    Motion Detector
    213 Posts 38 Posters 569.3k Views 39 Watching
      done @bhepler
      @bhepler Sorry, I haven’t tried yet. :)
      I installed the cam and the module yesterday and motion detection worked.
      But I experienced the same issue this morning. Wake up problem is not solved.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @done
        @done propably everything is working for you guys and you can just see the screensaver, be sure to disable the screensaver
        D B 2 Replies Last reply Reply Quote 1
          done @strawberry 3.141
          Hi @strawberry-3.141
          Thanks for your answer
          I disabled the screensaver by editing (found here
          Is that what you had in mind?
          sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
          @lxpanel --profile LXDE-pi
          @pcmanfm --desktop --profile LXDE-pi
          #@xscreensaver -no-splash
          @xset s off
          @xset -dpms
          @xset s noblank
          @unclutter
          Strange that my camera driver was not working today.
          I had to activate the cam in the pi config again.
          In the morning the cam led was on but when I tried to wake up the monitor the led just turned off.
          I use a v1.3 cam on a rpi3.
            @done Personally I don’t have a mirror myself, but I heard from other users in this forum they had problems with the screensaver when they tried to wake up the mirror using my voice module. They could see the mirror got brighter, but the screen was still black because of the screensaver. I would connect a mouse or keyboard and do some action to see if there is a screensaver active.
              @strawberry-3.141 Ok, I’ll give it a try. Tomorrow morning, I will test again. Thx!
                bibi
                hello! as understood there are 2 topics ongoing here "PIR module of @cowboysdude " and "motiondetector of @alexyak ". I will not ask which is the best module, you both did a great job, thx!
                don’t take it bad but i just wanted to have opinions and feedback on which one is running currently without any, less issues please? (i am starting my mirror and don’t want to be too much demanding on the forum if not working - wise ;-))
                @cowboysdude : i have already implemented Paviro’s module to test and i wanted to know if i should remove it before installing your one?
                Thx in advance for your relpies and have a good day/eve :)
                • cowboysdudeC Offline
                  cowboysdude Module Developer @bibi
                  @bibi said in Motion Detector:
                  Honestly I will you this… I liked the motion sensor BUT @ianperrin worked out a module scheduler that I liked much better! I can turn modules off and on at specific times and turn it all off when I"m not home only to have it back on again when I arrive home.
                  All-in-all it really depends on your needs. NOTHING is without issues of some kind. I just really disliked the PIR sensor sticking out …
                  I hoped this help you in some way.
                  OH but of course @strawberry-3-141 also made a voice module that you can just tell the mirror to turn off too :) The usb mike is about the same price as a pir sensor!!! It’s REALLY awesome!!!
                    cowboysdude Module Developer @done
                    @done said in Motion Detector:
                    WORST case senario is you install a screen saver program and disable it… period. :)
                      bibi @cowboysdude
                      @cowboysdude 1st thx for taking time to reply. much appriciated! the PIR is ok but as it needs to get hidden somewhere, etc it’s less convinent. Yes you are right, the solution depends on my personnal need… i just need a way to switch on MM when i am in front of it BUT also completly switch off the monitor when nothing detected and not only the MM.
                      oh great, i will check @strawberry-3-141 module for sure!
                      @IngmarSwart also designed a solution with motion detection with a Picam behind the glass which seems to be nice to. i let you check it if interest…
                      by the way, do i have to remove Paviro module to install your one?
                      i couldn’t find @strawberry-3-141 module… can you pls forward me the link?
                        bhepler Module Developer @strawberry 3.141
                        @strawberry-3.141 said in Motion Detector:
                        Negative. The screensaver has been disabled but the motiondetection module isn’t working. I gave the Facial Recognition module a try, but with the camera behind the glass, there isn’t enough light to train the system to recognize anyone.
                        At this point, I’m considering downgrading my chromium to something without the new security “features”.
                          I’m still working this problem. To help with @paphko 's concern about processor utilization, I finally figured out how and where to put a delay in the main image comparison loop. @alexyak is using the RequestAnimationFrame feature to run the comparison as fast as the browser can render the UI.
                          If you wish to include a delay, modify your motion.js file’s main function to read as such:
                          function main(frequency) {
                          	render();
                          	if(rendering == true) {
                          		setTimeout(function() {
                          			raf(main.bind(this));
                          		}, 500);
                          That last number (the 500) is the milliseconds between each image comparison. I think half a second between comparisons is enough to keep the CPU usage down and the effectiveness up.
                            done @bhepler
                            Thx @bhepler
                            this helped to reduce my temperature from 80 °C to 50-60 °C.
                            Maybe the 80 °C even caused the wake up problem? :)
                            Anyway, I think I’ll try the voice activation module tomorrow.
