    Background Image question ~ EasyBack
    9 Posts 3 Posters 1.3k Views 2 Watching
      j.ason
      Hi there,
      Thought the idea of adding my own desktop background image to my Pi would be awesome… Came across a module and thought I would give it a go…
      So this is what I have done so far…>>
      Got to modules and ran gitclone
      Dropped my own image into the EasyBack module folder as instructed
      Copied the config.js options however now get config error
      I am only interested (at this time) for a desktop image to appear rather than the use of the video part so when I used the entry I did leave the video part and YouTube part as “” - hope that is correct? Or am I to remove the videoName & youTubeID parts completely?
      			module: "MMM-EasyBack",
      			position: "fullscreen_below",
      			    bgName: "NHS.jpg",
      			    videoName: "",
      			    youTubeID: "",
      			    height: "1080px",
      			    width" "1920px",
      Any ideas would be gratefully welcomed…
      Thanks in advance
      J
        Mykle1 Project Sponsor Module Developer @j.ason
        @j-ason
        There is a file included in the images folder of the module. It’s called Example.jpg.
        Using the config entry from the repo your entry would look like this:
            module: 'MMM-EasyBack',
            position: 'fullscreen_below',
                bgName: "Example.jpg",          // "Example.jpg", the file name of your background image
                videoName: "",
                youTubeID: "",
                height: "1080px",    // your display's resolution in pixels. Enter in config.js
                width: "1920px",     // your display's resolution in pixels. Enter in config.js
        I just tested it and it works as expected.
        ReadMe says - Background picture files go in the “images” folder inside the MMM-EasyBack module folder.
        Also, the name of your image file is case sensitive so your config entry must have the exact name, case sensitive. (Also in the readMe)
        Let me know how you make out.
          j.ason
          Hi there and thanks for your reply…
          module: “MMM-EasyBack”,
          position: “fullscreen_below”,
          bgName: “Example.jpg”,
          videoName: “”,
          youTubeID: “”,
          height: “1080px”,
          width" “1920px”,
          This is what I have and yet still have config?
          TIA
          J
            @j-ason
            That entry is correct. Something else might be causing the error. You can do two things.
            1. Post your entire config here.using the code block option. It looks like this: </>
            2. start mm using npm start dev. Click the “Elements” tab at the top left of the window that appears.
            3. Report any errors. They will be in red. You may have to scroll.
              @j-ason said in Background Image question ~ EasyBack:
              height: “1080px”,
              width" “1920px”,
              Also, these two values have to match your your displays resolution
                j.ason @Mykle1
                @Mykle1
                Complete config listed below:
                FYI I did try the nom start dev option too however it said
                npm Error code ENOENT
                npm Error sys call OPEN
                npm Error path /home/pi/package.json
                npm Error errno -2
                npm error enoent Enoent: no such file or directory, open ‘/home/pi/package.json’
                npm error enoent This is related to npm not being able to find a file
                npm error enoent
                npm error A complete log of this run can be run in:
                npm error /home/pi/.npm/_logs/2020 -04-01T22_07_45_756Z-debug.log
                I am sorry if this a simple thing to you however as I have said before I bought a Pi and as I am on lockdown thought… Hey lets give this MM a go and see if I can understand code… Thought / hoped I would have MM up and running using other modules first and then be able to read and learn from there (easy option I know)…
                Thanks again for your time and effort - sorry for delay I am UK time so missed your reply last night
                /* Magic Mirror Config Sample
                • MIT Licensed.
                • For more information how you can configurate this file
                • See https://github.com/MichMich/MagicMirror#configuration
                var config = {
                // - “”, “0.0.0.0”, “::” to listen on any interface
                // Default, when address config is left out, is “localhost”
                port: 8080,
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: "en",
                timeFormat: 24,
                units: "metric",
                		     // false, default for all  NON-armv6l devices
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		module: "MMM-Bose-Soundtouch",
                		header: "Music",
                		position: "bottom_right",
                		updateInterval: 5,
                		apiBase: '192.168.0.19',
                		    videoName: "",
                		    youTubeID: "",
                		    height: "1080px",
                		    width" "1920px",
                		header: "Calendar",
                					symbol: "My Calendar",
                					url: "https://calendar.google.com/calendar/ical/j.asonjmanhart%40gmail.com/private-d0f255d38247687de39d3f4fec66a79f/basic.ics",
                					maximumEntries: 5,
                					symbol: "calendar-check-o",
                				        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/UK_Holidays.ics",
                					maximumEntries: 5
                		module: "compliments",
                		position: "lower_third",
                			compliments: {
                				morning: [
                					"Have a great day",
                				afternoon: [
                					"Good afternoon folks",
                				evening: [
                					"Good evening",
                		updateInterval: 30000,
                		remoteFile: null,
                		fadeSpeed: 4000,
                		morningStartTime: 5,
                		morningEndTime: 12,
                		afternoonStartTime: 12,
                		afternoonEndTime: 17
                		module:"MMM-OpenmapWeather",
                		header: "Current Weather",
                			locationID: "2641598",
                			appid: "8a0a36897340ca635a879e7c7ce77966",
                			colorIcon: true
                		module: "weatherforecast",
                		header: "Weather Forecast",
                			locationID: "2641598",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                			maxNumberOfDays: "7",
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "BBC UK",
                					url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                			showSourceTitle: true,
                			showPublishDate: true,
                			broadcastNewsFeeds: true,
                			broadcastNewsUpdates: true
                if (typeof module !== “undefined”) {module.exports = config;}
                • bheplerB Offline
                  bhepler Module Developer @j.ason
                  videoName: “”,
                  youTubeID: “”,
                  height: “1080px”,
                  width" “1920px”,
                  I think I found it. It should read width: "1920". You’re missing the : and have an extra ".
                  J Mykle1M 2 Replies Last reply Reply Quote 1
                    j.ason @bhepler
                    @bhepler
                    You sir / madam are a blooming legend :-) :-) :-) :-) :-) :-) :-)
                      Mykle1 Project Sponsor Module Developer @bhepler
                      @bhepler
                      Thanks hep. I didn’t see that. :thumbsup:
