    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 just to recheck
      git clone https://github.com/sdetweil/MagicMirror_scripts.git
      fails with the same error…
      do this
      cat ~/.gitconfig
      is there a
      [http]
          proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
      M 1 Reply Last reply
        MMRPi1 @sdetweil
        @sdetweil I got this instead: [http]
        sslVerify = false
          sdetweil @MMRPi1
          @MMRPi1
          https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
          ok, here is a solution I think… second response, recompile git with openssl
          link to script that does the work.
            MMRPi1 @sdetweil
            @sdetweil what do I put instead of <my_proxy>
              MMRPi1 @MMRPi1
              @MMRPi1 my_proxy
                bhepler Module Developer
                I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
                  MMRPi1 @bhepler
                  @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
                    sdetweil @MMRPi1
                    @MMRPi1 no… the second answer
                    Might be issue with gnutls Package. we have to compile a git Package with openssl instead of gnutls. Follow the below steps,
                      MMRPi1 @sdetweil
                      @sdetweil That one shows up first for me. In any case I tried and it still doesn’t work
                        sdetweil @MMRPi1
                        @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
                        sudo apt-get install -y build-essential fakeroot dpkg-dev
                        sudo apt-get -y build-dep git
                        sudo apt-get install -y libcurl4-openssl-dev
                        mkdir git-openssl
                        cd git-openssl
                        apt-get source git
                        cd git-*
                        sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
                        ./debian/control
                        sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
                        sudo dpkg-buildpackage -rfakeroot -b
                        sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
                        #CleanUp
                        cd ../../
                        sudo rm -rf git-openssl
                        You can follow This Bog or You can find simple script here to do that
                        M 2 Replies Last reply
                          MMRPi1 @sdetweil
                          @sdetweil I tried that and got gnutls_handshake() failed: Close notify
                          But that’s the same error as before :/
                            sdetweil @MMRPi1
                            @MMRPi1 then you are not running the openssl git…
                            u may have to run the pi admin tool for software and updates to enable source download… I had to
                            M B 2 Replies Last reply
                              MMRPi1 @sdetweil
                              @sdetweil How do you do that?
                                bhepler Module Developer @sdetweil
                                “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
                                M S 2 Replies Last reply
                                  MMRPi1 @bhepler
                                  @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
                                    the build process above doesn’t work. too old
                                      sdetweil @bhepler
                                      @bhepler but he can git clone from windows on the same local network.
                                      almost like an install failure or an sd card starting to fail.
                                      B 1 Reply Last reply
                                        @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                                        Let’s try to reinstall git one more time, if you please:
                                        sudo apt remove git --purge
                                        sudo apt install git
                                        S M 2 Replies Last reply
                                          sdetweil @bhepler
                                          @bhepler I don’t think its a git problem… I think its a library problem
                                            @sdetweil - Yeah, at this point it may be easier to just back up the config.jsfile and reflash the SD card.
                                            • 4 / 6
