    Background Image question ~ EasyBack
    9 Posts 3 Posters 1.3k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @j.ason
      @j-ason
      That entry is correct. Something else might be causing the error. You can do two things.
      1. Post your entire config here.using the code block option. It looks like this: </>
      2. start mm using npm start dev. Click the “Elements” tab at the top left of the window that appears.
      3. Report any errors. They will be in red. You may have to scroll.
        @j-ason said in Background Image question ~ EasyBack:
        height: “1080px”,
        width" “1920px”,
        Also, these two values have to match your your displays resolution
          j.ason @Mykle1
          @Mykle1
          Complete config listed below:
          FYI I did try the nom start dev option too however it said
          npm Error code ENOENT
          npm Error sys call OPEN
          npm Error path /home/pi/package.json
          npm Error errno -2
          npm error enoent Enoent: no such file or directory, open ‘/home/pi/package.json’
          npm error enoent This is related to npm not being able to find a file
          npm error enoent
          npm error A complete log of this run can be run in:
          npm error /home/pi/.npm/_logs/2020 -04-01T22_07_45_756Z-debug.log
          I am sorry if this a simple thing to you however as I have said before I bought a Pi and as I am on lockdown thought… Hey lets give this MM a go and see if I can understand code… Thought / hoped I would have MM up and running using other modules first and then be able to read and learn from there (easy option I know)…
          Thanks again for your time and effort - sorry for delay I am UK time so missed your reply last night
          /* Magic Mirror Config Sample
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 24,
          units: "metric",
          		     // false, default for all  NON-armv6l devices
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		module: "MMM-Bose-Soundtouch",
          		header: "Music",
          		position: "bottom_right",
          		updateInterval: 5,
          		apiBase: '192.168.0.19',
          		module: "MMM-EasyBack",
          		position: "fullscreen_below",
          		    bgName: "Example.jpg",
          		    videoName: "",
          		    youTubeID: "",
          		    height: "1080px",
          		    width" "1920px",
          		header: "Calendar",
          					symbol: "My Calendar",
          					url: "https://calendar.google.com/calendar/ical/j.asonjmanhart%40gmail.com/private-d0f255d38247687de39d3f4fec66a79f/basic.ics",
          					maximumEntries: 5,
          					symbol: "calendar-check-o",
          				        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/UK_Holidays.ics",
          					maximumEntries: 5
          		module: "compliments",
          		position: "lower_third",
          			compliments: {
          				morning: [
          					"Have a great day",
          				afternoon: [
          					"Good afternoon folks",
          				evening: [
          					"Good evening",
          		updateInterval: 30000,
          		remoteFile: null,
          		fadeSpeed: 4000,
          		morningStartTime: 5,
          		morningEndTime: 12,
          		afternoonStartTime: 12,
          		afternoonEndTime: 17
          		module:"MMM-OpenmapWeather",
          		header: "Current Weather",
          			locationID: "2641598",
          			appid: "8a0a36897340ca635a879e7c7ce77966",
          			colorIcon: true
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			locationID: "2641598",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			maxNumberOfDays: "7",
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "BBC UK",
          					url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          if (typeof module !== “undefined”) {module.exports = config;}
          • bheplerB Offline
            bhepler Module Developer @j.ason
            module: “MMM-EasyBack”,
            position: “fullscreen_below”,
            bgName: “Example.jpg”,
            videoName: “”,
            youTubeID: “”,
            height: “1080px”,
            width" “1920px”,
            I think I found it. It should read width: "1920". You’re missing the : and have an extra ".
            J Mykle1M 2 Replies Last reply Reply Quote 1
              j.ason @bhepler
              @bhepler
              You sir / madam are a blooming legend :-) :-) :-) :-) :-) :-) :-)
                Mykle1 Project Sponsor Module Developer @bhepler
                @bhepler
                Thanks hep. I didn’t see that. :thumbsup:
