarstenD
          Hi Carsten,
          love the idea of this module. I have just installed it with DWD_region: 120, for Bayern. It does not show any data. Does that mean there is no “Pollenwarnung” for today? When I put in the default DWD_region: 92, it shows me two values for Erle. If this is not a mistake, it might be a goog idea to show something like “Keine” when there is no “Pollenwarnung”.
          Thanks and excuse my bad English ;)
          My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
            CarstenD @thedoorsfanatic
            @thedoorsfanatic
            thanks for the hint. I am parsing for the partregion_id which in case of of Bayern has 4 sub regions 121-124:
            121 Allgäu/Oberbayern
            122 Donauniederungen
            123 Bayern n. der Donau, o. Bayr. Wald, o. Mainfranken
            124 Mainfranken
            There is a map showing the regions (even though the numbers are wrong): https://www.dwd.de/DE/leistungen/gefahrenindizespollen/Gebiete.html?nn=16102&lsbId=463856
            But good idea with the “no data” warning.
            Thanks (btw, I mad a bug fix yesterday that prevented some of the items showing up)
            thedoorsfanaticT 1 Reply Last reply Reply Quote 1
              Hey @CarstenD,
              thanks for the update. I put in DWD_region: 121, for Munich and now it shows up data.
              Keep up the good work!
                CarstenD
                New version available with icons as alternative display
                  Sachse
                  @CarstenD
                  Hi Carsten,
                  I have installed the module MMM-DWD-Pollen according to specification. Unfortunately it (as the only module) does not provide any data. I have also tested different DWD regions (81,92 and 122), but it only shows “Load …”. tcpdump (tcpdump -n host 141.38.3.62 -A -s 0) shows no connection attempt to https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
                  npm run config:check
                  magicmirror@2.11.0 config:check /home/pi/MagicMirror
                  node tests/configs/check_config.js
                  Checking file… /home/pi/MagicMirror/config/config.js
                  Your configuration file doesn’t contain syntax errors :)
                  What can I do to isolate the error?
                  start log:
                  x:~/MagicMirror $ npm start
                  magicmirror@2.11.0 start /home/pi/MagicMirror
                  [2020-05-11 18:05:28.755] [LOG] Starting MagicMirror: v2.11.0
                  [2020-05-11 18:05:28.769] [LOG] Loading config …
                  [2020-05-11 18:05:28.778] [LOG] Loading module helpers …
                  [2020-05-11 18:05:28.782] [LOG] No helper found for module: alert.
                  [2020-05-11 18:05:28.868] [LOG] Initializing new module helper …
                  [2020-05-11 18:05:28.870] [LOG] Module helper loaded: updatenotification
                  [2020-05-11 18:05:28.872] [LOG] No helper found for module: clock.
                  [2020-05-11 18:05:29.546] [LOG] Initializing new module helper …
                  [2020-05-11 18:05:29.547] [LOG] Module helper loaded: calendar
                  [2020-05-11 18:05:29.549] [LOG] No helper found for module: currentweather.
                  [2020-05-11 18:05:29.551] [LOG] No helper found for module: weatherforecast.
                  [2020-05-11 18:05:29.554] [LOG] Initializing new module helper …
                  [2020-05-11 18:05:29.556] [LOG] Module helper loaded: MMM-DWD-Pollen
                  [2020-05-11 18:05:29.598] [LOG] Initializing new module helper …
                  [2020-05-11 18:05:29.600] [LOG] Module helper loaded: newsfeed
                  [2020-05-11 18:05:29.601] [LOG] All module helpers loaded.
                  [2020-05-11 18:05:29.787] [LOG] Starting server on port 8080 …
                  [2020-05-11 18:05:29.808] [LOG] Server started …
                  [2020-05-11 18:05:29.810] [LOG] Connecting socket for: updatenotification
                  [2020-05-11 18:05:29.811] [LOG] Connecting socket for: calendar
                  [2020-05-11 18:05:29.813] [LOG] Starting node helper for: calendar
                  [2020-05-11 18:05:29.814] [LOG] Connecting socket for: MMM-DWD-Pollen
                  [2020-05-11 18:05:29.815] [LOG] MMM-DWD-Pollen helper started …
                  [2020-05-11 18:05:29.816] [LOG] Connecting socket for: newsfeed
                  [2020-05-11 18:05:29.817] [LOG] Starting module: newsfeed
                  [2020-05-11 18:05:29.818] [LOG] Sockets connected & modules started …
                  [2020-05-11 18:05:30.023] [LOG] Launching application.
                  THX Heiko
                  • bheplerB Offline
                    bhepler Module Developer @Sachse
                    @Sachse - Have you tried running the mirror in developer mode and looking for errors?
                    x:~/MagicMirror $ npm start dev
                      Sachse
                      @bhepler said in MMM-DWD-Pollen:
                      npm start dev
                      @bhepler
                      you mean the error messages in the bash or the console of Chromium?
