    MMM-MQTTbridge
    Scheduled Pinned Locked Moved Unsolved System
    44 Posts 14 Posters 24.4k Views 15 Watching
    • SergeS Offline
      Serge
      TOPIC MOVED. PLEASE FOLLOW THE LINK BELOW FOR THE MODULE UPDATES, INQUIRIES, ETC
      [MMM-MQTTbridge] A module to publish and receive MQTT messages.
      MMM-MQTTbridge
      https://github.com/Tom-Hirschberger/MMM-MQTTbridge
      MMM-MQTTbridge allows you to integrate your MagicMirror into your smart home system via MQTT protocol and manage MagicMirror via MQTT messages by converting them into MM Notifications and vise verse - listen to your MM’s Notifications and convert them into MQTT mesages.
      So, this module for MagicMirror do the following:
      • Listens to MQTT messages from your MQTT broker and, if mqtt-message arrives, module sends MM Notifications based on the pre-configured mqtt-to-notification Dictionary rules.
      • Listens to the MM Notifications within your MagicMirror environment. If Notification arrives, module sends MQTT message based on the preconfigured notification-to-mqtt Dictionary rules.
      module_logo
      DOWNLOAD
      CONFIG STRUCTURE
      For better understanding, we have divided config into 3 sections:
      1. General configurations in config.js;
      2. “NOTIFICATION to MQTT” dictionary rules;
      3. “MQTT to NOTIFICATION” dictionary rules;
      GENERAL SECTION
      	module: 'MMM-MQTTbridge',
      	disabled: false,
      		mqttServer: "mqtt://:@localhost:1883",
      		mqttConfig:
      			listenMqtt: true,
      			interval: 300000,
      		notiConfig:
      			listenNoti: true,
      			ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
      			ignoreNotiSender: ["SYSTEM", "NEWS_FEED"],
      		// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
      		// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
      GENERAL part
      • mqttServerset you server address using the following format: “mqtt://”+USERNAME+“:”+PASSWORD+“@”+IPADDRESS+“:”+PORT. E.g. if you are using your broker without username/password on localhost with port 1883, you config should looks “mqtt://:@localhost:1883”.
      MQTT part
      • listenMqtt - turn on/off the listening of MQTT messages. Set to false if you are going to use only NOTI->MQTT dictionary to save CPU usage;
      • interval - interval for MQTT status update, default is 300000ms.
        (topics for subscription are taken from mqttDictionary.js
      NOTIFICATION part
      • listenNoti - turn on/off the listening of NOTIFICATIONS. Set to false if you are going to use only MQTT->NOTI dictionary to save CPU usage;
      • ignoreNotiId - list your NOTIFICATION ID that should be ignored from processing, this saves CPU usage. E.g. [“CLOCK_MINUTE”, “NEWS_FEED”],
      • ignoreNotiSender - list your NOTIFICATION SENDERS that should be ignored from processing, this saves CPU usage. E.g. [“system”, “NEWS_FEED”]
      NOTIFICATIONS to MQTT DICTIONARY SECTION
      Should be set within ~/MagicMirror/modules/MMM-MQTTbridge/dict/notiDictionary.js
      If payloadValue is empty, the actual payload of the notification will be used as MQTT payload.
      If payloadValue is specified and matches the payload received via the notification, mqttMsgPayload will be used as MQTT payload.
      var notiHook = [
          notiId: "CLOCK_SECOND",
          notiPayload: [
              payloadValue: '10',
              notiMqttCmd: ["Command 1"]
              payloadValue: '20',
              notiMqttCmd: ["Command 2"]
              payloadValue: '30',
      var notiMqttCommands = [
          commandId: "Command 1",
          mqttTopic: "myhome/kitchen/light/set",
          mqttMsgPayload: '{"state":"OFF"}'
          commandId: "Command 2",
          mqttMsgPayload: '{"state":"ON"}'
      MQTT to NOTIFICATIONS DICTIONARY SECTION
      Should be set within ~/MagicMirror/modules/MMM-MQTTbridge/dict/mqttDictionary.js
      If payloadValue is empty, the actual payload of the MQTT message will be used as notification payload.
