    MMM-NewsFeedTicker
    94 Posts 15 Posters 90.0k Views 14 Watching
    • justjim1220J
      justjim1220 Module Developer @mrSnatz
      @mrSnatz
      I have never used a Tinkerboard, so no thoughts regarding the use of one. Apologies!
      Jim Hallock - 1995
        A Former User @mrSnatz
        @mrSnatz
        I didn’t test this module on ATB, but ATB is definitely stronger than RPI.
        However apart from this module, you have more option nowadays. I think you can consider RK3399 or S922X. I especially recommend Jetson Nano at this moment for powerful GPU. RockPi 4 or NanoPi M4 is also good for overall performance.
        • justjim1220J
          justjim1220 Module Developer @mumblebaj
          @mumblebaj
          Please update your MMM-NewsFeedTicker and run it to see if it is working the way you are wanting.
          git pull
          Thanks!
          Jim Hallock - 1995
            dirkie @Guest
            I run MM on a dedicated Intel NUC and I still occure this stuttering you are talking about. I noticed that the suttering appears when “MMM-ImagesPhotos” loads new pictures in slideshow mode. I was able to reduce this stuttering by reducing the size of the images…
            What I try to say “the power” does not help. I think the code is sometimes “sloppy”. Not that I could do anything better in terms of coding but just my 2cent…
            • G
              Giarry88
              Hi guys! I know that this topic is quite old, but I am trying to add this module to my magic mirror unsuccesfully.
              I added in the “config.js” file the module but it doesn’t show up. Any ideas on what i’ve done wrong?
              		module: "alert",
              		module: "updatenotification",
              		position: "top_bar"
              		module: "clock",
              		position: "top_left"
              		header: "Calendario di Google",
              					symbol: "calendar-check",
              					url: "MY CALENDAR"					}
              		module: "compliments",
              		position: "lower_third"
              		module: "currentweather",
              			locationID: "6542009", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			appid: "MYAPPID"
              		module: "weatherforecast",
              		header: "Previsioni Meteo:",
              			appid: "MYAPPID"
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: "ANSA",
              					url: "https://www.ansa.it/sito/ansait_rss.xml"
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
              			broadcastNewsUpdates: true
              disabled: false,
              module: “MMM-NewsFeedTicker”,
              position: “bottom_bar”,
              //classes: “day_scheduler”,
              feeds: [
              title: “New York Times”,
              url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”,
              customLogo: “NYT_logo_rss_250x40.png”
              title: “USA Today”,
              url: “http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories”,
              customLogo: “RSS_Syndication_Logo-USATN.png”
              title: “BBC World News”,
              url: “http://feeds.bbci.co.uk/news/world/rss.xml#”,
              customLogo: “bbc_news_120x60.gif”
              Thanks in advance!
                sdetweil @Giarry88
                @Giarry88 from the MagicMirror folder do
                npm run check:config
                • G
                  Giarry88 @sdetweil
                  @sdetweil said in MMM-NewsFeedTicker:
                  Thanks sdetweil.
                  the terminal says:
                  pi@raspberrypi:~/magicmirror $ npm run check:config
                  npm ERR! missing script: check:config
                  npm ERR! /home/pi/.npm/_logs/2020-04-22T00_59_46_184Z-debug.log
                  the log says:
                  1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘run’, ‘check:config’ ]
                  2 info using npm@6.14.4
                  3 info using node@v10.20.1
                  4 verbose stack Error: missing script: check:config
                  4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
                  4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:63:5
                  4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:116:5
                  4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:436:5
                  4 verbose stack at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:391:45)
                  4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:434:3)
                  4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:161:5)
                  4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:382:12
                  4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:115:16
                  4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                  5 verbose cwd /home/pi/magicmirror
                  6 verbose Linux 4.19.97-v7l+
                  7 verbose argv “/usr/bin/node” “/usr/bin/npm” “run” “check:config”
                  8 verbose node v10.20.1
                  9 verbose npm v6.14.4
                  10 error missing script: check:config
                  11 verbose exit [ 1, true ]
                  What does “check.config” do?
                    sdetweil @Giarry88
                    @Giarry88 ok, I hate this thing.
                    npm run config:check
                      sdetweil @Giarry88
                      @Giarry88 said in MMM-NewsFeedTicker:
                      It checks the config.js file
                      • G
                        Giarry88
                        Ok, i’ve checked and corrected it with geanie and now the syntax is correct but it still doesn’t show it on mm
                          sdetweil @Giarry88
                          @Giarry88 open the developers window ctrl-shift-i on the keyboard, and select the console tab and scroll up to see any errors.
                          • G
                            Giarry88 @sdetweil
                            yes,
                            Load script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
                            :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                            loader.js:187 Error on loading script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
                            script.onerror @ loader.js:187
                            loader.js:194 Load stylesheet: css/custom.css
                            (index):1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                            loader.js:203 Error on loading stylesheet: css/custom.css
                              sdetweil @Giarry88
                              @Giarry88 sounds like u didn’t install the module in the right place
                              • G
                                Giarry88 @sdetweil
                                I’ve nstalled it in the Modules folders (outside of the Default folder, correct?)
                                  sdetweil @Giarry88
                                  @Giarry88 :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                                  says file not there
                                  you can get rid of this one by creating an empty custom.css (my installation script does this)
                                  touch ~/MagicMirror/css/custom.css
                                  • G
                                    Giarry88 @sdetweil
                                    says file not there
                                    so…
                                    I created the custom.css (but I’ve added the command for removing the borders, because I had it in the main.css - yes…i know…my bad :grimacing_face: - also it seems I can’t remove the spacing at the top, but this is a ittle bit OT) now as you said it previously that error disappeared.
                                    Now I have only
                                    GET http://localhost:8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js net::ERR_ABORTED 404 (Not Found)
                                    But this morning I’ve installed an other module (MMM-networrk-signal) in the same way and it is working properly
                                    Load script: modules/MMM-network-signal//MMM-network-signal.js
                                    Module registered: MMM-network-signal
                                    I am confused…
                                    EDIT
                                    My mistake was that I didn’t put capital letters in the name of the folder (I didn’t think it would have mattered)…
                                    Now I can see the red bar with “Loading” and in the console it keeps showing :
                                    MMM-NewsFeedTicker - unknown notification, ignoring: CLOCK_SECOND
                                    MMM-NewsFeedTicker - received notification: CLOCK_SECOND
                                      sdetweil @Giarry88
                                      linux is case sensitive… windows is not
                                      look in the console where u start ed MagicMirror
                                      if pm2, the use the pm2 logs --lines=100 command to view the logs…
                                      the error more than likely is a bad url, ???
                                      • G
                                        Giarry88 @sdetweil
                                        I don’t know why, when I closed and Opened again Magic Mirror, it wasn’t working at all; so I started with the backup of the config file and now it is working everything, ticker included. I think that I just needed to remove the default feed (especially the url - I was asking him to load the same feed on both modules -).
                                        Now I only have an issue with the stuttering ticker (but I’ve read something about it so I will try solving it by looking at those posts).
                                        Thanks again sdetweil, especially for your patience!
                                        • L
                                          liquidevo
                                          Hi love the module can anyone help me out ? I want each of the headlines to be longer sometimes it cuts the headline midway so I cannot read completly , and also anyone knows if I can add the qr code to this module ?
                                          thank you
                                          • Cr4z33C
                                            Cr4z33
                                            @justjim1220 I’ve moved to a NUC and your module is now scrolling incredibly smooth. :D
                                            Only can you please tell me what to edit to avoid scrolling from right to left (after having scrolled from left to right)?
                                            • 4 / 5
