    Newsfeed size
    29 Posts 4 Posters 12.3k Views 4 Watching
      sdetweil @Kenta
      @Kenta understand… each module gets to do its own thing… hardly any are documented well…
      all modules code are in the ~/MagicMirror/modules folder
      all the built in ones are in the modules/default folder…
      each module has a file with the name matching the module name… so in this case
      ~/MagicMirror/modules/default/newsfeed/newsfeed.js
      setting the UI component css ‘class’ is done y setting the ‘className’ variable of the element
      so, you edit the file and search for className , and there may be multiple… (as there are in this case)…
        Mykle1 Project Sponsor Module Developer @Kenta
        @Kenta said in Newsfeed size:
        Nope. Still just the headlines. Does the css need to contain more than just the code you suggested?
        So, I second guessed myself and checked again. The code above does what you want for the headlines. Are you saying you want the New York Times, 2 hours ago: portion as well? In that case, add this as well.
        .newsfeed .light.small.dimmed {
          font-size: 60px;
          line-height: 60px;
        Screenshot
        • K Offline
          Kenta @Mykle1
          @Mykle1 not exactly. I want my entire newsfeed bigger. Not just the headlines. This is the original (https://www.dropbox.com/s/nzb2o5kecn6gfdy/Screenshot_20200317_065226_com.realvnc.view![alt
          Then by the changes made in the before mentioned css I get this https://www.dropbox.com/s/pxnuosggy7g24q7/Screenshot_20200317_065703_com.realvnc.viewer.android.jpg?dl=0
          But the actual news is still same size…
            @Kenta
            Assuming we are talking about the default newsfeed module, I could only identify two classes.
            The title
            .newsfeed .bright.medium.light {
              font-size: 60px;
              line-height: 60px;
            And the source
              font-size: 60px;
              line-height: 60px;
            I’m not seeing another. As you can see from my picture both rules are working. Are you using BOTH of these?
              font-size: 60px;
              line-height: 60px;
              font-size: 60px;
              line-height: 60px;
            Maybe I’m using an old version? Open the dev console when the mirror is running and identify the third class, if there is one.
            • K Offline
              Kenta @Mykle1
              @Mykle1
              None of those help. The first gives a bigger headline, as I’ve showed in previous posts, the other one a bigger name of news channel/time of occurrence.
              In dev I see this alt text
              • K Offline
                Kenta @Kenta
                • K Offline
                  Kenta
                  this
                    sdetweil @Kenta
                    @Kenta posting pictures does not work… u have to link to them uploaded somewhere else
                    • K Offline
                      Kenta @sdetweil
                      As previously stated, I’m a complete n00b. It’s sad because I want to be a nerd 😂
                      Yeah I’ve tried unsuccessfully to post images, but this last one was a link to a Dropbox image. Did it not work.?
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @Kenta
                        @Kenta ok, didn’t see the last as a link.
                        For Dropbox, if u change the url, dl=0, to dl=1, then it will show here…
                          sdetweil @Kenta
                          no problems, we all were…
                            sdetweil @Kenta
                            @Kenta the code for the source title and date/time is
                            sourceAndTimestamp.className = “newsfeed-source light small dimmed”;
                            newsfeed-source doesn’t exist in main.css
                            light is
                            .light {
                              font-family: "Roboto Condensed", sans-serif;
                              font-weight: 300;
                            small is
                            .small {
                              font-size: 20px;
                              line-height: 25px;
                            and dimmed is
                            .dimmed {
                              color: #666;
                            so, to change the SIZE you need to change the value for class ‘small’
                            so, for example
                            in ~/MagicMirror/css/custom.css put
                            .newsfeed .small {
                              font-size: 40px;
                              line-height: 45px;
                            for the title text the code is
                            title.className = “newsfeed-title bright medium light” +
                            newsfeed-title doesn't exist
                            so 'medium' is the size
                            .medium {
                            font-size: 30px;
                            line-height: 35px;
                            so change that to, in custom.css
                            .medium {
                            font-size: 50px;
                            line-height: 55px;
                            so now, custom.css looks like this (sizes just for example)
                            .newsfeed .small {
                            font-size: 40px;
                            line-height: 45px;
                            .newsfeed .medium {
                            font-size: 50px;
                            line-height: 55px;
                            K C 2 Replies Last reply Reply Quote 0
                            • K Offline
                              Kenta @sdetweil
                              Thank you! That worked perfectly!
                                cyberphox @sdetweil
                                @sdetweil said in Newsfeed size:
                                .newsfeed .small {
                                font-size: 40px;
                                line-height: 45px;
                                Why the heck isn’t this working for me!
                                I’ve moved compliments module to lower_third region but i can’t seem to change the size of it
                                  sdetweil @cyberphox
                                  @cyberphox show me the css class setup you did… note that each module gets to choose there own class usage… so ‘small’ might not work for compliments… read the readme,
                                  or look at the
                                  main.css or
                                  compliments.css or
                                  last resort the compliments.js. file for class usage (search for className in the js file)
                                  sometimes the class usages is documented, and sometimes(most times) not
                                    cyberphox @sdetweil
                                    @sdetweil sorry i’ve been fighting with CSS all day and typed that in wrong…
                                    What I mean to say was I moved the newsfeed module to lower_third
                                    In custom.css I’ve tried:
                                    .newsfeed .small {
                                    font-size: 40px;
                                    line-height: 45px;
                                    .newsfeed .medium {
                                    font-size: 50px;
                                    line-height: 55px;
                                      cyberphox
                                      I even tried this - thinking maybe the indent made a difference but nope!
                                      .newsfeed .small {
                                        font-size: 80px;
                                        line-height: 65px;
                                      .newsfeed .medium {
                                        font-size: 70px;
                                        line-height: 75px;
                                        sdetweil @cyberphox
                                        @cyberphox i would open the developers window, ctrl-shift-i or f12, and select the elements tab, and scroll thru to the needs feed objects and look at their classes and settings (the css tree is expand on the right as u select an item, nears to the element at the top (custom.css -> main.css ) to furthest at the bottom
                                        it solves so many problems to be able to just look at it
                                          cyberphox
                                          Oh I’ve been looking at the damn thing all day!
                                          newsfeed-title bright medium light seems to be one…if i could at least change something!
                                            sdetweil @cyberphox
                                            @cyberphox said in Newsfeed size:
                                            newsfeed-title
                                            in your class u said
                                            .newsfeed
                                            not the same thing
