    Random Quotes
    19 Posts 9 Posters 18.3k Views 8 Watching
    • W
      Wilco89
      I just installed it. it’s working fine, Did send you a PR there were some typos in the readme file. some people wouldn’t be able to install it with that typos.
      • K
        KirAsh4 Moderator
        Thanks, merged into dev. Will push it to master as well.
          pietrodona
          Hi, I am very bad with javascript is it possible to load the quotes from a text file?
          • K
            KirAsh4 Moderator
            Not as written. It would require a bit of rewriting to allow for a local call to a file. Not impossible, just not written.
            • G
              geeflaxx
              so is that right that you put the information from your script not from brainyguote?
              so i can change it in vocal to learn an another language ?
              i mean its only a script what change the text per time ?
              if that is it that i am thanksfull
              that i need it (for example for my english…)
              • K
                KirAsh4 Moderator
                All the quotes are in the random_quotes.js file. You can change them to anything you want.
                • G
                  geeflaxx
                  so i have to add the paramteres (updateintervall etc) in my config ?
                  because in your example wasn’t that
                  very thank you!
                  ‘modules: [
                  module: ‘random_quotes’,
                  position: ‘lower_third’,
                  updateIntervall=500 // The config property is optional
                  fadeSpeed=4 // Without a config, a random quote is shown,
                  category=random // selected from all of the categories available.
                  • K
                    KirAsh4 Moderator
                    Correct, as the documentation shows.
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @geeflaxx
                      @geeflaxx you need to write it down like this
                          module: 'random_quotes',
                          position: 'lower_third',
                              updateIntervall: 500,
                              fadeSpeed: 4,
                              category: 'random'
                      • G
                        geeflaxx
                        very thanksfull an both you help me a lot
                        i edited it
                        • G
                          geeflaxx
                          how i can do a wordwrap ? (that the word is under my words) (i hope you understand despite my english skills ^^)
                          like that :
                          hello
                          my name is
                          • K
                            KirAsh4 Moderator
                            Can’t. It’s a single line each time.
                              Jopyth Moderator @KirAsh4
                              @KirAsh4 Couldn’t @geeflaxx insert a <br> inside all quotes? Would be a lot of manual work though.
                              • Y
                                yawns Moderator
                                That’s what I was thinking as well. After all it is just text in a <div> isn’t it?
                                • K
                                  KirAsh4 Moderator
                                  Actually, yes you could. Basically any HTML tag would (should?) work. I did a ‘split’ on a key character so I can apply two different styles, one on the quote, and one on the author. Slightly different approach.
                                  • G
                                    geeflaxx
                                    how i can config the data so, that the autor is always the same ?
                                    or
                                    do i need after a quote add the autor with “~” ?
                                    Q 1 Reply Last reply Reply Quote 0
                                    • Q
                                      qqqqqqqq @geeflaxx
                                      @geeflaxx said in Random Quotes:
                                      or
                                      Too late, but here it goes.
                                      You can add all the quotes from the same author in a category (like motivational or life) and change the config file to show quotes from that category only.
                                      It’s upto you to add “~”, but if you do, they will follow different styles as set by the developer.
                                      @KirAsh4 , I’ve noticed that the selection of quotes isn’t true random. Every time I start MM, I get the same quotes.
                                        A Former User @KirAsh4
                                        @KirAsh4
                                        Love the module, works a treat.
                                        Can’t figure out how to change the size of the quote and/or author however.
                                        I’ve tried adding the following to custom.css
                                        .random_quotes .medium {
                                        font-size: 50px;
                                        and
                                        .random_quotes .quote .medium {
                                        font-size: 50px;
                                        Neither work however.
                                        I think you’ll be able to see what I tried to do here, but please could you help me figure out where I am going wrong?
                                        Thanks in advance.