                      $ npm start dev
                      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”
                      Gtk-Message: 19:18:06.195: Failed to load module “canberra-gtk-module”
                      Gtk-Message: 19:18:06.204: Failed to load module “canberra-gtk-module”
                      [2020-05-12 19:18:07.380] [LOG] Starting MagicMirror: v2.11.0
                      [2020-05-12 19:18:07.393] [LOG] Loading config …
                      [2020-05-12 19:18:07.402] [LOG] Loading module helpers …
                      [2020-05-12 19:18:07.405] [LOG] No helper found for module: alert.
                      [2020-05-12 19:18:07.507] [LOG] Initializing new module helper …
                      [2020-05-12 19:18:07.508] [LOG] Module helper loaded: updatenotification
                      [2020-05-12 19:18:07.509] [LOG] No helper found for module: clock.
                      [2020-05-12 19:18:08.251] [LOG] Initializing new module helper …
                      [2020-05-12 19:18:08.252] [LOG] Module helper loaded: calendar
                      [2020-05-12 19:18:08.253] [LOG] No helper found for module: currentweather.
                      [2020-05-12 19:18:08.255] [LOG] No helper found for module: weatherforecast.
                      [2020-05-12 19:18:08.258] [LOG] Initializing new module helper …
                      [2020-05-12 19:18:08.260] [LOG] Module helper loaded: MMM-DWD-Pollen
                      [2020-05-12 19:18:08.306] [LOG] Initializing new module helper …
                      [2020-05-12 19:18:08.307] [LOG] Module helper loaded: newsfeed
                      [2020-05-12 19:18:08.308] [LOG] All module helpers loaded.
                      [2020-05-12 19:18:08.510] [LOG] Starting server on port 8080 …
                      [2020-05-12 19:18:08.533] [LOG] Server started …
                      [2020-05-12 19:18:08.535] [LOG] Connecting socket for: updatenotification
                      [2020-05-12 19:18:08.536] [LOG] Connecting socket for: calendar
                      [2020-05-12 19:18:08.537] [LOG] Starting node helper for: calendar
                      [2020-05-12 19:18:08.538] [LOG] Connecting socket for: MMM-DWD-Pollen
                      [2020-05-12 19:18:08.539] [LOG] MMM-DWD-Pollen helper started …
                      [2020-05-12 19:18:08.540] [LOG] Connecting socket for: newsfeed
                      [2020-05-12 19:18:08.541] [LOG] Starting module: newsfeed
                      [2020-05-12 19:18:08.542] [LOG] Sockets connected & modules started …
                      [2020-05-12 19:18:08.772] [LOG] Whoops! There was an uncaught exception…
                      [2020-05-12 19:18:08.773] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                      at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                      at listenInCluster (net.js:1274:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                      code: ‘EADDRINUSE’,
                      errno: ‘EADDRINUSE’,
                      syscall: ‘listen’,
                      address: ‘127.0.0.1’,
                      port: 8080
                      [2020-05-12 19:18:08.792] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2020-05-12 19:18:08.793] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [2020-05-12 19:18:08.802] [LOG] Launching application.
                      [22416:0512/191926.709481:ERROR:CONSOLE(24)] “Empty response arrived for script ‘devtools://devtools/remote/serve_file/@74afbfc65bd4d271bc09280abd5783ffe47444b9/accessibility/accessibility_module.js’”, source: devtools://devtools/bundled/shell.js (24)
                      [22416:0512/191926.710572:ERROR:CONSOLE(109)] “Uncaught (in promise) Error: Could not instantiate: Accessibility.AccessibilitySidebarView”, source: devtools://devtools/bundled/shell.js (109)
                      [22416:0512/191936.736681:ERROR:CONSOLE(24)] “Empty response arrived for script ‘devtools://devtools/remote/serve_file/@74afbfc65bd4d271bc09280abd5783ffe47444b9/product_registry_impl/product_registry_impl_module.js’”, source: devtools://devtools/bundled/shell.js (24)
                      [22416:0512/191936.802627:ERROR:CONSOLE(109)] “Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry”, source: devtools://devtools/bundled/shell.js (109)
                      In the network analysis from the console of Chromium I find under MMM-DWD-Pollen.js:
                      Request URL: http://localhost:8080/modules/MMM-DWD-Pollen//MMM-DWD-Pollen.js
                      Request Method: GET
                      Status Code: 304 Not Modified
                      Remote Address: 127.0.0.1:8080
                      Referrer Policy: no-referrer-when-downgrade
                      Accept-Ranges: bytes
                      Cache-Control: public, max-age=0
                      Connection: keep-alive
                      Date: Tue, 12 May 2020 17:30:47 GMT
                      ETag: W/“1e7a-1720040e625”
                      Last-Modified: Sun, 10 May 2020 20:22:32 GMT
                      Strict-Transport-Security: max-age=15552000; includeSubDomains
                      X-Content-Type-Options: nosniff
                      X-DNS-Prefetch-Control: off
                      X-Download-Options: noopen
                      X-Frame-Options: SAMEORIGIN
                      X-XSS-Protection: 1; mode=block
                      Accept: /
                      Accept-Encoding: gzip, deflate, br
                      Accept-Language: de
                      Host: localhost:8080
                      If-Modified-Since: Sun, 10 May 2020 20:22:32 GMT
                      If-None-Match: W/“1e7a-1720040e625”
                      Referer: http://localhost:8080/
                      Sec-Fetch-Mode: no-cors
