    MMM-MQTTbridge
    Scheduled Pinned Locked Moved Unsolved System
    44 Posts 14 Posters 26.1k Views 15 Watching
    • F
      fribse @Serge
      @Serge Wow, that looks very interesting. I’ll go and look into this!
      I have to turn the monitor on and off, and dim an undim the screen, it looks possible with this.
      • F
        fribse
        @Serge is it on purpose you write:
        useMqttBridgeFromatOnly
        and not
        useMqttBridgeFormatOnly
        SergeS 1 Reply Last reply Reply Quote 0
        • F
          fribse
          Ok, so now I tried setting it up, so far without luck.
          In the config.js I added
                      module: 'MMM-MQTTbridge',
                      disabled: false,
                          mqttServer: "mqtt://user:password@mqttserver:1883",
                          mqttConfig:
                              listenMqtt: true,
                              useMqttBridgeFormatOnly: false,
                              interval: 300000,
                              topicSubscr: ["cmnd/home/bathroom/mirror"],
                          notiConfig:
                              listenNoti: true,
                              ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
                              ignoreNotiSender: ["system", "NEWS_FEED"],
          		// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
          		// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
          So this should make it listen to the topic
          I have added the MMM-Remote module to have the screen off/on commands.
          in the dict/mqttDictionary.js I have written
          /**  mqtt-to-notification                     **/
          /**  dictionaty                               **/
          /**  for MMM-MQTTbridge module                **/
          /**  modify comands                           **/
          /**         @sergge1                          **/
          var mqttHook = [
                mqttPayload: "TURN_OFF_SCREEN",
                mqttNotiCmd: ["MONITOROFF"]
                mqttPayload: "TURN_ON_SCREEN",
                mqttNotiCmd: ["MONITORON"]
                mqttPayload: "UNDIM_SCREEN",
                mqttNotiCmd: ["UNDIM"]
                mqttPayload: "DIM_SCREEN",
                mqttNotiCmd: ["DIM"]
          var mqttNotiCommands = [
                commandId: "MONITOROFF",
                notiID: "REMOTE_ACTION",
                notiPayload: 'MONITOROFF'
                commandId: "MONITORON",
                notiPayload: 'MONITORON'
                commandId: "UNDIM",
                notiPayload: 'BRIGHTNESS 100'
                commandId: "DIM",
                notiPayload: 'BRIGHTNESS 75'
            module.exports = { mqttHook,  mqttNotiCommands};
          But if I publish MONITOROFF to cmnd/home/bathroom/mirror nothing happens?
          Now, how do I debug this, where can I see if it even receives the message?
          • SergeS
            Serge @fribse
            You have (1) mismatch in config and (2) wrong use of MMMRemoteControl syntax.
            1. First.
              You config.js contains a line:
            use the syntax exactly as it is written in the module’s readme. So please correct your config.js to useMqttBridgeFromatOnly.
            !!! I know about this misprint but it will be corrected in next release. As of now use as it is mentioned in readme.
            1. Second.
            notiPayload: ‘MONITOROFF’
            Notifications REMOTE_ACTION:MONITOROFF should be issued by the MQTTbridge module with your current mqttDictionary.js.
            However, I have checked the MMM-Remote control module, section “examples” and have found that MMMRemoteControl requires different from your Notification’s payload. It requires format: REMOTE_ACTION:{action: 'MONITOROFF'}
            So correct your mqttDictionary according to that format from MMM-Remote Control repo. As I understood, for monitor turn-off it should look like:
              notiPayload: "{action: 'MONITOROFF'}"
            Check the terminal log, MQTTbridge log in there (1) module start/stop (2) connection to mqtt server (3) conversion mqtt->noti.
            • SergeS
              Serge @fribse
              @fribse said in MMM-MQTTbridge:
              see the log in terminal
              module produces something like this:
              [00:46:52.653] [LOG]    [MQTT bridge] MQTT message received. Topic: cmnd/home/smartmirror/volume/set, message: VOLUME_SET:0
              [00:46:52.873] [LOG]    [MQTT bridge] MQTT -> NOTI issued: VOLUME_SET, payload: 0
              • F
                fribse
                • F
                  fribse
                  Ok, I fixed the config.
