    Can't clone from GitHub
    107 Posts 3 Posters 82.9k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 then you are not running the openssl git…
      u may have to run the pi admin tool for software and updates to enable source download… I had to
      M B 2 Replies Last reply Reply Quote 0
        MMRPi1 @sdetweil
        @sdetweil How do you do that?
          bhepler Module Developer @sdetweil
          “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
          M S 2 Replies Last reply Reply Quote 0
            MMRPi1 @bhepler
            @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
              the build process above doesn’t work. too old
                sdetweil @bhepler
                @bhepler but he can git clone from windows on the same local network.
                almost like an install failure or an sd card starting to fail.
                  @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                  Let’s try to reinstall git one more time, if you please:
                  sudo apt remove git --purge
                  sudo apt install git
                    sdetweil @bhepler
                    @bhepler I don’t think its a git problem… I think its a library problem
                      @sdetweil - Yeah, at this point it may be easier to just back up the config.jsfile and reflash the SD card.
                        MMRPi1 @bhepler
                        @bhepler Didn’t work
                          MMRPi1 @bhepler
                          @bhepler I’d very much prefer it doesn’t come to that. I’m on a Pi 1 and I had enough (too much) trouble setting up MM in the first place (since its not officially supported), I’m kinda paranoid it won’t work this time around
                            sdetweil @MMRPi1
                            @MMRPi1 use my installer script
                            see here https://github.com/sdetweil/MagicMirror_scripts
                            read the readme for the command to issue
                              MMRPi1 @sdetweil
                              @sdetweil that to update?
                              B S 2 Replies Last reply Reply Quote 0
                                bhepler Module Developer @MMRPi1
                                @MMRPi1 - He has an installation script too. Use that one instead. It’s quite robust.
                                If you’re really paranoid about losing your data, you can make an image of your SD card before reflashing it. If anything goes wrong, you can just flash that image back onto the card.
                                The downside is that it’s going to take a fair amount of time to install Magic Mirror again. But I think at this point it’s going to be faster this way than to keep banging our heads against this TLS error.
                                  sdetweil @MMRPi1
                                  @MMRPi1 no. install
                                  my stuff does ONLY MagicMirror related work
                                  so create a new sd card, get it all working, ssh, whatever
                                  and check that git clone works (U can get this repo), just don’t use it after download
                                  then ssh in and execute the MM install script command
                                    sdetweil @bhepler
                                    @bhepler said in Can't clone from GitHub:
                                    typically less than 20 minutes
                                    oh, use raspian buster, not jessie or stretch… too old now
                                      @sdetweil said in Can't clone from GitHub:
                                      He’s on an RPI 1. That’s not typical.
                                        sdetweil @bhepler
                                        @bhepler still won’t be bad… take 25 on my pi0
                                          MMRPi1 @bhepler
                                          @bhepler For reference on why I’m sceptical, check my other thread from a few years back
                                            sdetweil @MMRPi1
                                            @MMRPi1 its been a mess… the old installer didn’t work, and there are tons of old documents that people built 2-3 years ago, that are no mostly useless, but we can’t get rid of them.
                                            i wanted the installer to be THE way to get it installed, by it takes a lot of work, and it was felt that was outside the MM project objectives… so they were removed in 2.11. armv6l devices pi 0, 1 and pi2 a are not supported (ie won’t run) unless some extra work is done… my script handles all that
                                            • 5 / 6
