    Fresh install of MM on pi 3- buster
    4 Posts 3 Posters 597 Views 2 Watching
      bigmans
      Running into some problems with this install. I had a working mirror ~a year ago but it stopped working and I didn’t have the time to fix it until now. Formated card, and did a fresh install of the latest OS and followed the manual install on docs.magicmirror.builders/
      I had some problems with npm install (it kept crashing and rebooting with no warnings, after running it enough it said it was successful) Tried to run the
      npm install electron@6.0.12
      and ran into some errors too. Looking for some guidance to get this build back online
      ~R
      Mykle1M S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @bigmans
        @bigmans
        User @sdetweil has a script/installer that does all the dirty work for you, and it does it well. He’ll put the link here when he sees this post.
        All credit to him. :-)
          sdetweil @Mykle1
          @Mykle1
          See the installer command here
            sdetweil @bigmans
            @bigmans what version of node and npm are you running?
            node -v should be 10.1x.y (mine is 10.19.0)
            npm -v should be 6.1x.y (mine is 6.14.3)
            the 2.11 install will try to install electron 6.1.7
            use my script, it handles a lot of the issues