                            Somehow it’s even very sweet to say “Mirror, Mirror on the wall. Wake up!”.
                              DirkS
                              That is the reason why my screen doesn’t switch on after a couple of hrs switched off.
                              Any idea what the cause of unavailable tvservice is?
                              Testwise i used the scripts reported here before. They where called if a PIR detects motion or no motion.
                              Nov  1 08:22:00 MagicMirror kernel: [86411.138649] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.138665] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.138670] detected fb_set_par error, error code: -22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.139138] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.139148] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.139152] detected fb_set_par error, error code: -22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140642] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140654] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140659] detected fb_set_par error, error code: -22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140777] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140785] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140789] detected fb_set_par error, error code: -22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140856] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140863] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.140868] bcm2708_fb_pan_display(0,0) returns=-22
                              Nov  1 08:22:00 MagicMirror systemd[1]: Started Getty on tty6.
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256398] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256413] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256418] detected fb_set_par error, error code: -22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256758] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256770] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
                              Nov  1 08:22:00 MagicMirror kernel: [86411.256775] bcm2708_fb_pan_display(0,0) returns=-22
                              Nov  1 08:22:00 MagicMirror kernel: [86411.296428] raspberrypi-firmware soc:firmware: Request 0x00040002 returned status 0x80000001
                              Nov  1 08:22:00 MagicMirror kernel: [86411.296455] bcm2708_fb soc:fb: bcm2708_fb_blank(0) failed: -22
                              2016.11.01 08:05:04 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                              tvservice-client: Failed to connect to TV service: -1
                              [E] Failed to power off HDMI
                              Powering off HDMI
                              2016.11.01 08:05:57 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                              [E] Failed to set property 4
                              2016.11.01 08:07:37 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                              Powering off HDMI
                              2016.11.01 08:09:00 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                              2016.11.01 08:09:42 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                              Powering off HDMI
                              2016.11.01 08:09:59 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                              ping: icmp open socket: Operation not permitted
                              2016.11.01 08:10:41 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                              Powering off HDMI
                              2016.11.01 08:21:59 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_on.sh &")}: -1
                              2016.11.01 08:22:50 2: KuMagicScreen: {system("sudo /opt/fhem/monitor_off.sh &")}: -1
                              Powering off HDMI
                                DirkS
                                So here i found a workaround. Maybe it fixes the issue but let’s see. I just modified my test script and need to see it the next hrs/days
                                https://github.com/raspberrypi/documentation/pull/245/files
                                https://github.com/raspberrypi/linux/issues/487
                                  DirkS
                                  for all the people here I wrote it more cleary :D
                                  i had big problems by switching off my screen with the PIR or another module with camera. The problem was not the module itself it is a firmware problem of the PI. I could see the same problem outside of MagicMirror as well by trying different things.
                                  Reported also here:
                                  The symptom is that after a while of switching on and off the screen it remains off.
                                  Dmesg reports the problem:
                                  Switching off the screen with
                                  /opt/vc/bin/tvservice -o
                                  and on with
                                  /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chat 7
                                  does not work reliable! The git issue tells you more about.
                                  The workaround is a not yet described solution inside the config.txt
                                  the option “hdmi_blanking=1” is your friend in this case! :D
                                  Now i’m switching off the screen with
                                  vcgencmd display_power 0
                                  and on with
                                  vcgencmd display_power 1
                                  And it is working now like a charm! Did started to use it one day before this report and it is still working without any issue :)
                                  Honestly speaking i don’t use any MM module for switching off anymore. But maybe my discovered solution will help any other and might be a way to change the module as well.
                                  If you have trouble with on/off as well please check the output of dmesg. If you have the frambuffer problem you can fix it.
                                  My personal solution is to have the PIR state at FHEM and from FHEM i’m using a script to switch the screen. But that’s a special case and for the most people here the usage of a MM Module will be the better way.
                                  regards
                                  Dirk
                                  B D 2 Replies Last reply Reply Quote 2
                                    bibi @DirkS
                                    @DirkS thx for sharing! one question please : where is located the option : “hdmi_blanking=1” ???
                                      bhepler Module Developer @bibi
                                      @bibi Based on that pull request, it looks like it’s in the config.txt of your Pi. So /boot/config.txt
                                        DirkS
                                        @bibi yes you need to include it into /boot/config.txt
                                          bibi @DirkS
                                          @Dirks Thx!
                                          @bhepler Thx! i will add this option there under HDMI hotplug as i don’t know where else to add.
                                            bibi @bhepler
                                            @bhepler and @DirkS : any idea why my screen doesn’t stay off as long as no motion is detected??
                                            • 10
                                            • 11
                                            • 6 / 11