                      Sec-Fetch-Site: same-origin
                      User-Agent: Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.146 Electron/6.0.12 Safari/537.36
                      under Console with the word filter “pollen” I see:
                      Load script: modules/MMM-DWD-Pollen//MMM-DWD-Pollen.js
                      module.js:479 Module registered: MMM-DWD-Pollen
                      loader.js:150 Bootstrapping module: MMM-DWD-Pollen
                      loader.js:155 Scripts loaded for: MMM-DWD-Pollen
                      loader.js:194 Load stylesheet: modules/MMM-DWD-Pollen/MMM-DWD-Pollen.css
                      loader.js:157 Styles loaded for: MMM-DWD-Pollen
                      loader.js:159 Translations loaded for: MMM-DWD-Pollen
                      I hope I got the right error messages
                      Greetings Heiko
                        duxnobis
                        Hi Mate, could you do the same for Switzerland? Or chat bilateral to talk about what is required and I will see what I can organize. Thanks!
                        • bheplerB Offline
                          @Sachse - I mean the console in Chromium. The dev mode should display the console on your mirror so you can see the log from the display layer. The log in “bash” is the log from the back end (the node_helper.js and similar scripts).
                          @Sachse said in MMM-DWD-Pollen:
                          This means that some other process is already using port 8080 on your Pi. Usually, this means that you have two instances of Magic Mirror running. You may have something else using that port, but usually it’s another script attempting to also run your mirror. First, let’s check if PM2 has two instances defined. If you type pm2 status all what do you see?
                          General principle: You can ignore just about everything in a log file unless it is preceded by ERROR.
                            Sachse
                            @bhelper
                            Ohh, this is almost embarrassing. I could have figured that out myself by looking at netstat -plan|grep 8080. I was just irritated that the other modules worked without problems, so I didn’t suspect the error there. The module “MMM-DWD-Pollen” works great now :-)
                            Thanks for your support
                            bheplerB C K 3 Replies Last reply Reply Quote 1
                            • TechJak7000T Offline
                              TechJak7000
                              Hello Carsten,
                              Thank you for making a such a useful module, just out of curiosity would like to know that you can the data free from DWD, I would love to have one for Denmark, I tried to contact the AAD :- “Astma-Allergi Denmark” but could not find a solution.
                              I was wondering if you can assist me making one for Denmark, I will be wonderful and beneficial for many.
                              Best Regards
                              JG
                              • bheplerB Offline
                                @Sachse - Glad you got it working!
                                Don’t worry about the “gee, I could have figured that out for myself” thing. Today, it took me hours to realize that one of my customer’s problems was he had the wrong time zone set on his laptop. It’s the simple fixes with vague errors that hurt the most.
                                  CarstenD @Sachse
                                  @Sachse Glad you got it working with the support from @bhelper. Sorry that I could not reply fast enough. Thanks for using!
                                    CarstenD @duxnobis
                                    @duxnobis In general yes, I think Switzerland gets data from Meteo Schweiz (https://opendata.swiss/de/dataset/messstationen-des-nationalen-pollenmessnetzes)
                                      CarstenD @TechJak7000
                                      @TechJak7000 said in MMM-DWD-Pollen:
                                      I found some information here: https://github.com/rugaard/pollen
                                      Thus it looks like Astma-Allergi Denmark does not offer any official API. Thus you have to use this API here (which I guess takes the data from the website) and renders the data accordingly. There are only two regions as far as I can see (East and West?) and 25 pollen. If the API works it should no big problem.
                                      TechJak7000T 1 Reply Last reply Reply Quote 0
                                        TechJak7000 @CarstenD
                                        @CarstenD Thank you very much for your attention and effort. I have contacted the owner of the post to have more in depth information how to go about and use this API.
                                        As far as my limited knowledge for implementing this, one has to install / use 2 different programs systems to utilize it, and I have sent the guy a message with and example of the “MMM-pollen” to give him and idea of what I am looking for and how can I implement this, I hope I get a useful response.
                                          CarstenD
                                          Added the option to select which Pollen to display through config.
                                            MajorC Project Sponsor @CarstenD
                                            I have the DWD-Pollen on the right side of my scree. Unfortunately, there is a gap as you can see in the picture.
                                            I checked the CSS, but it is a table and I can’t see a good way to get rid of the space on the right.
                                            Any idea is appreciated.
