    MMM-DWD-Pollen
    Scheduled Pinned Locked Moved Health
    healthweather
    32 Posts 10 Posters 15.5k Views 10 Watching
      CarstenD
      https://github.com/carstendirks/MMM-DWD-Pollen/blob/master/screenshot.png
      • thedoorsfanaticT Offline
        thedoorsfanatic @CarstenD
        @CarstenD
        Hi Carsten,
        love the idea of this module. I have just installed it with DWD_region: 120, for Bayern. It does not show any data. Does that mean there is no “Pollenwarnung” for today? When I put in the default DWD_region: 92, it shows me two values for Erle. If this is not a mistake, it might be a goog idea to show something like “Keine” when there is no “Pollenwarnung”.
        Thanks and excuse my bad English ;)
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          CarstenD @thedoorsfanatic
          @thedoorsfanatic
          thanks for the hint. I am parsing for the partregion_id which in case of of Bayern has 4 sub regions 121-124:
          121 Allgäu/Oberbayern
          122 Donauniederungen
          123 Bayern n. der Donau, o. Bayr. Wald, o. Mainfranken
          124 Mainfranken
          There is a map showing the regions (even though the numbers are wrong): https://www.dwd.de/DE/leistungen/gefahrenindizespollen/Gebiete.html?nn=16102&lsbId=463856
          But good idea with the “no data” warning.
          Thanks (btw, I mad a bug fix yesterday that prevented some of the items showing up)
          thedoorsfanaticT 1 Reply Last reply Reply Quote 1
            Hey @CarstenD,
            thanks for the update. I put in DWD_region: 121, for Munich and now it shows up data.
            Keep up the good work!
              CarstenD
              New version available with icons as alternative display
                Sachse
                @CarstenD
                Hi Carsten,
                I have installed the module MMM-DWD-Pollen according to specification. Unfortunately it (as the only module) does not provide any data. I have also tested different DWD regions (81,92 and 122), but it only shows “Load …”. tcpdump (tcpdump -n host 141.38.3.62 -A -s 0) shows no connection attempt to https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
                npm run config:check
                magicmirror@2.11.0 config:check /home/pi/MagicMirror
                node tests/configs/check_config.js
                Checking file… /home/pi/MagicMirror/config/config.js
                Your configuration file doesn’t contain syntax errors :)
                What can I do to isolate the error?
                start log:
                x:~/MagicMirror $ npm start
                magicmirror@2.11.0 start /home/pi/MagicMirror
                [2020-05-11 18:05:28.755] [LOG] Starting MagicMirror: v2.11.0
                [2020-05-11 18:05:28.769] [LOG] Loading config …
                [2020-05-11 18:05:28.778] [LOG] Loading module helpers …
                [2020-05-11 18:05:28.782] [LOG] No helper found for module: alert.
                [2020-05-11 18:05:28.868] [LOG] Initializing new module helper …
                [2020-05-11 18:05:28.870] [LOG] Module helper loaded: updatenotification
                [2020-05-11 18:05:28.872] [LOG] No helper found for module: clock.
                [2020-05-11 18:05:29.546] [LOG] Initializing new module helper …
                [2020-05-11 18:05:29.547] [LOG] Module helper loaded: calendar
                [2020-05-11 18:05:29.549] [LOG] No helper found for module: currentweather.
                [2020-05-11 18:05:29.551] [LOG] No helper found for module: weatherforecast.
                [2020-05-11 18:05:29.554] [LOG] Initializing new module helper …
                [2020-05-11 18:05:29.556] [LOG] Module helper loaded: MMM-DWD-Pollen
                [2020-05-11 18:05:29.598] [LOG] Initializing new module helper …
                [2020-05-11 18:05:29.600] [LOG] Module helper loaded: newsfeed
                [2020-05-11 18:05:29.601] [LOG] All module helpers loaded.
