    Can't clone from GitHub
    107 Posts 3 Posters 82.9k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil You’re right, the SSH is all sorted
        sdetweil @MMRPi1
        @MMRPi1 eh? ‘all sorted’ means working to me
          MMRPi1 @sdetweil
          @sdetweil Yes I can SSH into the pi fine now.
            sdetweil @MMRPi1
            @MMRPi1 ok, I missed that … what did u reboot? the pi, or the router?
            let remove git and reinstall it
            sudo apt-get remove git
            sudo apt-get install git
              MMRPi1 @sdetweil
              @sdetweil I rebooted the router.
                MMRPi1 @sdetweil
                @sdetweil I tried reinstalling git and I got the same error.
                  sdetweil @MMRPi1
                  @MMRPi1 just to recheck
                  git clone https://github.com/sdetweil/MagicMirror_scripts.git
                  fails with the same error…
                  do this
                  cat ~/.gitconfig
                  is there a
                  [http]
                      proxy = http://mydomain\\myusername:mypassword@myproxyserver:8080
                    MMRPi1 @sdetweil
                    @sdetweil I got this instead: [http]
                    sslVerify = false
                      sdetweil @MMRPi1
                      @MMRPi1
                      https://stackoverflow.com/questions/51088635/git-clone-error-gnutls-handshake-failed-an-unexpected-tls-packet-was-receive
                      ok, here is a solution I think… second response, recompile git with openssl
                      link to script that does the work.
                        MMRPi1 @sdetweil
                        @sdetweil what do I put instead of <my_proxy>
                          MMRPi1 @MMRPi1
                          @MMRPi1 my_proxy
                            bhepler Module Developer
                            I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
                              MMRPi1 @bhepler
                              @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
                                sdetweil @MMRPi1
                                @MMRPi1 no… the second answer
                                Might be issue with gnutls Package. we have to compile a git Package with openssl instead of gnutls. Follow the below steps,
                                  MMRPi1 @sdetweil
                                  @sdetweil That one shows up first for me. In any case I tried and it still doesn’t work
                                    sdetweil @MMRPi1
                                    @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
                                    sudo apt-get install -y build-essential fakeroot dpkg-dev
                                    sudo apt-get -y build-dep git
                                    sudo apt-get install -y libcurl4-openssl-dev
                                    mkdir git-openssl
                                    cd git-openssl
                                    apt-get source git
                                    cd git-*
                                    sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
                                    ./debian/control
                                    sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
                                    sudo dpkg-buildpackage -rfakeroot -b
                                    sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
                                    #CleanUp
                                    cd ../../
                                    sudo rm -rf git-openssl
                                    You can follow This Bog or You can find simple script here to do that
                                      MMRPi1 @sdetweil
                                      @sdetweil I tried that and got gnutls_handshake() failed: Close notify
                                      But that’s the same error as before :/
                                        sdetweil @MMRPi1
                                        @MMRPi1 then you are not running the openssl git…
                                        u may have to run the pi admin tool for software and updates to enable source download… I had to
                                        M B 2 Replies Last reply Reply Quote 0
                                          MMRPi1 @sdetweil
                                          @sdetweil How do you do that?
                                            bhepler Module Developer @sdetweil
                                            “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
                                            M S 2 Replies Last reply Reply Quote 0
                                            • 4 / 6