                  The typo is back :-)
                  I see a few results right of the bat:
                  [15:55:10.009] [LOG]    [MQTT bridge] MQTT brocker error: Error: client disconnecting
                  [15:55:10.015] [LOG]    [MQTT bridge] NOTI->MQTT. Topic: home/bathroom/mirror/set, payload: {"state":"OFF"}
                  [15:55:20.026] [LOG]    [MQTT bridge] MQTT brocker error: Error: client disconnecting
                  [15:55:20.028] [LOG]    [MQTT bridge] NOTI->MQTT. Topic: home/bathroom/mirror/set, payload: {"state":"ON"}
                  It also pops up on the screen that the MQTT broker is not replying, which is weird, as it’s in use for a lot of systems. Not sure what is going on?
                  The dict looks like this:
                  var mqttHook = [
                        notiPayload: "{action: 'MONITORON'}"
                        commandId: "UNDIM",
                        notiPayload: "{action; 'BRIGHTNESS 100'}"
                        commandId: "DIM",
                        notiPayload: "{action: 'BRIGHTNESS 75'}"
                  When I publish the MONITOROFF to it, it seems to pick it up and then bummer:
                  [16:04:30.547] [LOG]    [MQTT bridge] MQTT message received. Topic: cmnd/home/bathroom/mirror, message: TURN_OFF_SCREEN
                  [16:04:30.639] [LOG]    [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: {action: 'MONITOROFF'}
                  [16:04:30.646] [LOG]    Whoops! There was an uncaught exception...
                  [16:04:30.665] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [16:04:30.667] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [16:04:30.710] [LOG]    Whoops! There was an uncaught exception...
                  [16:04:30.713] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [16:04:30.714] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  So for me it looks like the MQTT part works, it’s the sending to ‘Remote commander’ that is not working, or am I wrong?
                  I’ve also tried creating a ‘RESTART’ command, same result.
                  • SergeS
                    Serge @fribse
                    the log record above means that MMM-MQTTbridge received mqtt message at the topic cmnd/home/bathroom/mirror with payload TURN_OFF_SCREEN.
                    The next log record
                    [16:04:30.639] [LOG] [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: {action: ‘MONITOROFF’}
                    says that MQTTbridge issued MagicMirror’s notification REMOTE_ACTION with payload {action: 'MONITOROFF'} which is exactly what you need. So this part works well.
                    However, the further messages in log
                    [16:04:30.646] [LOG] Whoops! There was an uncaught exception…
                    says that something went wrong with the MM core. That could be the reason for not executing the command by another module.
                    To find out the reason, you need to localize the error. Try to disable all modules and then add modules one-by-one and find which one cause that error.
                    hint: to disable modules, use disabled: true within each module config.
                    Change also listenNoti: to false, in MQTTbridge config if you do not need to convert Noti to Mqtt messages. So the module will not check all incoming MM’s notifications.
                    Here is the full log within my setup, I just sent a simple message to issue noti TEST with payload message:
                    pi@raspberrypi:~/MagicMirror $ npm start dev
                    > magicmirror@2.10.1 start /home/pi/MagicMirror
                    > ./run-start.sh "dev"
                    [23:48:05.361] [LOG]    Starting MagicMirror: v2.10.1
                    [23:48:05.395] [LOG]    Loading config ...
                    [23:48:05.435] [LOG]    Loading module helpers ...
                    [23:48:05.444] [LOG]    No helper found for module: clock.
                    [23:48:07.792] [LOG]    Initializing new module helper ...
                    [23:48:07.794] [LOG]    Module helper loaded: calendar
                    [23:48:07.800] [LOG]    No helper found for module: currentweather.
                    [23:48:07.802] [LOG]    No helper found for module: weatherforecast.
                    [23:48:07.890] [LOG]    Initializing new module helper ...
                    [23:48:07.891] [LOG]    Module helper loaded: newsfeed
                    [23:48:08.506] [LOG]    Initializing new module helper ...
                    [23:48:08.507] [LOG]    Module helper loaded: MMM-MQTTbridge
                    [23:48:08.691] [LOG]    All module helpers loaded.