      If payloadValue is specified and matches the payload received via MQTT, notiPayload will be used as notification payload.
      var mqttHook = [
            mqttTopic: "dahoam/test",
            mqttPayload: [
                payloadValue: "ASSISTANT_LISTEN",
                mqttNotiCmd: ["Command 1"]
                payloadValue: "",
                mqttNotiCmd: ["Command 2"]
            mqttTopic: "dahoam/test2",
            mqttPayload: [
                payloadValue: "",
      var mqttNotiCommands = [
            notiID: "ASSISTANT_LISTEN",
            notiPayload: 'BLABLABLA-1'
            notiPayload: ''
      TESTED ENVIRONMENT
      • Raspberry Pi 3 B+;
      • Clean Updated Upgarded Raspbian Buster;
      • MagicMirror ^2.10.1;
      • mqtt-broker eclipse-mosquitto run in docker on the same RPi;
      • mqtt-client on Windows10.
      CREDITS
      • @Thomas Hirschberger
      • @bugsounet
      • @sergge1
      • @DanielHfnr
      F wishmaster270W 2 Replies Last reply Reply Quote 3
      • F Offline
        fribse @Serge
        @Serge Wow, that looks very interesting. I’ll go and look into this!
        I have to turn the monitor on and off, and dim an undim the screen, it looks possible with this.
        • F Offline
          fribse
          @Serge is it on purpose you write:
          useMqttBridgeFromatOnly
          and not
          useMqttBridgeFormatOnly
          SergeS 1 Reply Last reply Reply Quote 0
          • F Offline
            fribse
            Ok, so now I tried setting it up, so far without luck.
            In the config.js I added
                        disabled: false,
                            mqttServer: "mqtt://user:password@mqttserver:1883",
                            mqttConfig:
                                listenMqtt: true,
                                useMqttBridgeFormatOnly: false,
                                interval: 300000,
                                topicSubscr: ["cmnd/home/bathroom/mirror"],
                            notiConfig:
                                listenNoti: true,
                                ignoreNotiSender: ["system", "NEWS_FEED"],
            So this should make it listen to the topic
            I have added the MMM-Remote module to have the screen off/on commands.
            in the dict/mqttDictionary.js I have written
            /**  mqtt-to-notification                     **/
            /**  dictionaty                               **/
            /**  for MMM-MQTTbridge module                **/
            /**  modify comands                           **/
            /**         @sergge1                          **/
            var mqttHook = [
                  mqttPayload: "TURN_OFF_SCREEN",
                  mqttNotiCmd: ["MONITOROFF"]
                  mqttPayload: "TURN_ON_SCREEN",
                  mqttNotiCmd: ["MONITORON"]
                  mqttPayload: "UNDIM_SCREEN",
                  mqttNotiCmd: ["UNDIM"]
                  mqttPayload: "DIM_SCREEN",
                  mqttNotiCmd: ["DIM"]
                  commandId: "MONITOROFF",
                  notiID: "REMOTE_ACTION",
                  notiPayload: 'MONITOROFF'
                  commandId: "MONITORON",
                  notiPayload: 'MONITORON'
                  commandId: "UNDIM",
                  notiPayload: 'BRIGHTNESS 100'
                  commandId: "DIM",
                  notiPayload: 'BRIGHTNESS 75'
              module.exports = { mqttHook,  mqttNotiCommands};
            But if I publish MONITOROFF to cmnd/home/bathroom/mirror nothing happens?
            Now, how do I debug this, where can I see if it even receives the message?
            • SergeS Offline
              Serge @fribse
              You have (1) mismatch in config and (2) wrong use of MMMRemoteControl syntax.
              1. First.
                You config.js contains a line:
              use the syntax exactly as it is written in the module’s readme. So please correct your config.js to useMqttBridgeFromatOnly.
              !!! I know about this misprint but it will be corrected in next release. As of now use as it is mentioned in readme.
              1. Second.
              notiPayload: ‘MONITOROFF’
              Notifications REMOTE_ACTION:MONITOROFF should be issued by the MQTTbridge module with your current mqttDictionary.js.
              However, I have checked the MMM-Remote control module, section “examples” and have found that MMMRemoteControl requires different from your Notification’s payload. It requires format: REMOTE_ACTION:{action: 'MONITOROFF'}
              So correct your mqttDictionary according to that format from MMM-Remote Control repo. As I understood, for monitor turn-off it should look like:
                notiPayload: "{action: 'MONITOROFF'}"
              Check the terminal log, MQTTbridge log in there (1) module start/stop (2) connection to mqtt server (3) conversion mqtt->noti.
