    Installing on a Pi Zero
    175 Posts 33 Posters 294.0k Views 33 Watching
      sdetweil @nigel-daniels
      @nigel-daniels no, just mm
      • N Offline
        nigel-daniels @sdetweil
        @sdetweil looks like the script gets to the same place :(
        Installing dependencies ...
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@^6.1.7 (node_modules/electron):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Cannot read property 'resolve' of undefined
        npm ERR! Cannot read property 'resolve' of undefined
        npm ERR!     /home/pi/.npm/_logs/2020-04-13T15_17_35_327Z-debug.log
        Unable to install dependencies!
        The config.json only mentions electron in the optional dependancies so I don’t know where the resolve comes from. It looks to the the property of some var that is not being set.
          @nigel-daniels ok. We need to upgrade node or npm
          Try
          sudo npm I -g npm
          Then npm install --only=prod
          In the MagicMirror folder
          • N Offline
            @sdetweil thanks for the support, that fixed it!
            It looks like npm was broken. I removed node and npm then installed node v10.20.1 and things seem to be working again. Running npm install --only=prod let the install run without getting upset about electron!
              RushHour99
              I ran your raspberry.sh install script on a Raspberry Pi Zero W yesterday. I started with a fresh install of Rasbian. The script completed with some warnings, but the Magic Mirror started and seems to be running OK. What does this error mean? Should I try to fix it even though MagicMirror seems to be running OK?
              The errored log file was located at /home/pi/.npm/_logs/2020-04-14T22_35_02_257Z-debug.log
              Here is the snippet from the end:
              10077 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
              10078 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              10079 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
              10079 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
              10079 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
              10079 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
              10080 verbose stack Error: electron-chromedriver@6.0.0 install: `node ./download-chromedriver.js`
              10080 verbose stack Exit status 1
              10080 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
              10080 verbose stack     at EventEmitter.emit (events.js:189:13)
              10080 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
              10080 verbose stack     at ChildProcess.emit (events.js:189:13)
              10080 verbose stack     at maybeClose (internal/child_process.js:970:16)
              10080 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              10081 verbose pkgid electron-chromedriver@6.0.0
              10082 verbose cwd /home/pi/MagicMirror
              10083 verbose Linux 4.19.97+
              10084 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install" "eslint"
              10085 verbose node v10.15.2
              10086 verbose npm  v6.14.4
              10087 error code ELIFECYCLE
              10088 error errno 1
              10089 error electron-chromedriver@6.0.0 install: `node ./download-chromedriver.js`
              10089 error Exit status 1
              10090 error Failed at the electron-chromedriver@6.0.0 install script.
              10090 error This is probably not a problem with npm. There is likely additional logging output above.
              10091 verbose exit [ 1, true ]
              install.log:
              install starting  - Tue Apr 14 17:54:46 EDT 2020
              installing on armv6l processor system
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              Updating packages ...
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists...
              apt-get update  completed ok
              apt-get upgrade  started
              apt upgrade result =rc=0 Reading package lists...
              Building dependency tree...
              Reading state information...
              Calculating upgrade...
              Installing helper tools ...
              build-essential is already the newest version (12.6).
              curl is already the newest version (7.64.0-4+deb10u1).
              git is already the newest version (1:2.20.1-2+deb10u1).
              unzip is already the newest version (6.0-23+deb10u1).
              wget is already the newest version (1.20.1-1.1).
              wget set to manually installed.
              Minimum Node version: v10.1.0
              Installed Node version: v10.15.2
              No Node.js upgrade necessary.
              Minimum npm version: V6.0.0
              Installed npm version: V5.8.0
              npm should be upgraded.
              Installing npm ...
              npm is already the newest version (5.8.0+ds6-4).
              npm set to manually installed.
              upgrading npm to latest
              /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
              /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
              + npm@6.14.4
              added 435 packages from 869 contributors in 416.088s
              npm installation Done! version=V6.14.4
              Cloning MagicMirror ...
              Cloning MagicMirror Done!
              package.json update for armv6l completed ok
              > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              Dependencies installation Done!
              setting up initial config.js
              Check plymouth installation ...
              Splashscreen: Checking themes directory.
              Splashscreen: Create theme directory if not exists.
              Splashscreen: Changed theme to MagicMirror successfully.
              install and setup pm2
              pm2 not installed, installing
              pm2 install result npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.) /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2 /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev /usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + pm2@4.2.3 added 206 packages from 202 contributors in 240.179s
              get the pm2 platform specific startup command
              startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
              __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
               _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                 _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                  _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                   _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                    _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                     _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                      _\///______________\///______________\///__\///////////////__
                                        Runtime Edition
                      PM2 is a Production Process Manager for Node.js applications
                                   with a built-in Load Balancer.
