Background Image question ~ EasyBack
9 Posts 3 Posters 1.0k Views 2 Watching
    j.ason
    Hi there,
    Thought the idea of adding my own desktop background image to my Pi would be awesome… Came across a module and thought I would give it a go…
    So this is what I have done so far…>>
    Got to modules and ran gitclone
    Dropped my own image into the EasyBack module folder as instructed
    Copied the config.js options however now get config error
    I am only interested (at this time) for a desktop image to appear rather than the use of the video part so when I used the entry I did leave the video part and YouTube part as “” - hope that is correct? Or am I to remove the videoName & youTubeID parts completely?
    			module: "MMM-EasyBack",
    			position: "fullscreen_below",
    			    bgName: "NHS.jpg",
    			    videoName: "",
    			    youTubeID: "",
    			    height: "1080px",
    			    width" "1920px",
    Any ideas would be gratefully welcomed…
    Thanks in advance
    J
    M 1 Reply Last reply Apr 1, 2020, 8:58 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @j.ason
      @j-ason
      There is a file included in the images folder of the module. It’s called Example.jpg.
      Using the config entry from the repo your entry would look like this:
          module: 'MMM-EasyBack',
          position: 'fullscreen_below',
              bgName: "Example.jpg",          // "Example.jpg", the file name of your background image
              videoName: "",
              youTubeID: "",
              height: "1080px",    // your display's resolution in pixels. Enter in config.js
              width: "1920px",     // your display's resolution in pixels. Enter in config.js
      I just tested it and it works as expected.
      ReadMe says - Background picture files go in the “images” folder inside the MMM-EasyBack module folder.
      Also, the name of your image file is case sensitive so your config entry must have the exact name, case sensitive. (Also in the readMe)
      Let me know how you make out.
        j.ason
        Hi there and thanks for your reply…
        module: “MMM-EasyBack”,
        position: “fullscreen_below”,
        bgName: “Example.jpg”,
        videoName: “”,
        youTubeID: “”,
        height: “1080px”,
        width" “1920px”,
        This is what I have and yet still have config?
        TIA
        J
        M 2 Replies Last reply Apr 1, 2020, 9:58 PM Reply Quote 0
          @j-ason
          That entry is correct. Something else might be causing the error. You can do two things.
          1. Post your entire config here.using the code block option. It looks like this: </>
          2. start mm using npm start dev. Click the “Elements” tab at the top left of the window that appears.
          3. Report any errors. They will be in red. You may have to scroll.
            @j-ason said in Background Image question ~ EasyBack:
            height: “1080px”,
            width" “1920px”,
            Also, these two values have to match your your displays resolution
            J 1 Reply Last reply Apr 2, 2020, 10:23 AM Reply Quote 0
              j.ason @Mykle1
              @Mykle1
              Complete config listed below:
              FYI I did try the nom start dev option too however it said
              npm Error code ENOENT
              npm Error sys call OPEN
              npm Error path /home/pi/package.json
              npm Error errno -2
              npm error enoent Enoent: no such file or directory, open ‘/home/pi/package.json’
              npm error enoent This is related to npm not being able to find a file
              npm error enoent
              npm error A complete log of this run can be run in:
              npm error /home/pi/.npm/_logs/2020 -04-01T22_07_45_756Z-debug.log
              I am sorry if this a simple thing to you however as I have said before I bought a Pi and as I am on lockdown thought… Hey lets give this MM a go and see if I can understand code… Thought / hoped I would have MM up and running using other modules first and then be able to read and learn from there (easy option I know)…
              Thanks again for your time and effort - sorry for delay I am UK time so missed your reply last night
              /* Magic Mirror Config Sample
              • MIT Licensed.
              • For more information how you can configurate this file
              • See https://github.com/MichMich/MagicMirror#configuration
              var config = {
              // - “”, “0.0.0.0”, “::” to listen on any interface
              // Default, when address config is left out, is “localhost”
              port: 8080,
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
              language: "en",
              timeFormat: 24,
              units: "metric",
              		     // false, default for all  NON-armv6l devices
              		module: "alert",
              		module: "updatenotification",
              		position: "top_bar"
              		module: "clock",
              		position: "top_left"
              		module: "MMM-Bose-Soundtouch",
              		header: "Music",
              		position: "bottom_right",
              		updateInterval: 5,
              		apiBase: '192.168.0.19',
              		    videoName: "",
              		    youTubeID: "",
              		    height: "1080px",
              		    width" "1920px",
              		header: "Calendar",
              					symbol: "My Calendar",
              					url: "https://calendar.google.com/calendar/ical/j.asonjmanhart%40gmail.com/private-d0f255d38247687de39d3f4fec66a79f/basic.ics",
              					maximumEntries: 5,
              					symbol: "calendar-check-o",
              				        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/UK_Holidays.ics",
              					maximumEntries: 5
              		module: "compliments",
              		position: "lower_third",
              			compliments: {
              				morning: [
              					"Have a great day",
              				afternoon: [
              					"Good afternoon folks",
              				evening: [
              					"Good evening",
              		updateInterval: 30000,
              		remoteFile: null,
              		fadeSpeed: 4000,
              		morningStartTime: 5,
              		morningEndTime: 12,
              		afternoonStartTime: 12,
              		afternoonEndTime: 17
              		module:"MMM-OpenmapWeather",
              		header: "Current Weather",
              			locationID: "2641598",
              			appid: "8a0a36897340ca635a879e7c7ce77966",
              			colorIcon: true
              		module: "weatherforecast",
              		header: "Weather Forecast",
              			locationID: "2641598",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			maxNumberOfDays: "7",
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: "BBC UK",
              					url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
              			broadcastNewsUpdates: true
              if (typeof module !== “undefined”) {module.exports = config;}
              B 1 Reply Last reply Apr 2, 2020, 6:16 PM Reply Quote 0
                bhepler Module Developer @j.ason
                videoName: “”,
                youTubeID: “”,
                height: “1080px”,
                width" “1920px”,
                I think I found it. It should read width: "1920". You’re missing the : and have an extra ".
                J M 2 Replies Last reply Apr 2, 2020, 8:12 PM Reply Quote 1
                  j.ason @bhepler
                  @bhepler
                  You sir / madam are a blooming legend :-) :-) :-) :-) :-) :-) :-)
                    Mykle1 Project Sponsor Module Developer @bhepler
                    @bhepler
                    Thanks hep. I didn’t see that. :thumbsup:
