    Dynamic Module change
    11 Posts 5 Posters 8.2k Views 5 Watching
      done
      Maybe this is what you’re looking for?
      https://forum.magicmirror.builders/topic/516/display-modules-in-a-carousel
        Sillec123
        No this is only a module to change type. I mean a magic mirror main function with more than one area.
          Jopyth Moderator
          I think you can use this. Have a look at Scheduling Module Display.
          Example:
          hides and shows modules
            Sillec123
            Thanks but if i see it right, i have to build thousands of entries in my config for change the modules every xxx seconds. That’s not the goal.
            J I 2 Replies Last reply Reply Quote 0
              Jopyth Moderator @Sillec123
              @Sillec123 You have to create one (pair of?) entries per module, as I see it.But this is limited to a per minute schedule. What you want might be an extension of the Carousel, but configurable for areas. Or a per second scheduling of the Module Scheduler.
              S I 2 Replies Last reply Reply Quote 0
                Sillec123 @Jopyth
                @Jopyth Exactly but i think, it should be a main function and no module. It would make the smart mirror really smart. Please have a look on my example.
                • cowboysdudeC Offline
                  cowboysdude Module Developer @Sillec123
                  @Sillec123 said in Dynamic Module change:
                  You could do it. Just build a ‘metro’ module and then add ‘classes’ to your modules config.js…
                  But there is also a carousel module and a module scheduler…
                  • I Offline
                    ianperrin @Jopyth
                    @Jopyth said in Dynamic Module change:
                    I’ve not tried it but as the node cron module supports seconds, then MMM-ModuleScheduler may too. Feel free to try using a 6 part expression rather than the 5 part expressions in the examples for the module and report back
                    "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
                    • I Offline
                      ianperrin @Sillec123
                      Possibly, but the module now supports global, group and individual schedules so the configurations can be minimised which may help.
                        Sillec123
                        Thanks i will try it later.