                    [23:48:08.693] [LOG]    Starting server on port 8181 ...
                    [23:48:08.705] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [23:48:08.735] [LOG]    Server started ...
                    [23:48:08.740] [LOG]    Connecting socket for: calendar
                    [23:48:08.744] [LOG]    Starting node helper for: calendar
                    [23:48:08.747] [LOG]    Connecting socket for: newsfeed
                    [23:48:08.749] [LOG]    Starting module: newsfeed
                    [23:48:08.752] [LOG]    Connecting socket for: MMM-MQTTbridge
                    [23:48:08.754] [LOG]    [MQTT bridge] Module started
                    [23:48:08.800] [LOG]    Sockets connected & modules started ...
                    [23:48:09.890] [LOG]    Launching application.
                    [23:48:26.071] [LOG]    [MQTT bridge] Subscribed to the topic: home/smartmirror/bathroom/light/set
                    [23:51:43.274] [LOG]    [MQTT bridge] MQTT message received. Topic: home/smartmirror/bathroom/light/set, message: TEST:message
                    [23:51:43.420] [LOG]    [MQTT bridge] MQTT -> NOTI issued: TEST, payload: message
                    • F
                      fribse
                      Hmm, not really sure what changed. I’ve tried setting the notilisten to false, and then I don’t see the error, but after reactivating it, I still dont’ see it.
                      I can see that the log reports state 0x6 when the monitor is on, and 0x2 when it’s off.
                      I can send commands to the Remote_Control module via http api, but nothing happens when I try it via the mqttbridge.
                      I guess I have to ask @Jopyth about that?
                      I also tried changing the quotation markings in the dict file, to match the Remote_Control parameters in the examples, but no change :-(
                            notiID: 'REMOTE_ACTION',
                            notiPayload: '{action: "MONITOROFF"}'
                            notiPayload: '{action: "MONITORON"}'
                            commandId: "UNDIM",
                            notiPayload: '{action; "BRIGHTNESS", value: "100"}'
                            commandId: "DIM",
                            notiPayload: '{action: "BRIGHTNESS", value: "75"}'
                            commandId: "RESTART",
                            notiPayload: '{action: "RESTART"}'
                        A Former User
                        attention the syntax is not correct
                        try wih:
                        notiPayload: '{action: "BRIGHTNESS", value: "100"}'
                        • F
                          fribse @Guest
                          @Bugsounet Thanks, it doesn’t change the behaviour though :-)
                          • F
                            fribse
                            Darned, I just found the problem.
                            I had this in the mqttdictionary:
                            var mqttHook = [
                            But I was sending a MQTT message with ‘MONITOROFF’, if I send ‘TURN_OFF_SCREEN’ it works perfectly :-)
                            Thankyou @Serge and @Bugsounet for this GREAT module, just the missing piece.
                            Now I have to figure out about the noti->mqtt thing, I can see that the monitor status is reported in the log, but I can’t see what ‘notification’ is sent…
                            P.S. the logfile looks a bit weird:
                            0|mm  | [MQTT bridge] MQTT message received. Topic: cmnd/bathroom/mirror, message: MONITORON
                            0|mm  | [MQTT bridge] MQTT -> NOTI issued: REMOTE_ACTION, payload: **[object Object]**
                            But it works…
                            • SergeS
                              Serge
                              @fribse , finally it works for you. So the reason was the incorrect config initially as I understood.
                              log means that the payload of the noti is an “object” and not other type of data.
                              Exactly the same as for mqtt->noti: create an noti->mqtt dictionary and that is, literally, all.
                              here author https://github.com/Jopyth/MMM-Remote-Control#system-control wrote that Noti USER_PRESENCE: true or USER_PRESENCE: false is issued by the MMM-Remote-Control.
                              So configure your noti dictionary with these lines and you will get mqtt as soon as the USER_PRESENCE: true\false arrive. Pay attention, that the same noti could by issued by other modules, e.g.
                              Also, you can control other modules via mqtt-noti command. Starting from hiding/showing and ending with direct control. Examples:
                              Within your smarthome ecosystem based on MQTT/HomeAssistant (HA) - a great modules are
                              • MMM-NewPIR - use your PIR sensor, integrated into MM as an instance within HA ecosystem and add it states to the scenes automation.
