    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 do you have another sd card available?
      M 1 Reply Last reply
        MMRPi1 @sdetweil
        @sdetweil Don’t think so but I’ll look around.
          sdetweil @MMRPi1
          @MMRPi1 ok, before you start, one thing… electron for the newer node levels is not available for armv6l devices anymore, so we run in split mode, serveronly and chrome-browser to view… takes a little longer to start up
            MMRPi1 @sdetweil
            @sdetweil I think I do that already. Not sure what split mode is though. Side note: I found an old SD, how much space do I need for the OS and MM and everything else?
            S B 2 Replies Last reply
              sdetweil @MMRPi1
              @MMRPi1 i think 8 gig is too small
                MMRPi1 @sdetweil
                @sdetweil Cool /s All I’ve got is 4GB :/
                  bhepler Module Developer @MMRPi1
                  @MMRPi1 - You should be fine with anything over 6 GB or so. The Buster with desktop image is 4 GB unpacked. You can free up more space by uninstalling libreoffice and some other stuff. Or just throw gigabytes at it.
                    MMRPi1 @bhepler
                    @bhepler I’ve only got 4GB :/
                      There are three flavors of Buster on the downloads page. The full 4GB one is “Buster with desktop and recommended software”. You should be okay - barely - with the middle level: Buster with desktop
                        MMRPi1
                        Haven’t done anything yet, but I tried to SSH in again and it’s gone back to not working.
                        (interrupted system call is the error I get on terminus)
                          sdetweil @MMRPi1
                          @MMRPi1 reboot the router and it comes back?
                            MMRPi1 @sdetweil
                            @sdetweil Do you mind if we try this again. I’ve seen many answers referencing recompiling git or something, but I’m getting a lot of errors. I thought maybe it would solve the issue if I did it correctly, which I’m clearly not.
                            I’ve attached a screenshot of the terminal because there are a lot of errors I don’t really understand, but maybe you guys could make sense of it.
                            It’s just I don’t have another SD card and I’d prefer not to flash my existing one.
                            (First command works fine, but it’s a bit cut off at the top)
                              MMRPi1 @sdetweil
                              @sdetweil Also for the record SSH is back working (I DIDN’T restart the router), it seems a bit hit and miss but we’ll leave that for now
                              • 6 / 6