                [2020-05-11 18:05:29.787] [LOG] Starting server on port 8080 …
                [2020-05-11 18:05:29.808] [LOG] Server started …
                [2020-05-11 18:05:29.810] [LOG] Connecting socket for: updatenotification
                [2020-05-11 18:05:29.811] [LOG] Connecting socket for: calendar
                [2020-05-11 18:05:29.813] [LOG] Starting node helper for: calendar
                [2020-05-11 18:05:29.814] [LOG] Connecting socket for: MMM-DWD-Pollen
                [2020-05-11 18:05:29.815] [LOG] MMM-DWD-Pollen helper started …
                [2020-05-11 18:05:29.816] [LOG] Connecting socket for: newsfeed
                [2020-05-11 18:05:29.817] [LOG] Starting module: newsfeed
                [2020-05-11 18:05:29.818] [LOG] Sockets connected & modules started …
                [2020-05-11 18:05:30.023] [LOG] Launching application.
                THX Heiko
                • bheplerB Offline
                  bhepler Module Developer @Sachse
                  @Sachse - Have you tried running the mirror in developer mode and looking for errors?
                  x:~/MagicMirror $ npm start dev
                    Sachse
                    @bhepler said in MMM-DWD-Pollen:
                    npm start dev
                    @bhepler
                    you mean the error messages in the bash or the console of Chromium?
                    $ npm start dev
                    DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”
                    Gtk-Message: 19:18:06.195: Failed to load module “canberra-gtk-module”
                    Gtk-Message: 19:18:06.204: Failed to load module “canberra-gtk-module”
                    [2020-05-12 19:18:07.380] [LOG] Starting MagicMirror: v2.11.0
                    [2020-05-12 19:18:07.393] [LOG] Loading config …
                    [2020-05-12 19:18:07.402] [LOG] Loading module helpers …
                    [2020-05-12 19:18:07.405] [LOG] No helper found for module: alert.
                    [2020-05-12 19:18:07.507] [LOG] Initializing new module helper …
                    [2020-05-12 19:18:07.508] [LOG] Module helper loaded: updatenotification
                    [2020-05-12 19:18:07.509] [LOG] No helper found for module: clock.
                    [2020-05-12 19:18:08.251] [LOG] Initializing new module helper …
                    [2020-05-12 19:18:08.252] [LOG] Module helper loaded: calendar
                    [2020-05-12 19:18:08.253] [LOG] No helper found for module: currentweather.
                    [2020-05-12 19:18:08.255] [LOG] No helper found for module: weatherforecast.
                    [2020-05-12 19:18:08.258] [LOG] Initializing new module helper …
                    [2020-05-12 19:18:08.260] [LOG] Module helper loaded: MMM-DWD-Pollen
                    [2020-05-12 19:18:08.306] [LOG] Initializing new module helper …
                    [2020-05-12 19:18:08.307] [LOG] Module helper loaded: newsfeed
                    [2020-05-12 19:18:08.308] [LOG] All module helpers loaded.
                    [2020-05-12 19:18:08.510] [LOG] Starting server on port 8080 …
                    [2020-05-12 19:18:08.533] [LOG] Server started …
                    [2020-05-12 19:18:08.535] [LOG] Connecting socket for: updatenotification
                    [2020-05-12 19:18:08.536] [LOG] Connecting socket for: calendar
                    [2020-05-12 19:18:08.537] [LOG] Starting node helper for: calendar
                    [2020-05-12 19:18:08.538] [LOG] Connecting socket for: MMM-DWD-Pollen
                    [2020-05-12 19:18:08.539] [LOG] MMM-DWD-Pollen helper started …
                    [2020-05-12 19:18:08.540] [LOG] Connecting socket for: newsfeed
                    [2020-05-12 19:18:08.541] [LOG] Starting module: newsfeed
                    [2020-05-12 19:18:08.542] [LOG] Sockets connected & modules started …
                    [2020-05-12 19:18:08.772] [LOG] Whoops! There was an uncaught exception…
                    [2020-05-12 19:18:08.773] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                    at listenInCluster (net.js:1274:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                    code: ‘EADDRINUSE’,
                    errno: ‘EADDRINUSE’,
                    syscall: ‘listen’,
                    address: ‘127.0.0.1’,
                    port: 8080
                    [2020-05-12 19:18:08.792] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-05-12 19:18:08.793] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-05-12 19:18:08.802] [LOG] Launching application.
