    Can't clone from GitHub
    107 Posts 3 Posters 86.3k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1
      https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
      ok, here is a solution I think… second response, recompile git with openssl
      link to script that does the work.
        MMRPi1 @sdetweil
        @sdetweil what do I put instead of <my_proxy>
          MMRPi1 @MMRPi1
          @MMRPi1 my_proxy
            bhepler Module Developer
            I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
              MMRPi1 @bhepler
              @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
                sdetweil @MMRPi1
                @MMRPi1 no… the second answer
                Might be issue with gnutls Package. we have to compile a git Package with openssl instead of gnutls. Follow the below steps,
                  MMRPi1 @sdetweil
                  @sdetweil That one shows up first for me. In any case I tried and it still doesn’t work
                    sdetweil @MMRPi1
                    @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
                    sudo apt-get install -y build-essential fakeroot dpkg-dev
                    sudo apt-get -y build-dep git
                    sudo apt-get install -y libcurl4-openssl-dev
                    mkdir git-openssl
                    cd git-openssl
                    apt-get source git
                    cd git-*
                    sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
                    ./debian/control
                    sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
                    sudo dpkg-buildpackage -rfakeroot -b
                    sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
                    #CleanUp
                    cd ../../
                    sudo rm -rf git-openssl
                    You can follow This Bog or You can find simple script here to do that
                      MMRPi1 @sdetweil
                      @sdetweil I tried that and got gnutls_handshake() failed: Close notify
                      But that’s the same error as before :/
                        sdetweil @MMRPi1
                        @MMRPi1 then you are not running the openssl git…
                        u may have to run the pi admin tool for software and updates to enable source download… I had to
                        M B 2 Replies Last reply Reply Quote 0
                          MMRPi1 @sdetweil
                          @sdetweil How do you do that?
                            bhepler Module Developer @sdetweil
                            “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
                            M S 2 Replies Last reply Reply Quote 0
                              MMRPi1 @bhepler
                              @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
                                the build process above doesn’t work. too old
                                  sdetweil @bhepler
                                  @bhepler but he can git clone from windows on the same local network.
                                  almost like an install failure or an sd card starting to fail.
                                    @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                                    Let’s try to reinstall git one more time, if you please:
                                    sudo apt remove git --purge
                                    sudo apt install git
                                      sdetweil @bhepler
                                      @bhepler I don’t think its a git problem… I think its a library problem
                                        @sdetweil - Yeah, at this point it may be easier to just back up the config.jsfile and reflash the SD card.
                                          MMRPi1 @bhepler
                                          @bhepler Didn’t work
                                            MMRPi1 @bhepler
                                            @bhepler I’d very much prefer it doesn’t come to that. I’m on a Pi 1 and I had enough (too much) trouble setting up MM in the first place (since its not officially supported), I’m kinda paranoid it won’t work this time around
                                            • 4 / 6