                              • MMM-Youtube, - send mqtt->noti to this module and control via HA scenes e.g. turn-on news on Youtube in the morning etc.
                              • MMM-Volume, set and turn-on/off the volume (e.g. during the day/night time)
                              • Google Assistant etc.
                              Also, just a hint: add to ignoreNotiSender a default “clock” module. I will add this by default to the next release. The reason: “clock” module sends notification every second. So adding “clock” to ignored list will prevent MQTTbridge from checking “clock’s” notification in dictionary every second (just to save rpi cpu usage).
                              • F
                                fribse @Serge
                                @Serge Yes, I did most of this already, I used the MMM-ViewNotifications to monitor which notifications was sent, and added all those I am not interested in :-)
                                Thankyou for the followup.
                                • SergeS
                                  Serge
                                  here is fribse’s great tutorial for simple integration of MM into Home Assistant ecosystem.
                                  Following the logic from his post, user can expand it and control everything on its MM:
                                  https://community.home-assistant.io/t/magicmirror-integration-into-home-assistant-with-mqtt/177246
                                  • F
                                    fribse
                                    Hi @Serge , I found one thing missing from the noti->mqtt, the QOS is not settable.
                                    I can see that you send them with qos:0, it should be settable to 0,1 or 2 as to how much guarantee for delivery it’s supposed to get.
                                    Other than that, it’s working perfectly, even via Google Home to turn the screen on and off (via the switch in Home Assistant)
                                    • rudibaraniR
                                      rudibarani Project Sponsor
                                      This looks very interesting! Thanks a lot for the effort to create this module. I look forward to trying it :)
                                      • O
                                        oberpiller
                                        Hey @Serge
                                        i am struggeling around with publishing a variable. Here is the thing: I want to publish a variable from the default “newsfeed” module of MMM. I already get a notification of ARTICLE_INFO_RESPONSE. I took a look at the source code and it seems like ARTICLE_INFO_RESPONSE is kind of an Array. I spend hours trying to get the “URL” variable from this Array into mqttMsgPayload:. Is it possible to get variables (from “arrays”) into the mqttMsgPayload variable of NotiDictionary.js?
                                        It can be a really easy thing, but I am kind of a newbie in JavaScrip…
                                        But newertheless I really like your module! Very good job!!!
                                          chimera
                                          This is perfect!!! Thanks so much! I run OpenHAB and utilise MQTT quite heavily. However I don’t like MQTT persistence, as it doesn’t work for me in OpenHAB. I run MMM-MQTT module in MM, but the problem with that is, when MagicMirror starts up it doesn’t display MQTT topic payload, as many MQTT updates I get are on intermittent basis (eg: swimming pool temperature, only updates if it changes, garden sprinkler last run, only updates when it’s run etc) So I’ve used this with MMM-Pages (I have several MM screens) and the 2nd page has mostly OpenHAB related info that I want to display. So I use the Notification ‘PAGE_CHANGED’ with payload = 1 (as pages start from 0) to publish an MQTT message of openhab/magicmirror/requestmqtt = ON. This is tied to a switch item in OpenHAB, and a rule in OpenHAB detects when the switch gets turned on, and in turn publishes a list of latest home automation data out to MQTT, which gets picked up and displayed on Magic Mirror. Prior to this, I would have a lot of items with “updating…” and had to wait until the device sent its latest information to MQTT.
                                          This covers all bases and more. I can see this becoming a very powerful little module!
                                          Thanks again!
                                          • SergeS
                                            Serge
                                            @chimera said in MMM-MQTTbridge:
                                            eg: swimming pool temperature, only updates if it changes, garden sprinkler last run, only updates when it’s run, etc
                                            As far as I understood you, you need to issue some NOTI during the MM/Module startup, right?
                                            How would be the best option to do that? One possible solution is to have a file with the list of topics (e.g. “swimmingpool/temp/status”, “gardenspirnkler/run/status”) to which MQTTbrdige will send the mqtt-messages at startup.
                                            Will this solve your problem with the integration of MM to your smart home?