                    [22416:0512/191926.709481:ERROR:CONSOLE(24)] “Empty response arrived for script ‘devtools://devtools/remote/serve_file/@74afbfc65bd4d271bc09280abd5783ffe47444b9/accessibility/accessibility_module.js’”, source: devtools://devtools/bundled/shell.js (24)
                    [22416:0512/191926.710572:ERROR:CONSOLE(109)] “Uncaught (in promise) Error: Could not instantiate: Accessibility.AccessibilitySidebarView”, source: devtools://devtools/bundled/shell.js (109)
                    [22416:0512/191936.736681:ERROR:CONSOLE(24)] “Empty response arrived for script ‘devtools://devtools/remote/serve_file/@74afbfc65bd4d271bc09280abd5783ffe47444b9/product_registry_impl/product_registry_impl_module.js’”, source: devtools://devtools/bundled/shell.js (24)
                    [22416:0512/191936.802627:ERROR:CONSOLE(109)] “Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry”, source: devtools://devtools/bundled/shell.js (109)
                    In the network analysis from the console of Chromium I find under MMM-DWD-Pollen.js:
                    Request URL: http://localhost:8080/modules/MMM-DWD-Pollen//MMM-DWD-Pollen.js
                    Request Method: GET
                    Status Code: 304 Not Modified
                    Remote Address: 127.0.0.1:8080
                    Referrer Policy: no-referrer-when-downgrade
                    Accept-Ranges: bytes
                    Cache-Control: public, max-age=0
                    Connection: keep-alive
                    Date: Tue, 12 May 2020 17:30:47 GMT
                    ETag: W/“1e7a-1720040e625”
                    Last-Modified: Sun, 10 May 2020 20:22:32 GMT
                    Strict-Transport-Security: max-age=15552000; includeSubDomains
                    X-Content-Type-Options: nosniff
                    X-DNS-Prefetch-Control: off
                    X-Download-Options: noopen
                    X-Frame-Options: SAMEORIGIN
                    X-XSS-Protection: 1; mode=block
                    Accept: /
                    Accept-Encoding: gzip, deflate, br
                    Accept-Language: de
                    Host: localhost:8080
                    If-Modified-Since: Sun, 10 May 2020 20:22:32 GMT
                    If-None-Match: W/“1e7a-1720040e625”
                    Referer: http://localhost:8080/
                    Sec-Fetch-Mode: no-cors
                    Sec-Fetch-Site: same-origin
                    User-Agent: Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.146 Electron/6.0.12 Safari/537.36
                    under Console with the word filter “pollen” I see:
                    Load script: modules/MMM-DWD-Pollen//MMM-DWD-Pollen.js
                    module.js:479 Module registered: MMM-DWD-Pollen
                    loader.js:150 Bootstrapping module: MMM-DWD-Pollen
                    loader.js:155 Scripts loaded for: MMM-DWD-Pollen
                    loader.js:194 Load stylesheet: modules/MMM-DWD-Pollen/MMM-DWD-Pollen.css
                    loader.js:157 Styles loaded for: MMM-DWD-Pollen
                    loader.js:159 Translations loaded for: MMM-DWD-Pollen
                    I hope I got the right error messages
                    Greetings Heiko
                      duxnobis
                      Hi Mate, could you do the same for Switzerland? Or chat bilateral to talk about what is required and I will see what I can organize. Thanks!
                      • bheplerB Offline
                        @Sachse - I mean the console in Chromium. The dev mode should display the console on your mirror so you can see the log from the display layer. The log in “bash” is the log from the back end (the node_helper.js and similar scripts).
                        @Sachse said in MMM-DWD-Pollen:
                        This means that some other process is already using port 8080 on your Pi. Usually, this means that you have two instances of Magic Mirror running. You may have something else using that port, but usually it’s another script attempting to also run your mirror. First, let’s check if PM2 has two instances defined. If you type pm2 status all what do you see?
                        General principle: You can ignore just about everything in a log file unless it is preceded by ERROR.
                        • 1 / 4
