    RPi 3B+ / high %CPU / high temp
    11 Posts 3 Posters 2.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Ebson
      @Ebson said in RPi 3B+ / high %CPU / high temp:
      'Weather or Not’
      CPU usage and heat have arisen now and again. If you search the forum you’ll find lots to read and perhaps a solution. At times it has been the version of Pi and other times the version of electron.
      Concerning MMM-WeatherOrNot: There are only 2 things that I can think of that might affect your Pi negatively.
      1. An extremely low updateInternal. The default is updateInterval: 10 * 60 * 1000, (10 minutes)
      2. The use of the animated icons option.
      I would like to hear from others if they are having the same issue, whether with a low updateInterval or the animated icons.
      • E Offline
        Ebson
        I used:
        • Weather or Not:
          updateInterval: 60 * 60 * 1000,
          icons: Climacons (no animation)
        • DarkSky:
          useAnimatedIcons: false,
          animateMainIconOnly: false,
          updateInterval: 60,
          requestDelay: 1000,
          updateFadeSpeed: 2000
        • 2x Newsfeed:
          reloadInterval: 10*60*1000,
          updateInterval: 15000,
          animationSpeed: 0
        and I ended up with:
        finnnnnnn
        I still need to consider adding fan but increasing intervals and turning off animation helped a lot
        Maybe I will play also with some older electrons.
        Thank you for your reply;)
          @Ebson
          Honestly, I don’t think a 60 minute updateInterval is necessary for WeatherOrNot.
          DarkSky updateInterval is 60 ms??? (I don’t use that module). If that is miiliseconds it would certainly cause trouble.
          • E Offline
            Ebson
            You are right. I will change it into 6h… or even longer.
            There is written in DarkSky’s Documentation that the value should be given in minutes. I don’t really know how to check whether it is not a mistake in Doc. I will make some testing;)
            • E Offline
              Ebson
              DarkSky:
                setInterval(function() {
                  self.getData();
                }, self.config.updateInterval * 60 * 1000); //convert to milliseconds
              So, value should be given in minutes in config file. Anyway, I will increase a value. BTW, it is also nice module for weather.
                No, I meant that 60 minutes is more than adequate.
                I use a few of my own.
