    Can't clone from GitHub
    107 Posts 3 Posters 88.5k Views 3 Watching
      MMRPi1 @MMRPi1
      @MMRPi1 my_proxy
        bhepler Module Developer
        I still want that connectivity check. The Pi can see the Windows box, but I want confirmation that the Pi can see the internet.
        M 1 Reply Last reply
          MMRPi1 @bhepler
          @bhepler Oh yeah sorry, I did that and it worked fine, I got a bit of html
            sdetweil @MMRPi1
            @MMRPi1 no… the second answer
            Might be issue with gnutls Package. we have to compile a git Package with openssl instead of gnutls. Follow the below steps,
              MMRPi1 @sdetweil
              @sdetweil That one shows up first for me. In any case I tried and it still doesn’t work
                sdetweil @MMRPi1
                @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
                sudo apt-get install -y build-essential fakeroot dpkg-dev
                sudo apt-get -y build-dep git
                sudo apt-get install -y libcurl4-openssl-dev
                mkdir git-openssl
                cd git-openssl
                apt-get source git
                cd git-*
                sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
                ./debian/control
                sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
                sudo dpkg-buildpackage -rfakeroot -b
                sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
                #CleanUp
                cd ../../
                sudo rm -rf git-openssl
                You can follow This Bog or You can find simple script here to do that
                M 2 Replies Last reply
                  MMRPi1 @sdetweil
                  @sdetweil I tried that and got gnutls_handshake() failed: Close notify
                  But that’s the same error as before :/
                    sdetweil @MMRPi1
                    @MMRPi1 then you are not running the openssl git…
                    u may have to run the pi admin tool for software and updates to enable source download… I had to
                    M B 2 Replies Last reply
                      MMRPi1 @sdetweil
                      @sdetweil How do you do that?
                        bhepler Module Developer @sdetweil
                        “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
                        M S 2 Replies Last reply
                          MMRPi1 @bhepler
                          @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
                            the build process above doesn’t work. too old
                              sdetweil @bhepler
                              @bhepler but he can git clone from windows on the same local network.
                              almost like an install failure or an sd card starting to fail.
                              B 1 Reply Last reply
                                @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                                Let’s try to reinstall git one more time, if you please:
                                sudo apt remove git --purge
                                sudo apt install git
                                S M 2 Replies Last reply
                                  sdetweil @bhepler
                                  @bhepler I don’t think its a git problem… I think its a library problem
                                    @sdetweil - Yeah, at this point it may be easier to just back up the config.jsfile and reflash the SD card.
                                      MMRPi1 @bhepler
                                      @bhepler Didn’t work
                                        MMRPi1 @bhepler
                                        @bhepler I’d very much prefer it doesn’t come to that. I’m on a Pi 1 and I had enough (too much) trouble setting up MM in the first place (since its not officially supported), I’m kinda paranoid it won’t work this time around
                                          sdetweil @MMRPi1
                                          @MMRPi1 use my installer script
                                          see here https://github.com/sdetweil/MagicMirror_scripts
                                          read the readme for the command to issue
                                            MMRPi1 @sdetweil
                                            @sdetweil that to update?
                                            B S 2 Replies Last reply
                                            • 4 / 6
