    Newsfeed size
    29 Posts 4 Posters 10.6k Views 4 Watching
    • K Offline
      Kenta @sdetweil
      @sdetweil thank you for trying, but I don’t know where to look… Total n00b…
      This is from my config.js
      module: “newsfeed”,
      position: “bottom_bar”,
      feeds: [
      title: “NRK Nyheter”,
      url: “https://www.nrk.no/nyheter/siste.rss”
        sdetweil @Kenta
        @Kenta understand… each module gets to do its own thing… hardly any are documented well…
        all modules code are in the ~/MagicMirror/modules folder
        all the built in ones are in the modules/default folder…
        each module has a file with the name matching the module name… so in this case
        ~/MagicMirror/modules/default/newsfeed/newsfeed.js
        setting the UI component css ‘class’ is done y setting the ‘className’ variable of the element
        so, you edit the file and search for className , and there may be multiple… (as there are in this case)…
          Mykle1 Project Sponsor Module Developer @Kenta
          @Kenta said in Newsfeed size:
          Nope. Still just the headlines. Does the css need to contain more than just the code you suggested?
          So, I second guessed myself and checked again. The code above does what you want for the headlines. Are you saying you want the New York Times, 2 hours ago: portion as well? In that case, add this as well.
          .newsfeed .light.small.dimmed {
            font-size: 60px;
            line-height: 60px;
          Screenshot
          • K Offline
            Kenta @Mykle1
            @Mykle1 not exactly. I want my entire newsfeed bigger. Not just the headlines. This is the original (https://www.dropbox.com/s/nzb2o5kecn6gfdy/Screenshot_20200317_065226_com.realvnc.view![alt
            Then by the changes made in the before mentioned css I get this https://www.dropbox.com/s/pxnuosggy7g24q7/Screenshot_20200317_065703_com.realvnc.viewer.android.jpg?dl=0
            But the actual news is still same size…
              @Kenta
              Assuming we are talking about the default newsfeed module, I could only identify two classes.
              The title
              .newsfeed .bright.medium.light {
                font-size: 60px;
                line-height: 60px;
              And the source
                font-size: 60px;
                line-height: 60px;
              I’m not seeing another. As you can see from my picture both rules are working. Are you using BOTH of these?
                font-size: 60px;
                line-height: 60px;
                font-size: 60px;
                line-height: 60px;
              Maybe I’m using an old version? Open the dev console when the mirror is running and identify the third class, if there is one.
              • K Offline
                Kenta @Mykle1
                @Mykle1
                None of those help. The first gives a bigger headline, as I’ve showed in previous posts, the other one a bigger name of news channel/time of occurrence.
                In dev I see this alt text
                • K Offline
                  Kenta @Kenta
                  • K Offline
                    Kenta
                    this
                      sdetweil @Kenta
                      @Kenta posting pictures does not work… u have to link to them uploaded somewhere else
                      • K Offline
                        Kenta @sdetweil
                        As previously stated, I’m a complete n00b. It’s sad because I want to be a nerd 😂
                        Yeah I’ve tried unsuccessfully to post images, but this last one was a link to a Dropbox image. Did it not work.?
                        S 3 Replies Last reply Reply Quote 0
