    Random Quotes
    19 Posts 9 Posters 18.0k Views 8 Watching
    • K Offline
      KirAsh4 Moderator
      All the quotes are in the random_quotes.js file. You can change them to anything you want.
      • G Offline
        geeflaxx
        so i have to add the paramteres (updateintervall etc) in my config ?
        because in your example wasn’t that
        very thank you!
        ‘modules: [
        module: ‘random_quotes’,
        position: ‘lower_third’,
        updateIntervall=500 // The config property is optional
        fadeSpeed=4 // Without a config, a random quote is shown,
        category=random // selected from all of the categories available.
        • K Offline
          KirAsh4 Moderator
          Correct, as the documentation shows.
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @geeflaxx
            @geeflaxx you need to write it down like this
                module: 'random_quotes',
                position: 'lower_third',
                    updateIntervall: 500,
                    fadeSpeed: 4,
                    category: 'random'
            • G Offline
              geeflaxx
              very thanksfull an both you help me a lot
              i edited it
              • G Offline
                geeflaxx
                how i can do a wordwrap ? (that the word is under my words) (i hope you understand despite my english skills ^^)
                like that :
                hello
                my name is
                • K Offline
                  KirAsh4 Moderator
                  Can’t. It’s a single line each time.
                    Jopyth Moderator @KirAsh4
                    @KirAsh4 Couldn’t @geeflaxx insert a <br> inside all quotes? Would be a lot of manual work though.
                    • Y Offline
                      yawns Moderator
                      That’s what I was thinking as well. After all it is just text in a <div> isn’t it?
                      • K Offline
                        KirAsh4 Moderator
                        Actually, yes you could. Basically any HTML tag would (should?) work. I did a ‘split’ on a key character so I can apply two different styles, one on the quote, and one on the author. Slightly different approach.
                        • G Offline
                          geeflaxx
                          how i can config the data so, that the autor is always the same ?
                          or
                          do i need after a quote add the autor with “~” ?
                          Q 1 Reply Last reply Reply Quote 0
                          • Q Offline
                            qqqqqqqq @geeflaxx
                            @geeflaxx said in Random Quotes:
                            or
                            Too late, but here it goes.
                            You can add all the quotes from the same author in a category (like motivational or life) and change the config file to show quotes from that category only.
                            It’s upto you to add “~”, but if you do, they will follow different styles as set by the developer.
                            @KirAsh4 , I’ve noticed that the selection of quotes isn’t true random. Every time I start MM, I get the same quotes.
                              [[global:former-user]] @KirAsh4
                              @KirAsh4
                              Love the module, works a treat.
                              Can’t figure out how to change the size of the quote and/or author however.
                              I’ve tried adding the following to custom.css
                              .random_quotes .medium {
                              font-size: 50px;
                              and
                              .random_quotes .quote .medium {
                              font-size: 50px;
                              Neither work however.
                              I think you’ll be able to see what I tried to do here, but please could you help me figure out where I am going wrong?
                              Thanks in advance.