              • SergeS Offline
                Serge @fribse
                @fribse said in MMM-MQTTbridge:
                see the log in terminal
                module produces something like this:
                [00:46:52.653] [LOG]    [MQTT bridge] MQTT message received. Topic: cmnd/home/smartmirror/volume/set, message: VOLUME_SET:0
                [00:46:52.873] [LOG]    [MQTT bridge] MQTT -> NOTI issued: VOLUME_SET, payload: 0
                • F Offline
                  fribse
                  • F Offline
                    fribse
                    Ok, I fixed the config.
                    The typo is back :-)
                    I see a few results right of the bat:
                    [15:55:10.009] [LOG]    [MQTT bridge] MQTT brocker error: Error: client disconnecting
                    [15:55:10.015] [LOG]    [MQTT bridge] NOTI->MQTT. Topic: home/bathroom/mirror/set, payload: {"state":"OFF"}
                    [15:55:20.026] [LOG]    [MQTT bridge] MQTT brocker error: Error: client disconnecting
                    [15:55:20.028] [LOG]    [MQTT bridge] NOTI->MQTT. Topic: home/bathroom/mirror/set, payload: {"state":"ON"}
                    It also pops up on the screen that the MQTT broker is not replying, which is weird, as it’s in use for a lot of systems. Not sure what is going on?
                    The dict looks like this:
                    var mqttHook = [
                          notiPayload: "{action: 'MONITORON'}"
                          commandId: "UNDIM",
                          notiPayload: "{action; 'BRIGHTNESS 100'}"
                          commandId: "DIM",
                          notiPayload: "{action: 'BRIGHTNESS 75'}"
                    When I publish the MONITOROFF to it, it seems to pick it up and then bummer:
                    [16:04:30.547] [LOG]    [MQTT bridge] MQTT message received. Topic: cmnd/home/bathroom/mirror, message: TURN_OFF_SCREEN
                    [16:04:30.639] [LOG]    [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: {action: 'MONITOROFF'}
                    [16:04:30.646] [LOG]    Whoops! There was an uncaught exception...
                    [16:04:30.665] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [16:04:30.667] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [16:04:30.710] [LOG]    Whoops! There was an uncaught exception...
                    [16:04:30.713] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [16:04:30.714] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    So for me it looks like the MQTT part works, it’s the sending to ‘Remote commander’ that is not working, or am I wrong?
                    I’ve also tried creating a ‘RESTART’ command, same result.
                    • SergeS Offline
                      Serge @fribse
                      the log record above means that MMM-MQTTbridge received mqtt message at the topic cmnd/home/bathroom/mirror with payload TURN_OFF_SCREEN.
                      The next log record
                      [16:04:30.639] [LOG] [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: {action: ‘MONITOROFF’}
                      says that MQTTbridge issued MagicMirror’s notification REMOTE_ACTION with payload {action: 'MONITOROFF'} which is exactly what you need. So this part works well.
                      However, the further messages in log
                      [16:04:30.646] [LOG] Whoops! There was an uncaught exception…
                      says that something went wrong with the MM core. That could be the reason for not executing the command by another module.
                      To find out the reason, you need to localize the error. Try to disable all modules and then add modules one-by-one and find which one cause that error.
                      hint: to disable modules, use disabled: true within each module config.
                      Change also listenNoti: to false, in MQTTbridge config if you do not need to convert Noti to Mqtt messages. So the module will not check all incoming MM’s notifications.
                      Here is the full log within my setup, I just sent a simple message to issue noti TEST with payload message:
                      pi@raspberrypi:~/MagicMirror $ npm start dev
                      > magicmirror@2.10.1 start /home/pi/MagicMirror
                      > ./run-start.sh "dev"
                      [23:48:05.361] [LOG]    Starting MagicMirror: v2.10.1
                      [23:48:05.395] [LOG]    Loading config ...
                      [23:48:05.435] [LOG]    Loading module helpers ...
                      [23:48:05.444] [LOG]    No helper found for module: clock.
                      [23:48:07.792] [LOG]    Initializing new module helper ...
                      [23:48:07.794] [LOG]    Module helper loaded: calendar
                      [23:48:07.800] [LOG]    No helper found for module: currentweather.
                      [23:48:07.802] [LOG]    No helper found for module: weatherforecast.
                      [23:48:07.890] [LOG]    Initializing new module helper ...
                      [23:48:07.891] [LOG]    Module helper loaded: newsfeed
                      [23:48:08.506] [LOG]    Initializing new module helper ...
                      [23:48:08.507] [LOG]    Module helper loaded: MMM-MQTTbridge
                      [23:48:08.691] [LOG]    All module helpers loaded.
                      [23:48:08.693] [LOG]    Starting server on port 8181 ...
                      [23:48:08.705] [INFO]   You're using a full whitelist configuration to allow for all IPs
                      [23:48:08.735] [LOG]    Server started ...
                      [23:48:08.740] [LOG]    Connecting socket for: calendar
                      [23:48:08.744] [LOG]    Starting node helper for: calendar
                      [23:48:08.747] [LOG]    Connecting socket for: newsfeed
                      [23:48:08.749] [LOG]    Starting module: newsfeed
                      [23:48:08.752] [LOG]    Connecting socket for: MMM-MQTTbridge
                      [23:48:08.754] [LOG]    [MQTT bridge] Module started
                      [23:48:08.800] [LOG]    Sockets connected & modules started ...
                      [23:48:09.890] [LOG]    Launching application.
                      [23:48:26.071] [LOG]    [MQTT bridge] Subscribed to the topic: home/smartmirror/bathroom/light/set
                      [23:51:43.274] [LOG]    [MQTT bridge] MQTT message received. Topic: home/smartmirror/bathroom/light/set, message: TEST:message
                      [23:51:43.420] [LOG]    [MQTT bridge] MQTT -> NOTI issued: TEST, payload: message
                      • F Offline
                        fribse
                        Hmm, not really sure what changed. I’ve tried setting the notilisten to false, and then I don’t see the error, but after reactivating it, I still dont’ see it.
                        I can see that the log reports state 0x6 when the monitor is on, and 0x2 when it’s off.
                        I can send commands to the Remote_Control module via http api, but nothing happens when I try it via the mqttbridge.
                        I guess I have to ask @Jopyth about that?
                        I also tried changing the quotation markings in the dict file, to match the Remote_Control parameters in the examples, but no change :-(
                              notiID: 'REMOTE_ACTION',
                              notiPayload: '{action: "MONITOROFF"}'
                              notiPayload: '{action: "MONITORON"}'
                              commandId: "UNDIM",
                              notiPayload: '{action; "BRIGHTNESS", value: "100"}'
                              commandId: "DIM",
                              notiPayload: '{action: "BRIGHTNESS", value: "75"}'
                              commandId: "RESTART",
                              notiPayload: '{action: "RESTART"}'
                          [[global:former-user]]
                          attention the syntax is not correct
                          try wih:
                          notiPayload: '{action: "BRIGHTNESS", value: "100"}'
                          • F Offline
                            fribse @Guest
                            @Bugsounet Thanks, it doesn’t change the behaviour though :-)
                            • F Offline
                              fribse
                              Darned, I just found the problem.
                              I had this in the mqttdictionary:
                              var mqttHook = [
                              But I was sending a MQTT message with ‘MONITOROFF’, if I send ‘TURN_OFF_SCREEN’ it works perfectly :-)
                              Thankyou @Serge and @Bugsounet for this GREAT module, just the missing piece.
                              Now I have to figure out about the noti->mqtt thing, I can see that the monitor status is reported in the log, but I can’t see what ‘notification’ is sent…
                              P.S. the logfile looks a bit weird:
                              0|mm  | [MQTT bridge] MQTT message received. Topic: cmnd/bathroom/mirror, message: MONITORON
                              0|mm  | [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: **[object Object]**
                              But it works…
                              • SergeS Offline
                                Serge
                                @fribse , finally it works for you. So the reason was the incorrect config initially as I understood.
                                log means that the payload of the noti is an “object” and not other type of data.
                                Exactly the same as for mqtt->noti: create an noti->mqtt dictionary and that is, literally, all.
                                here author https://github.com/Jopyth/MMM-Remote-Control#system-control wrote that Noti USER_PRESENCE: true or USER_PRESENCE: false is issued by the MMM-Remote-Control.
                                So configure your noti dictionary with these lines and you will get mqtt as soon as the USER_PRESENCE: true\false arrive. Pay attention, that the same noti could by issued by other modules, e.g.
                                Also, you can control other modules via mqtt-noti command. Starting from hiding/showing and ending with direct control. Examples:
                                Within your smarthome ecosystem based on MQTT/HomeAssistant (HA) - a great modules are
                                • MMM-NewPIR - use your PIR sensor, integrated into MM as an instance within HA ecosystem and add it states to the scenes automation.
                                • MMM-Youtube, - send mqtt->noti to this module and control via HA scenes e.g. turn-on news on Youtube in the morning etc.
                                • MMM-Volume, set and turn-on/off the volume (e.g. during the day/night time)
                                • Google Assistant etc.
                                Also, just a hint: add to ignoreNotiSender a default “clock” module. I will add this by default to the next release. The reason: “clock” module sends notification every second. So adding “clock” to ignored list will prevent MQTTbridge from checking “clock’s” notification in dictionary every second (just to save rpi cpu usage).
                                • F Offline
                                  fribse @Serge
                                  @Serge Yes, I did most of this already, I used the MMM-ViewNotifications to monitor which notifications was sent, and added all those I am not interested in :-)
                                  Thankyou for the followup.
                                  • SergeS Offline
                                    Serge
                                    here is fribse’s great tutorial for simple integration of MM into Home Assistant ecosystem.
                                    Following the logic from his post, user can expand it and control everything on its MM:
                                    https://community.home-assistant.io/t/magicmirror-integration-into-home-assistant-with-mqtt/177246
                                    • F Offline
                                      fribse
                                      Hi @Serge , I found one thing missing from the noti->mqtt, the QOS is not settable.
                                      I can see that you send them with qos:0, it should be settable to 0,1 or 2 as to how much guarantee for delivery it’s supposed to get.
                                      Other than that, it’s working perfectly, even via Google Home to turn the screen on and off (via the switch in Home Assistant)
                                      • rudibaraniR Offline
                                        rudibarani Project Sponsor
                                        This looks very interesting! Thanks a lot for the effort to create this module. I look forward to trying it :)
                                        • O Offline
                                          oberpiller
                                          Hey @Serge
                                          i am struggeling around with publishing a variable. Here is the thing: I want to publish a variable from the default “newsfeed” module of MMM. I already get a notification of ARTICLE_INFO_RESPONSE. I took a look at the source code and it seems like ARTICLE_INFO_RESPONSE is kind of an Array. I spend hours trying to get the “URL” variable from this Array into mqttMsgPayload:. Is it possible to get variables (from “arrays”) into the mqttMsgPayload variable of NotiDictionary.js?
                                          It can be a really easy thing, but I am kind of a newbie in JavaScrip…
                                          But newertheless I really like your module! Very good job!!!
                                            chimera
                                            This is perfect!!! Thanks so much! I run OpenHAB and utilise MQTT quite heavily. However I don’t like MQTT persistence, as it doesn’t work for me in OpenHAB. I run MMM-MQTT module in MM, but the problem with that is, when MagicMirror starts up it doesn’t display MQTT topic payload, as many MQTT updates I get are on intermittent basis (eg: swimming pool temperature, only updates if it changes, garden sprinkler last run, only updates when it’s run etc) So I’ve used this with MMM-Pages (I have several MM screens) and the 2nd page has mostly OpenHAB related info that I want to display. So I use the Notification ‘PAGE_CHANGED’ with payload = 1 (as pages start from 0) to publish an MQTT message of openhab/magicmirror/requestmqtt = ON. This is tied to a switch item in OpenHAB, and a rule in OpenHAB detects when the switch gets turned on, and in turn publishes a list of latest home automation data out to MQTT, which gets picked up and displayed on Magic Mirror. Prior to this, I would have a lot of items with “updating…” and had to wait until the device sent its latest information to MQTT.
                                            This covers all bases and more. I can see this becoming a very powerful little module!
                                            Thanks again!