                              Start and Daemonize any application:
                              $ pm2 start app.js
                              Load Balance 4 instances of api.js:
                              $ pm2 start api.js -i 4
                              Monitor in production:
                              $ pm2 monitor
                              Make pm2 auto-boot at server restart:
                              $ pm2 startup
                              To go further checkout:
                              http://pm2.io/
              [PM2] Init System found: systemd
              Platform systemd
              Template
              [Unit]
              Description=PM2 process manager
              Documentation=https://pm2.keymetrics.io/
              After=network.target
              [Service]
              Type=forking
              User=pi
              LimitNOFILE=infinity
              LimitNPROC=infinity
              LimitCORE=infinity
              Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
              Environment=PM2_HOME=/home/pi/.pm2
              PIDFile=/home/pi/.pm2/pm2.pid
              Restart=on-failure
              ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
              ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
              ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
              [Install]
              WantedBy=multi-user.target
              Target path
              /etc/systemd/system/pm2-pi.service
              Command list
              [ 'systemctl enable pm2-pi' ]
              [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
              [PM2] Making script booting at startup...
              [PM2] [-] Executing: systemctl enable pm2-pi...
              [PM2] [v] Command successfully executed.
              [PM2] Freeze a process list on reboot via:
              $ pm2 save
              [PM2] Remove init script via:
              $ pm2 unstartup systemd
              pm2 startup command done
              configure the pm2 config file for MagicMirror
              start MagicMirror via pm2 now
              save MagicMirror pm2 config now
              disable screensaver via gsettings was true and uint32 300
              disable screensaver via lightdm.conf
              disable screensaver via lxsession
              We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
              install completed - Tue Apr 14 19:02:54 EDT 2020
                sdetweil @RushHour99
                @RushHour99 that error is because some of the components used for the automated testing aren’t found. It’s ok.
                I need to recheck. I thought I had disabled trying to load those parts.
                All looks good
                R S 2 Replies Last reply Reply Quote 0
                  RushHour99 @sdetweil
                  @sdetweil Thanks for the reply. Magic Mirror does appear to be working just fine on my Pi Zero W. I only ran the install script. Should I run the upgrade script too?
                    @RushHour99 no. Upgrade is for every 3 months when the next release comes out. the scripts are only for MagicMirror… not the base OS, or any modules.
                      @RushHour99 looks like something changed between April 11 and April 15 in the npm tree, as it skipped the electron-chromdriver on the 11th and tries to install it today. is IS because of the specton library that is in the DEV tree, which i request to be skipped with --only=prod
                      so much fun…
                      I opened an issue against the scripts
                      https://github.com/sdetweil/MagicMirror_scripts/issues/5
                      to track it
                        @sdetweil said in Installing on a Pi Zero:
                        my intent is to submit this new installer to replace the project version…
                        I second the motion. :thumbsup:
                          sdetweil @Mykle1
                          so much fun…
                            sdetweil @Mykle1
                            @Mykle1 yeh, they updated the repo version in 2.10, and were completely removed in 2.11 to an outside repo…
                            • N Offline
                              naked-head
                              I got a new Pi Zero W, so I start a fresh install with a raspbian lite stretch (2019-04-08 version) but I got this error:
                              /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js:19
                                if (err != null) throw err
                              Error: Failed to find Electron v6.0.0 for linux-armv6l at https://github.com/electron/electron/releases/download/v6.0.0/chromedriver-v6.0.0-linux-armv6l.zip
                              searching on electron: https://github.com/electron/electron/releases/tag/v6.0.0 I can’t find armv6 version.
                              Whats the problem?
                              my pi is too old?
                              I got the wrong raspbian version?
                              thanks
                              qu1queQ S 2 Replies Last reply Reply Quote 0
                              • qu1queQ Offline
                                qu1que Project Sponsor @naked-head
                                @naked-head
                                I think electron is discontinued for raspberry pi zero, a few months ago I see a post in this forum talking about that. Now I can’t find that post.
                                  sdetweil @naked-head
                                  @naked-head did you use the automated installer? it handles this issue…
                                  electron is no longer available for the armv6l devices, and the default, manual npm install) will leave nothing installed…
                                  there is a side effect bug with npm… when my script runs, I request only the components needed for execution not for automated test, and the chromedriver is only used for automated testing… but npm didn’t pass on my request for only prod to sub modules…
                                  it causes no harm, other than that message
                                  you will have to run in split mode (serveronly + chromium-browser to view)…
                                  there are a bunch of tricky setup things… I suggest using the installer script
                                  also, lite does not include the graphical desktop, which is required, unless u intend to run headless
                                  see the installer script here
                                  all extra scripts were removed in 2.11, but referenced as ‘alternative’ install options…
                                  in the online doc
                                  • N Offline
                                    naked-head
                                    I used this script: https://github.com/ac2799/MagicMirrorPi0Installer following his guide.
                                    I’ll try the script you suggest.
                                    Thanks a lot
                                    • N Offline
                                      naked-head
                                      That’s work!!!
                                      And now the poor Pi Zero W had to do a lot of work :face_screaming_in_fear:
                                        @naked-head said in Installing on a Pi Zero:
                                        yes, it is only a pi0… !!
                                        • K Offline
                                          KNERD
                                          It seems this (the script OP posted) needs to be updated. I just tried this on the Raspberry Pi OS (based on Debian 10 “Buster”).
                                          It failed. I believe mostly because npm kept reporting warnings about not supporting nodejs version 10, and errors about could not load, or missing requirements not installed.
                                            sdetweil @KNERD
                                            @KNERD yes, please use mine. I support and test with it
                                            see
                                            • 5 / 9
