    Can't clone from GitHub
    107 Posts 3 Posters 84.4k Views 3 Watching
      MMRPi1 @sdetweil
      @sdetweil that to update?
      B S 2 Replies Last reply Reply Quote 0
        bhepler Module Developer @MMRPi1
        @MMRPi1 - He has an installation script too. Use that one instead. It’s quite robust.
        If you’re really paranoid about losing your data, you can make an image of your SD card before reflashing it. If anything goes wrong, you can just flash that image back onto the card.
        The downside is that it’s going to take a fair amount of time to install Magic Mirror again. But I think at this point it’s going to be faster this way than to keep banging our heads against this TLS error.
          sdetweil @MMRPi1
          @MMRPi1 no. install
          my stuff does ONLY MagicMirror related work
          so create a new sd card, get it all working, ssh, whatever
          and check that git clone works (U can get this repo), just don’t use it after download
          then ssh in and execute the MM install script command
            sdetweil @bhepler
            @bhepler said in Can't clone from GitHub:
            typically less than 20 minutes
            oh, use raspian buster, not jessie or stretch… too old now
              bhepler Module Developer @sdetweil
              @sdetweil said in Can't clone from GitHub:
              He’s on an RPI 1. That’s not typical.
                sdetweil @bhepler
                @bhepler still won’t be bad… take 25 on my pi0
                  MMRPi1 @bhepler
                  @bhepler For reference on why I’m sceptical, check my other thread from a few years back
                    sdetweil @MMRPi1
                    @MMRPi1 its been a mess… the old installer didn’t work, and there are tons of old documents that people built 2-3 years ago, that are no mostly useless, but we can’t get rid of them.
                    i wanted the installer to be THE way to get it installed, by it takes a lot of work, and it was felt that was outside the MM project objectives… so they were removed in 2.11. armv6l devices pi 0, 1 and pi2 a are not supported (ie won’t run) unless some extra work is done… my script handles all that
                      MMRPi1 @sdetweil
                      @sdetweil Oh alright I guess. Well I guess I’ll image the SD, flash it, try again and hope for the best. Here goes
                        good luck
                          sdetweil @MMRPi1
                          @MMRPi1 do you have another sd card available?
                            MMRPi1 @sdetweil
                            @sdetweil Don’t think so but I’ll look around.
                              sdetweil @MMRPi1
                              @MMRPi1 ok, before you start, one thing… electron for the newer node levels is not available for armv6l devices anymore, so we run in split mode, serveronly and chrome-browser to view… takes a little longer to start up
                                MMRPi1 @sdetweil
                                @sdetweil I think I do that already. Not sure what split mode is though. Side note: I found an old SD, how much space do I need for the OS and MM and everything else?
                                S B 2 Replies Last reply Reply Quote 0
                                  sdetweil @MMRPi1
                                  @MMRPi1 i think 8 gig is too small
                                    MMRPi1 @sdetweil
                                    @sdetweil Cool /s All I’ve got is 4GB :/
                                      @MMRPi1 - You should be fine with anything over 6 GB or so. The Buster with desktop image is 4 GB unpacked. You can free up more space by uninstalling libreoffice and some other stuff. Or just throw gigabytes at it.
                                        MMRPi1 @bhepler
                                        @bhepler I’ve only got 4GB :/
                                          There are three flavors of Buster on the downloads page. The full 4GB one is “Buster with desktop and recommended software”. You should be okay - barely - with the middle level: Buster with desktop
                                            MMRPi1
                                            Haven’t done anything yet, but I tried to SSH in again and it’s gone back to not working.
                                            (interrupted system call is the error I get on terminus)
                                            • 5 / 6
